03-07-2024, 08:18 PM
Energy Suspension Upper Control Arm bushings shot after 50k miles
Howdy all - been a while since I posted here but wanted to update on my Energy Suspension upper control arm bushings.
I’ve had a shimmy at all speeds for as long as I can remember.
When I first got the truck with 160k miles I did all front bushings. Used Whiteline for LCA and Energy Suspension for UCA.
Chasing down the shimmy I thought it was just my mud terrains being out of balance, did balancing beads and that did nothing.
More recently I noticed the shimmy became a bit of a wandering feel.
I did an inspection and noticed on the driver side with the wheel off I could grab the spindle and yank it with probably 1/8-1/4” of deflection.
Surprising to me, because I thought the poly bushings would last a lot longer. Yea I’ve done a bit of wheeling, but not much recently.
Anyway, yea they basically fell apart.
I replaced them with whitelines, which I think is superior, my LCA bushings still look great.
Also hot tip to get the old metal sleeve out - after I cut a few slots in it I was able to hammer it out with a 27mm harbor freight impact socket+ 12” extension.
Something like this - which was my attempt to use a ball joint press, which failed. So I took the press off and just hammered the extension instead and it popped right out
1997 Limited 4x4 3.4l 199k E-locker Blue Wire Mod | 255/85 r16 Maxxis Bighorn MT - LX450 9 wrap + Tokico black rear | Front: 2.5" King Coilover set @ 2" lift | True North Fab Front Bumper + Warn m8000 + Baja Designs Squadron Sport | Custom Sliders | NguyenWorks Rear Bumper + Tire Swingout
03-07-2024, 09:04 PM
I've been waiting to do mine until I got motivation. I may go with Whiteline now. Plus my Energy Suspension bushing need to use the old sleeve that you have to grind out which I was not pleased with. Why couldn't the provide a new sleeve I don't know.
03-07-2024, 09:06 PM
That’s exactly why I went whiteline for the LCA the first time around and I would do it again. You do not want to be reusing sleeves.
03-08-2024, 12:20 AM
Real Name: Devan
Real Name: Devan
Yikes! Good thing I have whitelines, those are toast
FWIW I went with UCAs from JBA which use their own special bushing and they're still doing great
03-08-2024, 01:07 AM
I used to think that ES made a good product. And, maybe they did, a long time ago. All of my recent experiences with their stuff has not been good. I would avoid them in the future. Whiteline makes reliable product as far as I can tell.
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
03-08-2024, 10:11 AM
I agree. I used ES for my Sway Bar bushings, and they were shot in 2 years....
My Whiteline LCA bushings are still rocking. My SPC X-Axis UCA bushings have a bad one within the first year. I'm about to swap to the older style bushings, will post a separate thread about that.
The 4Runner Show
03-08-2024, 05:07 PM
Well I drove it today - the new bushings did absolutely nothing for the shimmy, oh well, the search continues
03-08-2024, 05:40 PM
Real Name: Devan
Real Name: Devan
Could very well be worn out ball joints or tie rods too.
03-10-2024, 05:06 PM
I did my rear control arm bushings and after about 65,000 KM half of them were worn out. I asked Energy Suspension about why they would wear out this quick as most of my driving is on the highway and the only answer I got was to make sure they are greased well.
Get out and explore the outdoors as much as possible
03-10-2024, 05:37 PM
Real Name: 3 Bears
Real Name: 3 Bears
interesting, this late summer/ fall I am planning on replacing lots of bushings. Maybe I will stick with stock
03-11-2024, 02:20 PM
Could be. I replaced uppers and lowers when I did the front suspension at 170k miles (I’m at 225k now) - all OEM for the ball joints.
The uppers felt great when I had the UCA off so it wouldn’t be them.
I’m considering just changing the LBJ’s out again - although I should get way more than 55k miles out of them (plus about 10 Offroad trips)
When I had new tires put on at 190k (30k miles on new OEM LBJ’s) the shop said they felt a little bit of play, I didn’t believe them enough to change them, but I did buy a new set with plans to do it again just for peace of mind.
I guess I might as well give it a shot.
03-11-2024, 02:57 PM
Check your rear LCA. I had a bad bushing on the Rear Lower Control arm, and I was all over the road. Started a shimmy last year, and got worse and worse until I was practically changing lanes when I hit a decent bump!
The 4Runner Show
03-11-2024, 07:14 PM
Regarding the rear control arms and the related bushings, if you lift your 4Runner and install larger tires, you should upgrade your rear control arms and/or bushings. Same goes for the front. Get the upgraded arms, CV axles, rack and pinion bushings, etc.
The stock parts are for the stock suspension and tires.
03-13-2024, 09:01 PM
Did it have your steering wheel shaking all over the place? That’s where I feel it the most
03-14-2024, 01:30 PM
Yeah it kind of did. I thought something was wrong in the front end, i replaced the tie rods and had the alignment done with no change. I started to look at the rear, and one of them had some slight movement, so I swapped it real quick with a good used arm. Instantly fixed it. Every little bump was causing the rear end to shift, which caused the front end to veer, which caused the steering wheel to move....
The 4Runner Show
