04-02-2024, 05:05 PM
Is my seatbelt supposed to go through this thing?
2001 SR5, but I suppose other gens have a similar piece.
It is part number 73117-35011
Seems like the belt closest to the wall should be threaded through this, yet on both front belts, it does not. I can probably figure out how to do it, but it may be a pain, so want to verify before starting.
Thanks to anyone who can help.
04-03-2024, 02:01 AM
Real Name: Keith
Real Name: Keith
Perhaps add a wider photo that gives us a better idea of the geography. I can't tell what this closeup is looking at.
04-03-2024, 02:14 AM
It's the pillar between the front & rear doors, where the front seat seatbelt retractor/pretensioner is located. Shown with the plastic cover removed. In this photo, the belt is hiding it.
04-03-2024, 11:58 AM
No, its a guide that keeps the belt from rubbing there
04-03-2024, 12:30 PM
I had considered that, that it was a barrier to keep the belt from rubbing the wires/connectors that run up that pillar, but then why is it shaped with a cutout that looks exactly like a belt oughta be threaded through it?
04-05-2024, 12:33 PM
Real Name: Mark
Real Name: Mark
What the passenger side look like?
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
04-05-2024, 02:25 PM
That *is* the passenger side. But driver side looks the same.
04-05-2024, 02:45 PM
Went back and found some old pictures during my full interior removal/clean... The belts do not go through those.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
04-05-2024, 04:25 PM
Charlie, thanks very much. Isn't that weird though? That piece looks designed specifically to hold a belt. I was ready to cut a slit in it to thread the belt through easily.
04-05-2024, 04:43 PM
Real Name: Skip
Real Name: Skip
IMHO IF the belt was routed through that metal piece I would think after some time it would put undue wear on the belt!
2004 Limited V8
04-05-2024, 06:58 PM
How would the belt have gotten OUT of it during the truck's history? It still works as a belt guide in concert with the inner side of the plastic cover.
04-06-2024, 02:55 PM
Ah, this truck had a front impact in its history, so I figured the belts were replaced and maybe installed sloppily. There's lots about this truck that support that theory.....lol
04-06-2024, 02:56 PM
That piece is plastic.
04-07-2024, 11:38 AM
Real Name: Mark
Real Name: Mark
Ahh this chit in the manual.
