Old 03-14-2024, 08:35 AM #1
SeaCreechur SeaCreechur is offline
SeaCreechur is on a distinguished road
Possible 2000 Limited Security Sytem Issue?
I purchased another 4Runner back in December. It's a 2000 Limited 4x4 with 158,000 miles. It is not used as a daily driver. I park it at my neighbors race shop. If I take the key out and lock the doors and leave it parked for 4 or 5 days, when I go to start it, it does not want to go forward...it act like the emergency brake is on or a brake caliper is stuck.
Now, if i leave it parked in the same garage with the key left in the ignition for 4 or 5 days, it will start and drive perfectly. I will admit that I am a perfectionist and this is driving me crazy. Is there a factory fuse that can be pulled to disarm the security system? Any other items to investigate, I am stumped.
My security system is not the one with the red button.
Thanks,
Seacreechur
2000 Limited 4WD Locker 158K, Millennium Silver Weather Tech front & rear liners
2000 SR5 4WD 208K Millennium Silver
2007 Camry 41K
2015 Lexus GX 80K
SeaCreechur is offline   Reply With QuoteReply With Quote
Old 03-14-2024, 11:50 AM #2
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
The key not being in the ignition and the brake(s) sticking is not related. I would suggest someone didn't replace the shoes in the drums after an axle seal leak was fixed, but it could be a number of other things aswell,.
Malcolm99 is offline   Reply With QuoteReply With Quote
days , key , leave , parked , security
2000 4runner Limited Abs light and alarm security light question boatlee 3rd gen T4Rs 0 02-04-2021 11:31 PM
2000 Limited key fob issue riverdale21 3rd gen T4Rs 2 04-28-2018 12:06 AM
2000 3rd Gen Limited Retrofit Issue DRL Missing MTD 3rd gen T4Rs 10 07-02-2013 01:16 PM
Toyota security sytem gizmopt2002 Classic T4Rs 0 10-05-2007 01:06 AM
Anyone installed an RS3200 Security Sytem? toyota_speed Engines / Suspension / Wheels / Tires / Audio / Accessories 0 05-13-2003 03:08 PM
