Old 03-18-2024, 12:06 AM #1
enginelover enginelover is offline
enginelover is on a distinguished road
Can a worn driver side seat cushion be swapped with the almost new looking passenger?
Can a worn driver side seat cushion be swapped with the almost new looking passenger seat cushion?
How hard is it to get the seat cushions off (and back on) to test it out?
Notice how worn one edge is because of the seat belt.
Can a worn driver side seat cushion be swapped with the almost new looking passenger?-seatcushion-jpg
enginelover is offline   Reply With QuoteReply With Quote
Old 03-18-2024, 08:19 AM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I have the same question for the 4th gen, hopefully someone has tried and had success.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 03-18-2024, 09:23 AM #3
rglsr rglsr is offline
rglsr will become famous soon enough
You've got base 3rd Gen seats. On those the front seat seat bottoms are interchangable, only issue will be the passenger air bag sensor. The bottom cushions come out as a sub-assembly. Remove entire seat, plastic side panels, then the bottom cushion is removed from the seat frame via 4X bolts. I can't remember if the drivers side has the same air bag sensor, (don't think it does). Both seats also have seat belt sensors. Note this also applies to the sport seats, with larger side bolsters.
I'd look around at parts cars for a decent passenger seat, buy that and use it for your drivers side. So your passenger side doesn't look like s***. I've done this and recall zip tieing the passenger air bag sensor plug since there is no connection on the drivers side.
Seat back foam/covers can also be swapped, but much more involved. You need to pull the covers/foam off the frames.
rglsr is offline   Reply With QuoteReply With Quote
Old 03-18-2024, 04:11 PM #4
They are a direct swap L to R from a foam and cloth perspective. If you have '96-'98, there is no passenger seat sensor to worry about. If you have a '99-'00, the sensor is there but only lights the dash light (no affect to the airbag system. If you have an '01-'02, the passenger sensor does affect the airbag system, but can bet swapped with some care and spray adhesive. If you want/need to swap occupancy sensors, you will have to remove the hog rings and re-install, which is annoying but doable.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-18-2024, 04:35 PM #5
audiness's Avatar
audiness audiness is offline
audiness will become famous soon enough
audiness's Avatar
yes, i can confirm that on the 3rd gen, the bottoms are interchangeable. I grabbed a mint condition oak leather passenger bottom for my worn-out drivers seat. worked great
audiness is offline   Reply With QuoteReply With Quote
cushion , passenger , seat , swapped , worn
Driver's cloth seat cover cushion worn on 2015. Difficult to replace? nyvram 5th gen T4Rs 7 01-08-2022 04:43 PM
Swapped spare passenger seat leather over to drivers side. dogtail 3rd gen T4Rs 2 07-19-2020 11:07 AM
Driver Seat Cushion Shield Broken- DIY or Pay for Fix? Kenny Powers 5th gen T4Rs 3 05-21-2019 08:59 PM
Replacing driver seat cushion foam? ccpietscheck 5th gen T4Rs 4 03-21-2019 09:22 AM
Driver Side Seat Foam Worn (under seat cover) luke87gt 4th Gen T4Rs 3 09-24-2015 10:50 AM
