Old 03-20-2024, 09:11 AM #1
DWilliam DWilliam is offline
DWilliam is on a distinguished road
Code Help! P0301, P0171, Pending P0300
2002 with 140k. No symptoms, but it has the codes above. So far I’ve done:
Fuel pump, check valve, plugs, wires, coil on cylinder 1, timing belt, water pump, thermostat, VSV valves. Cleaned MAF sensor and throttle body.
I plan on doing the hose leak test with carb cleaner to see if I can trace a vacuum leak. Is there anything else I should look for? I assumed the misfire on 1 was a bad coil so that’s why I did the plugs, wires, and replaced that coil. Truck seems to run fine and doesn’t have any issues.
DWilliam is offline   Reply With QuoteReply With Quote
Old 03-20-2024, 10:16 AM #2
The P300 is random multiple missfires. Probably from the P171 system too lean code. Look for cracks in the rubber intake trunk.
What is your warmed up idle rpm?
What is your MAF reading with a warmed up idle?
How old is your fuel filter?
Any exhaust leaks?
Old 04-09-2024, 07:50 AM #3
Any exhaust leaks?
Getting around to updating this. MAF sensor and throttle body were cleaned. Coil replaced on cylinder 1. All new plugs and wires. Still have the codes. My reader says MAF is 0.50 lb/min and fuel rate is 0.33 gal/hr at idle
The big black hose that the MAF sensor is on is looking a little old, do you know the part number for that? The one that also hooks to the throttle body.
Anything else I can troubleshoot with this? I just want the damn CEL off. I’ve put 10 grand into this thing in less than a year.
Old 04-09-2024, 12:37 PM #4
Texmax's Avatar
Texmax Texmax is offline
Texmax is on a distinguished road
Texmax's Avatar
Did you pull the throttle body off to clean it? if yes, gasket is in upside down. If no, get a smoke machine.
99 4wd limited w/ E/locker
3" RC lift-loaded struts. Sonoran Drop diff and adjustable rear Panhard.
JBA Offroad UCA's, Pro comp Raven 16x8 wheels wrapped in 265/75/16 Gladiator Mt ,APOC INDUSTRIES Rear Trailing arms.
RETIRED USCG Aviation Mechanic/Hc130h Flight Engineer/HH65-A Flight Mech.
SEMPER PARATUS
Texmax is offline   Reply With QuoteReply With Quote
Old 04-11-2024, 06:05 PM #5
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
The big black hose that the MAF sensor is on is looking a little old, do you know the part number for that? The one that also hooks to the throttle body...
This solved my 0171 - pic of part num. attached-Luck.
2001 Limited 4WD - 349+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
Old 04-11-2024, 06:06 PM #6
jgue467's Avatar
jgue467's Avatar
Oops here it is.
Code Help! P0301, P0171, Pending P0300-new-air-intake-hose-jpg
Old 04-24-2024, 07:54 PM #7
Oops here it is.
Thanks! It’s available on Amazon for 12 bucks, or OEM is about 65 after shipping. I normally always go with OEM, but is this something I can go cheaper on? It just seems like a plastic hose.
Old 04-28-2024, 10:37 AM #8
jgue467's Avatar
jgue467's Avatar
I'd be tempted by those price differences too - I say if the amazon seller offers 100% refund and paid shipping both ways - study the seller pics comparing to yours and if it seems to match go for it. Luck.
Old 06-03-2024, 06:53 AM #9
Changed out that black plastic piece, still have the codes. Any other ideas?
What should I throw at it next? The misfire makes me think it’s an injector but I have no idea.
Also I noticed that when I try to “floor it” there’s a very noticeable hesitation and pause before any real RPM jump.
coil , leak , plugs , pump , wires
New Codes: P0300 and P0301 DWilliam 3rd gen T4Rs 7 02-19-2024 08:55 AM
Pending P0301? thegipper 3rd gen T4Rs 4 04-17-2017 07:47 PM
Help! P0300, p0301, p0302 Chandler_Ross 3rd gen T4Rs 2 06-04-2013 11:22 PM
Multi misfire P0300, P0301, P0302, P0303 kakarot 3rd gen T4Rs 3 12-24-2012 11:36 PM
4th gen 4runner V8 rough idle Misfiring p0300, p0301-p0308 aha2988 4th Gen T4Rs 9 04-10-2012 03:28 PM
