Old 03-11-2024, 11:26 PM #1
aa010175's Avatar
aa010175 aa010175 is offline
Real Name: Dave
aa010175 is on a distinguished road
aa010175's Avatar
Real Name: Dave
Help needed for a JMD engine exchange. 2000 4Runner
I have a 2000 3.4L 5vz-fe with a bad engine. I purchased a JMD engine 5VZ-FE engine. I noted on the original engine on the left block side there is a round canister with 2 water hose that goes to it. One from the water pump and the other from the block. The JDM engine does not have it. What do I do? Thanks Dave
aa010175 is offline   Reply With QuoteReply With Quote
Old 03-12-2024, 05:59 AM #2
subzjc subzjc is online now
subzjc is on a distinguished road
Well that is the oil cooler. Is there a block-off plate where it should be?
If not I guess you would run a single piece of hose to both coolant ports.
Are there even ports for the coolant hoses to hook up?
subzjc is online now   Reply With QuoteReply With Quote
Old 03-12-2024, 10:22 AM #3
aa010175's Avatar
Real Name: Dave
aa010175's Avatar
Real Name: Dave
It’s the original engine that has this round part with 2 water hoses that run to it. The newer replacement engine does not have this part. Also the water pump is different. The old water pump has the exit that runs to the round can. The new engine does not have the exit hose. Could the new engine have done away with this part?
Old 03-12-2024, 12:40 PM #4
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Different models came with or without the oil cooler.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 03-12-2024, 02:08 PM #5
Literally EVERYTHING on the outside of the motor needs to be swapped over from your USDM 5VZ. The engine you have is from a HiAce van, and all external components are different. All accessories/pullies, intake/exhaust manifolds, oil cooler (the thing you have a question about), mounts, wiring, etc.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
5vz-fe , block , engine , jmd , water
Parts needed for 2000 Toyota 4Runner/Surf Surf4Su 3rd gen T4Rs 5 07-08-2019 05:57 PM
My son killed my 4runner, new engine needed jwillie4308 4th Gen T4Rs 17 03-09-2018 12:14 AM
2000 4runner Engine Vibrates Violently bmed250 3rd gen T4Rs 4 12-24-2014 03:36 AM
Suggestions needed for 2000 4runner LTD trout runner 3rd gen T4Rs 8 12-08-2009 08:15 AM
Brake Shoes on 2000 4Runner 'HELP NEEDED!' buckz2001 Maintenance/Detailing 1 05-15-2008 11:54 PM
