03-20-2024, 04:00 PM
![lockedlex's Avatar](https://www.toyota-4runner.org/customavatars/avatar46762_1.gif) |
2000 Transmission or Torque Converter Problems
Hi, have a 2000, 4WD V6, 2nd Gen SC put in about 195k miles. Now it's at 218k miles.
Truck's been running flawlessly over the years. About 1,500 miles ago, I noticed:
- A whine when putting my trans in Gear (123 or R), but the whine goes away in P or N.
- It's present in gear going up to 50ish, then the road/engine noise I guess cancels it out.
- Transmission shifts exactly as it did 14 years ago, there is NO slipping or other weird noises
- I did change the filter and fluid and ensured it was at the correct level at the correct temp with the engine running and the car in Park.
- When the fluid warms up, the whine is significantly reduced at idle in gear (but yet again, no whine when in Park/N). However, the whine sound is obvious again as you accelerate and drive up to 50ish.
- The whine noise does change pitch with engine speed and during shifts, but otherwise remains.
- When I changed the trans fluid and filter, the magnets looked pretty normal, there was some slight metallic glitter in the corner of the pan however.
If I didn't have an SC, I would actually say it did sound like an SC whine. However, if in Neutral or Park and I up the revs, there's no whine (so it's not the SC).
I did see in a post that it could be the TC:
If your transmission makes noise when you put it in gear and that noise goes away when you put it back in park or neutral that is your converter coming apart.
Any thoughts on what the problem is? I don't mind changing out the TC and even flexplate if needed. I'd hate to replace the trans if it's not needed, but I intend to keep the truck forever, so I don't mind the investment and piece of mind. Most importantly, I need to be sure it doesn't break down on a trip, so I'm willing to change whatever is needed for that piece of mind.
2000 Limited V6 4WD | Factory Locker | 2nd Gen SC | NGK Spark Plug Wires | AEM Boost/AFM Gauges | Scangauge II | Sonoran Steel 1.2 Lift/Washer Reservoir | AirLift Rear Airbags/Wireless Compressor | 4XInnovations Front/Rear Bumpers | Schrockworks Skid Plates/Sliders | Warn 12k LBS Winch-Synline | LED Halo Driving Lights | LED "Satoshi Cover" Lightbar | Thermal IR Cam | BFG All-Terrain KO2 | Kenwood with Sirius/Garmin Nav and Surround-View Cam | Heated Seats | Lumbar Support | Blacked out Emblems TRD Badge | Rear Diff Breather Extension | LED Taillights | LED 6k Headlights | 120V Power Socket | Flipped Hood and Fuel Release | Rear Window Switch in Cargo Area | Custom FlipBlade Key | Warm White LEDs
03-20-2024, 04:01 PM
Here are the pan pics, with the only noticeable shavings to speak of. Magnets were barely coated with particles. The pan and filter were otherwise untouched since new. Trans fluid looked great and smelled normal.
03-21-2024, 11:57 AM
![jgue467's Avatar](https://www.toyota-4runner.org/customavatars/avatar75316_1.gif) |
The TC's bearings tend to wear first causing the whine as you described - may last another year or two - depending on pocketbook or skills you could replace just that or whole thing new or used - Luck deciding
![](https://www.toyota-4runner.org/signaturepics/sigpic75316_6.gif) 2001 Limited 4WD - 349+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
03-21-2024, 09:27 PM
Interesting, didn't know that bearing wear was a thing for the TC.
I'm debating between replacing it with a new Toyota TC, for about 1k. I can do the labor myself. Or using an aftermarket one (but with all that work, it might not be worth the few hundred saved). I guess I can inspect the flexplate too to see if it needs replacement.
I'd just hate to go through all that trouble and find out whine is still there.
How difficult would it be to change the trans oil pump too while I'm in there?
03-22-2024, 07:46 AM
Have you eliminated the power steering pump as a source of the noise?
If you replace the TC replace the bushing and seal as well.
I don’t remember hearing of TC failures……with out Gen 4Runners
03-22-2024, 01:06 PM
I'll double check, but it'd be weird that it's perfectly normal in P/N but in Gear the whine is there, until it's warmed up, then the whine substantially reduces, until I drive (up to about 50mph), then you can hear it.
