Old 02-27-2024, 09:49 PM #1
DWilliam DWilliam is offline
DWilliam is on a distinguished road
Parts list for replacing stock suspension?
I have a 2002 with a bit of a sag in the rear. I figured it’s probably time to replace the stock suspension. I don’t off road and I don’t want a lift, just replace the stock for a smooth ride. What parts do I need?
I am also running Sequoia 17s and Falken Wildpeaks.
I see rock has a Monroe suspension kit for front and back for a little over 200 bucks. Would that be decent for around town driving?
Or should I just go with Moog spring and 4 KYB gas adjust or OEM shocks?
Also, is the install pretty straightforward Or should I let my mechanic handle it?
DWilliam is offline   Reply With QuoteReply With Quote
Old 02-27-2024, 11:47 PM #2
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
I’m not a fan of either brand you listed. KYB is decent oem shock replacement. For coils maybe try:
1999-2002 Toyota 4Runner Coil Spring (Left, Right, Rear) 48231-35200 | Ourisman Toyota of Richmond Online Parts
They have the spring seat and shock listed in the “also purchased” section.
Also consider the replacing the rear will show how bad the front setup may be… so be prepared to change those out too.
I also know a lot of folks are happy with bilstein setups that stay close to oem ride heights and quality.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 02-28-2024, 09:38 AM #3
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light
jgue467's Avatar
It probably needs more than just the springs/struts, what I replaced last year and Yes it rides like a Dream as well as off-roads very well:
2 X Front Springs - Blue / Yellow 48131-35400
2 X Front Shocks 48510-39436
2 X Rear Springs - Yellow / Red 48231-35210
2 X Rear shocks 48531-80693
4 X Front Upper Top Control Arm bushings 48632-35080
2 X Front Bottom Control Arm bushings front side 48061-35040
2 X Front Bottom Control Arm bushings rear side 48061-35050
1 x LBJ Right 43330-39585
1 x LBJ Left 43340-39465
8 x LBJ bolts 90119-10933
2x LBJ protector 43346-60011
2 X Upper ball joint 43310-39016
4 X Link Bushing 90948-01003
2X Shock bushing 90389-14048
2X Front shock cushion 90948-01056
2X Front stabilizer bar bushings 48815-35100
4X Rear Stablizer bar Link bushings 48817-30020
2X Rear Stablizer Bar bushings 48815-10090
4X Rear Control Arm bushings 48702-35070
4X Rear Shock bushings 90385-19007
2X Rear Upper Control Arms 48710-35040
2X front stabilizer link 48820AD010
2X rear stabilizer link 4883035020
1 each: Steering tie rods 45046-39335, 45047-39215
2001 Limited 4WD - 350+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
Old 02-28-2024, 10:14 AM #4
96RedRunner's Avatar
Real Name: Mark
96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold
Real Name: Mark
@DWilliam Check out Timmy the Toolman's DIY vids to determine if you want to tackle job or not.
How long do you intend to keep Runner? What your budget?
The $200 kit probably good for 60k+- mi with other stuff needing replaced in the mean time.
Going with list jgue467 posted your good for 200k+ mi nothing else needing to be done
cost is substantially more.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress not stock.
2011 Audi S5 Prestige 4.2 V8 6 spd. MT not stock.
Old 02-28-2024, 01:09 PM #5
3bears 3bears is online now
Real Name: 3 Bears
Real Name: 3 Bears
nice list
however it looks like you listed the highlander springs to get that 1 inch extra lift from factory, . But for the front they are 48131-35400 blue yellow pass side, ( however you look up in some catalogs it says for both sides)
but
48131-35350 blue purple driver side ( to compensate for the extra weight of driver, battery and fuel tank all on that side.) and is listed only for left side.
2002 tundra ac v8 4wd
1969 kharmann ghia
3bears is online now   Reply With QuoteReply With Quote
Old 02-28-2024, 05:44 PM #6
jsnppp jsnppp is offline
jsnppp will become famous soon enough
Not to thread jack but I install stock OE '99 Tall springs on my 2002 4Runner and still have a bit of a drivers side lean despite 100% new everything on this list.
I see that someone specified front "Blue Yellow" for passenger side. I have my blue yellow on drivers side, and red yellow on passenger side.
Could this be the source of my lean and is there ANY formal documentation on this? I've looked and looked.
Not a trivial switch is why I ask before I go and do it...
Thanks in advance - and to the OP, yes, just replace all of it. Totally worth it.
~ Jason
2002 4Runner 4wd SR5 Sport Edition
+ many other cars
jsnppp is offline   Reply With QuoteReply With Quote
Old 03-03-2024, 01:21 PM #7
Real Name: 3 Bears
Real Name: 3 Bears
scroll down to 99 lift
3rd Gen 4Runner Lift Information and FAQ's
1969 kharmann ghia
Old 03-09-2024, 09:13 AM #8
Originally Posted by 3bears View Post
Thank you @3bears .
Dang, looks like I put them in on the wrong side...
~ Jason
+ many other cars
don’t , parts , replace , stock , suspension
Is there a complete parts list for replacing LBJs? DWilliam 3rd gen T4Rs 3 02-24-2024 03:07 PM
In need of parts list: Replacing Tans with Toyota Reman jimmyrecluse 3rd gen T4Rs 2 10-20-2021 04:20 PM
Suspension - finalize parts list snowboardwcu 4th Gen T4Rs 6 11-27-2018 10:06 PM
OEM Parts List Stock Up? 97Cruiser40th 3rd gen T4Rs 5 10-15-2018 07:26 PM
Suspension parts list - help me remember it! jham 3rd gen T4Rs 3 01-25-2016 08:30 AM
