02-19-2018, 04:44 PM
SEM colors for Oak Interior (Light Oak and Darker brown)?
I am sure this has been covered to some extent but my searches only found “half” of the information I am looking for so I hope someone can help.
I have a 2000 T4R LTD in Jade green and “oak” interior. The interior plastics have two colors; the “light oak” and then the darker brown color (like the door panels, kick panels, etc.
Does anyone happen to know the SEM paint color codes for BOTH the light oak plastic AND the darker brown plastic?
Any help would be greatly appreciated!
02-19-2018, 05:59 PM
Real Name: Rick Tuk
Real Name: Rick Tuk
couple options, You may be able to find out from a dealer, go talk to the guys in the paint dept. or If you can find the # for a Toyota rep call them. If you have a paint store that caters to professional shops, go by early on a Friday afternoon. They will usually be slow and may be helpful.
02-19-2018, 06:04 PM
This is SEM 15223. Big fail. Matches the leather seats though.
02-19-2018, 09:40 PM
Acura tan is dead on for the light shade of plastics around the a pillar trim and stuff in 99+s
Sent from my Z981 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" ( Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - ( Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
02-20-2018, 01:01 AM
Real Name: Leon
Real Name: Leon
I was pretty happy with SEM Medium Prairie Tan for the lighter oak, see below how the painted Homelink bezel matches the OEM sunroof console.
But I have not seen any good leads on the darker oak color.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
02-20-2018, 10:32 AM
Thanks everyone. I did find one "off the shelf color" by Rustoleum (#7226 Bronze) which is almost identical to the dark brown color. The only thing is, it has a little bit of texture to it. I am going to continue the search for the dark brown color and will keep everyone posted!
02-20-2018, 10:39 AM
Real Name: Leon
Real Name: Leon
That would be great! I am reluctant to start buying random cans of SEM at $20 each, so it'd be good to know what works. I might also hit my local body shop supplies place and see if they'll do a custom mix of SEM.
02-20-2018, 10:57 AM
Real Name: Samuel
Real Name: Samuel
15223 castella and 15753 Light Oak have been mentioned before. Castella is just a bit lighter while light oak is just a bit darker.
2001 Sport Edition 4WD, IJM, Auto, DD
1999 SR5 4WD, Millennium Silver Metallic, 5 speed, E-locker, Trail Rig
1998 SR5 4WD Custom bodywork from hitting a median. Beater truck.
1999 Limited 4WD No longer a vehicle. Now it's in parts and stored away.
02-20-2018, 11:23 AM
Well the 15223 isn't even close to the dark color.
02-20-2018, 11:43 AM
Real Name: Samuel
Real Name: Samuel
I’ve seen other examples where it is pretty close. Just spraying it on with no prep work will produce a bad match. What did you do to prep the surface? Another member used it to spray an FMU and then compared it to the OE sunglasses holder. It was very close and a good match.
Edit: sorry misread your post. It matches the lighter oak plastic.
02-20-2018, 12:41 PM
Where did you find the homelink to buy? I've been looking for one to install
02-20-2018, 12:47 PM
Real Name: Leon
Real Name: Leon
I bought one off e-bay, it was pretty cheap (under $20). Frankly, I now regret it - I have since bought a set of '01 Limited visors, where the driver's side has the Homelink built in. So now I have six Homelink buttons, and a hole in my headliner .
I'd suggest going the visor route - it's much less work and does not require you to cut up your headliner. Actually, if you want, I have an extra set of Limited visors with the Homelink built in. If you're interested, PM me, we can probably work something out.
02-20-2018, 02:46 PM
Real Name: Jerod
Real Name: Jerod
Are there cloth homelink visors or are they all leather?
02-20-2018, 02:52 PM
Real Name: Leon
Real Name: Leon
Mine are not leather, they are the cloth/foam type. Here's a better picture:
02-20-2018, 04:30 PM
How did you wire the homelink visor to work? I am interested if it's the beige color and in good shape!
