Old 03-18-2024, 12:19 AM #1
stevew092984 stevew092984 is offline
stevew092984 is on a distinguished road
Clicking noise from under 4runner
I have a 98 Limited automatic and I rotated my tires the other day and now I’m getting this clicking noise from somewhere underneath the vehicle. The sound is similar to when my cv joints went bad and I replaced those and the clicking noise was gone. Here it is yet again. I sounds like it was coming from my drivers side front wheel area, but when I rolled the passenger window down, it sounds like it’s coming from that side now, so I’m kinda stumped. I’ve changed both of the front bearings as well. I’ve lifted each front tire and rotated them separately, but I don’t hear any noise coming from either. Also, the clicking will increase as my speed increases. Anyone have any idea what this noise could be?
stevew092984 is offline   Reply With QuoteReply With Quote
Old 03-18-2024, 12:03 PM #2
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Did it sound something like this? I had a similar problem a while back and couldn't figure it out for the life of me. Turned out my steering knuckle was cracked around the upper ball joint, and I only found out what it was once it broke off and left me stranded up a mountain. Not a pleasant time
Old 03-18-2024, 01:08 PM #3
It does kinda sound like that. I’m gonna check both my knuckles and see if I find anything.
Old 03-25-2024, 12:11 AM #4
So I put the tires back to their original locations and the noise went away. Can’t figure out what the heck was making that clicking sound.
Old 03-25-2024, 07:33 AM #5
Stone in the tire tread?
Old 03-25-2024, 12:53 PM #6
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Running stick on wheel weights inside the rim? Wheel weight hitting something?
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 03-26-2024, 12:25 AM #7
It wasn’t a stone in tread for sure.
Maybe it was the wheel weights, but aren’t those on the outside of the rim? Not sure what running stick means.
Old 03-26-2024, 01:58 AM #8
bernardt bernardt is offline
bernardt is on a distinguished road
I just recorded this video this morning: very frustrating not to be able to identify the source!
Why are you so weird - YouTube
The sound appear after driving for a "while" (10 minutes) and then appears (as on the video above) while on parking break...
Btw, just like you it happened right after I rotated the tires (front to back / back to front).
bernardt is offline   Reply With QuoteReply With Quote
Old 03-26-2024, 02:12 AM #9
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Slightly bent rim hitting brake caliper?
pluton is offline   Reply With QuoteReply With Quote
Old 03-26-2024, 02:11 PM #10
Everything looks pretty straight there... I removed the wheel and put it back on to make sure it was correctly screwed. Testing now.
Old 03-26-2024, 02:48 PM #11
Seemed too easy and it was. Noise is still there...
clicking , coming , front , noise , side
Clicking noise around from passenger seat and loud knocking noise when accelerating Kool-Aid Problems & Warranty Issues 3 06-17-2019 09:18 PM
2001 4Runner Limited - turned key, low pop noise, clicking Bullmom 3rd gen T4Rs 5 06-04-2018 01:34 PM
Clicking noise when in reverse 06 4RUNNER??What is it? RHINO-99 4th Gen T4Rs 20 04-15-2018 12:49 AM
clicking noise... Larry Maintenance/Detailing 24 10-01-2016 12:44 AM
2008 4Runner Won't Start, Rapid Clicking Noise blacter Problems & Warranty Issues 6 04-04-2011 10:05 AM
