Old 02-27-2024, 05:24 PM #1
giovannie23's Avatar
giovannie23 giovannie23 is offline
giovannie23 is on a distinguished road
97 3.4 sounds like a whined up car
Hi
My 4runner was sitting for about 2 weeks it's been cold but not to cold. When I went to start it , it now has this whine noise like a whined up car or air plane. I attached a link to the sound.
Any thoughts what it could be?
Thanks in advance!
February 27, 2024 - YouTube
giovannie23 is offline   Reply With QuoteReply With Quote
Old 02-27-2024, 06:34 PM #2
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Sounds like the power steering system to me. Is the steering stiff or notchy when turned? Does the sound go away when the truck is warmed up? When was the last time a flush and screen cleaning was done?
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 02-27-2024, 07:41 PM #3
The sound stays on from start up it does not go away when warmed up at all. It gets louder as I increase rpms. The steering feels fine. Ps fluid looks good.
I did drive thru a big puddle of mud last time I drove it before it was sitting. Not sure if mud got in somewhere
Old 02-27-2024, 09:08 PM #4
I had a rectifier in the alt go bad and it whined like a starving power steering pump.
But, the bad rectifier was obvious. My system voltage dropped with any extra load. However, it was loud.
Old 02-27-2024, 09:40 PM #5
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Originally Posted by giovannie23 View Post
Hi
Thanks in advance!
I'd suggest giving the belt system a once-over. Mud from that puddle might be messing with it. Check the belts for any slipping or wear.
Also, that noise could be coming from the alternator or one of the pulleys. Pop the hood, let the engine run, and use a mechanic's stethoscope or a long screwdriver to narrow down where it's coming from. Just be careful and listen through the handle against different components.
If the noise keeps bugging you, take a look at the water pump and idler pulleys too.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 04-24-2024, 02:45 PM #6
Just wanted to update this. It ended being the alternator!!
Thank you guys for the guidance. Swap it out for a junkyard oem and the sound is gone!!
Thanks guys!
Old 04-24-2024, 03:17 PM #7
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Thanks guys!
Interesting! It sounded a lot like mine does and I was about to ask if it happens in N and Park. Mine doesn't and I suspect the transmission.
Y2K LTD/E 262K
Old 05-01-2024, 03:35 PM #8
Mine did it no matter what gear I was in. If the engine was running that noise would be apparent. Also it did not get louder as I Reved it up. It stood the same no matter what
car , cold , noise , whine , whined
Ads with sounds?! nitrag Comments & Suggestions 1 03-21-2015 09:35 PM
Sounds bad... denvermaxd 3rd gen T4Rs 3 10-27-2013 03:19 PM
Transmission sounds different jpiccini Maintenance/Detailing 5 10-09-2011 02:23 PM
Sounds about right racedirt1 4th Gen T4Rs 3 03-20-2008 09:43 AM
