Old 05-25-2024, 01:48 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Should I swap in a temporary CV axle?
On a trip my sway bar end link snapped, it took off my cv boot clamp and made it fling out some grease. I can't find any tears in the cv boot, and I replaced the metal clamp.
When I get home I plan to do a large service on the front, replace both my original lower ball joints (and bolts), replace original brake hose, and reboot the oem CV axle. But between there is 900 miles of highway.
My options are to swap in a cheap CV axle for the drive home or to leave the old one on, and both options have pros and cons.
I think the benefit of swapping out the CV axle is obvious, but the downside is I have to remove the 4 infamous bolts that hold the lower ball joint to the caliper, and since I'm short for time I'll have to reuse these bolts.
The other option is to leave the CV axle on, but if it lost too much grease I could damage it beyond repair. This option has benefits, it's cheaper, and it guarantees that I'll have enough time at home to fix everything else before I go away for business in early June.
So what do you think? Can I get away with leaving it in or should I put the replacement one on? Is it safe to reuse the original ball joint bolts?
I took a photo when it happened, so that should give you an idea.
Should I swap in a temporary CV axle?-img_4951-jpg
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 05-25-2024, 02:39 PM #2
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing has a spectacular aura about GhostRing has a spectacular aura about
GhostRing's Avatar
Personally, I would remove both links, strap the sway bar out of the way and drive home.
A swap is pretty easy with the right tools, but I'd rather do it in my garage than a parking lot.
I drove around with an missing OEM boot for like 900 weeks* and I finally re-booted it
and it's still doing great. That's winter, dirt, dust, mud, etc. for a loooong time and it held up.
eta: days!
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 05-25-2024, 03:27 PM #3
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Those boots are packed with a lot of grease. If only a bit came out and you don't think there was an opportunity for dirt to get into the boot then I'd say clamp it and move on. You can reboot some other time and be fine.
JZiggy is offline   Reply With QuoteReply With Quote
Old 05-25-2024, 04:14 PM #4
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
I drove around with an missing OEM boot for like 900 weeks and I finally re-booted it
I already replaced the broken link so that won't be a problem.
Old 05-25-2024, 09:11 PM #5
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
I finally get to share my dirty little secret. I drove around on an OEM axle with a ripped boot for over four years until I replaced it. I just trashed it afterwards, but not once did I ever encounter any problems as a result of it being torn open and flinging grease the way it was. Your mileage may vary, of course, so do what you will with the above information. I’m not saying it’s a great thing to do, but that’s just my own personal experience!
axle , ball , bolts , home , original
1st Gen 4Runner Solid Axle Swap and 1UZ Engine Swap NotKewl Classic T4Rs 24 12-12-2023 12:14 PM
Axle Swap collierunner 4th Gen T4Rs 5 07-31-2017 04:06 PM
Axle swap on 95 mtbfish Classic T4Rs 2 12-08-2013 11:05 PM
Im starting to get the 2.5yr blues...solid front axle swap or lt1 ls1 v8 swap? 240m3srt 3rd gen T4Rs 29 10-03-2011 12:15 AM
Solid Axle Swap vs regular axle w/ lift/suspension? priestsallore Classic T4Rs 9 04-28-2010 11:30 PM