You'd think if it were the pump, it wouldn't be affected by whatever gear it's in?
03-22-2024, 03:03 PM
No, I forgot you said it doesn’t make the noise in P/N.
I hate to mention this…but ![2000 Transmission or Torque Converter Problems](https://s3.amazonaws.com/tapatalk-emoji/emoji12.png) did you think of a tranny flush additive and then drop the pan and do the filter over again?
Pump could be going bad or the pressure regulator…….but at your milage and you are willing to replace the pump and TC you may as well do clutch’s and bands and if the pressure regulator is resleavable or replaceable do that too……
03-22-2024, 07:49 PM
I'd be down to just buy a rebuilt tranny as well at that point. In fact, was considering it (but just have to source one). That way one and done.
BUT, I also hate to replace things that aren't broken or might not break. If shifting, etc is literally the exact same as it was 14 years ago, I wonder if it could be the tranny itself? If the sound is just from the TC, I'd be OK with only replacing that.
The problem is, is it the TC to begin with. It'd be a lot of work to find out that it's not that.
EDIT: Also, I wonder if the additive would do anything for the whining noise and I'd rather just fix it than patch it.
03-22-2024, 10:29 PM
Real Name: Skip
Real Name: Skip
Keep in mind if you get a rebuilt transmission, it will not include a new torque converter, so you will still need to buy one, so if it were me and I was doing the labor myself I'd get the new torque converter first and if it solved the issues your good to go, if not then get the rebuilt transmission.
2004 Limited V8
03-23-2024, 01:26 PM
![Endlessblockades's Avatar](https://www.toyota-4runner.org/customavatars/avatar373697_25.gif) |
Real Name: Blair
Real Name: Blair
Can't offer any technical advice but just wanted to add I've had the same symptoms with whine/growl for nearly 2 years and 20k+ miles. It may not be an emergency - it hasn't been in my case, knock on wood. I have a short clip of the sound on YT if you want to compare. Haven't done the pan filter but been running Magnefines for a few years. Tranny snake-oil treatment had no effect. I will likely be doing a salvage yard AT swap this winter.
2000 T4R AT Failing? soundclip - YouTube
03-23-2024, 09:04 PM
If you replace the TC you need to also should replace the bushing and seal.
03-25-2024, 01:40 PM
OK, that's good to know and a valid point. The TC would be in for all of a min to determine if the noise goes away. If it does, then I'm good. If it's still there, I turn the car off, then source a rebult trans and just use the new TC.
Not a bad idea!
I don't relish the idea of having to do the job twice, but since it shifts perfectly right now, it might be overkill and unnecessary to do the trans too. I'll have to think about it.
I've been looking at Timmy's vids on how he replaced the trans and it seems doable, just a lot of contortions to get it out and I'd need a trans jack. I probably wouldn't need to get it out from under the truck though, I think I'd just need to be able to slide it back a foot or two so I can swap the TC and maybe Flexplate (if needed).
03-25-2024, 04:26 PM
Real Name: Skip
Real Name: Skip
Not a bad idea!
For just R&R the torque converter I wouldn't take the transmission out from under the vehicle, as you say just roll it out of the way on the jack, just make sure you strap it securely to the jack, you only need a few inches but more would make it easier.
2004 Limited V8
03-25-2024, 04:42 PM
Great, thanks for confirming AuS! I'll probably pick up a HF trans jack that Timmy used.
I'm debating to remove the transfer case first though, just to keep the whole thing easier to balance on the trans jack, however, if I'm not trying to remove the trans from the vehicle, I wonder if it'd be possible to keep attached to the trans, then slide the whole thing back while strapped to the jack.
My worry is if I remove the TC, the whole thing might tip back or something?
Seems like the Transfer Case would just be some bolts, vacuum line, electrical connectors?
03-25-2024, 05:04 PM
Real Name: Skip
Real Name: Skip
You WILL need to support the back of the engine, otherwise the back of the engine will drop down when removing the transmission.
The transfer case you need to check it out and do what's best, it's hard for me to say what would be possible without seeing it in person, you'll have to make that call from under the truck.
2004 Limited V8
