03-18-2014, 09:53 PM
![redstar's Avatar](https://www.toyota-4runner.org/customavatars/avatar84588_1.gif) |
Complete 2001 4Runner SR5 Bulb List
Below is a complete list of bulbs used throughout the 2001 Toyota 4Runner(there is also an attached copy).
I spent hour upon hour Googling them, then I spent some more time taking stuff apart to see for myself, then I was wrong a few times anyways ![Doh](https://www.toyota-4runner.org/images/smilies/doh.gif) .
Hopefully, you wont have to do the same!
Location Bulb Type/Number Quantity
Gauges #24 3
Instrument Lights #74 32
4-Wheel Drive Indicators Neowedge B/T4 2
Center Differential Indicator Neowedge B/T4 1
Key Ring #74 1
Hazard Button Neowedge A/T3 1
ECT/Rear Defrost Neowedge A/T3 1
Rear Defrost On 3mm LED 1
Rear Window Controls Neowedge A/T3 1
Passenger Seatbelt Indicator 5mm LED 1
Climate Controls Neowedge B/T4 3
A/C On 3mm LED 1
Air Return On 3mm LED 1
12v Outlet Ring N/A 1
Ashtray #74 1
Automatic Shifter #74 1
Glove Box #74 1
Vanity Mirrors Fuse Bulb 2
Map Lights BA9s 2
Dome Lights DE3175 2
Drivers Window Controls 3mm LED 2
Passenger Window Controls SMD LED 1
Headlights 9003/H4 2
Front Side Marker #194 2
Front Turn Signal 7440 2
Rear Turn Signal 992 2
Stop Lights 7443 2
Back-up Lights 921 2
Parking Lights #194 2
High Brake Light 921 1
Licence Plate #194 2
Reason: Copied contents of attachment into post.
03-19-2014, 11:46 AM
![jgue467's Avatar](https://www.toyota-4runner.org/customavatars/avatar75316_1.gif) |
Yes thanks for that!
Thanks for going to the trouble to document And post it here, it's saved away for later!
![](https://www.toyota-4runner.org/signaturepics/sigpic75316_6.gif) 2001 Limited 4WD - 349+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
03-19-2014, 01:15 PM
Real Name: Shane
Real Name: Shane
My HERO!! Ima use this next month for sure. Also,
@ redstar
where did you find had the majority of your replacement bulbs? I replaced my a/c controls and they work, then I replaced my rear defroster, and rear window controls and it shorts out my tail fuse...tried putting stock back in and they work, anytime I put LEDs in it shorts my tail fuse. You run into this issue?
03-19-2014, 01:41 PM
![BenK's Avatar](https://www.toyota-4runner.org/customavatars/avatar87696_1.gif) |
Holy moly! You're the man! Now I feel like I should replace every bulb in my truck though...
'01 T4R SR5, 4x4, TRD Supercharged, OME 881/90004 fronts w/ 3/4" spacers & 890/60028 rears, ToyTec 1" BL, 255/75/17 BFG MTs, Tundra 13WLs, 1.25" Spidertrax WS, Savage Offroad Sliders, Andy Mod 2.0, Deckplate Mod, Magnaflow 18"
My Build
03-19-2014, 01:55 PM
![MStudt's Avatar](https://www.toyota-4runner.org/customavatars/avatar98153_1.gif) |
official vendor
official vendor
Here's my write-up for an 01 LED dash swap. Has direct links to the bulbs I used, pictures of how to remove everything, bulb differences, and a bulb chart.
LED Dash Bulb MOD
03-19-2014, 02:17 PM
![samwalters's Avatar](https://www.toyota-4runner.org/customavatars/avatar93529_2.gif) |
Real Name: Sam
Real Name: Sam
I need this for a '97. I need to research a taillight led swap haha very nice man.
1997 4Runner Limited 4wd V6 with E-Locker
03-19-2014, 02:35 PM
@ nor_cal51501
I got them all from superbrightleds.
@ MStudt
Dude nice work! I replaced all mine in the cold and dark so I really didnt have the patience to take the pictures :S. I literally got all the same bulbs that you did. Im not very happy with how the gauges turned out though. Gonna replace them with the 3 SMD #74 bulbs if they'll fit in the same place...
Reason: typo
03-19-2014, 02:38 PM
![vm_boy's Avatar](https://www.toyota-4runner.org/customavatars/avatar105266_1.gif) |
Real Name: Chase
Real Name: Chase
Does this only apply to LEDs, or does it apply for the standard bulbs as well? I got some regular #74 bulbs for my glove box, AT shifter, and ash tray, but the bulb seemed to be just a little too big and wouldn't work. If I check the Autozone or O'Reilly's website for the glove box or AT shifter, it comes back with 2721. I have a '99 Limited so it's possible some of the model years were a little different, but I doubt it.
1999 4Runner Limited - Multi-Mode, E-Locker
Accessories: Kenwood KDC-BT755HD, Cobra 19 DX IV, Husky Liners, ProClip mount
Armor: Garrett Overland Rock Sliders
Mods: Tacoma Whip
Chronicles of Silver - Build Thread
03-19-2014, 02:55 PM
![MONTYMTB's Avatar](https://www.toyota-4runner.org/customavatars/avatar46730_1.gif) |
Real Name: Monty
Real Name: Monty
Sylvania has a lamp replacement guide here: https://www.sylvania.com/en-us/appli...s/lrgmain.aspx
It's not as in-depth as what the OP put up, but has a lot of them. It shows the 2721 for the glove box as well. superbrightleds has a cross reference chart you can use: LED Car Bulb Cross Reference | Super Bright LEDs
'99 Limited 4WD, V6, Auto
03-19-2014, 03:05 PM
Real Name: Chase
Real Name: Chase
So, yeah, Sylvania says the glove box bulb is a 2721. The same size bulb also goes into the shifter and ash tray. On the LED Cross Reference list, it says an LED 74 replaces a 74, 2721, etc. So a regular 74, I think, is slightly larger than a regular 2721, but in the LED world, the LED 74 works for all of those conditions. So I think it would be helpful if, in addition to the list provided by the OP, we also try to come up with a list for standard (non-LED) bulbs. It might also be helpful to refer to LED bulbs, as "LED 74", etc just to distinguish the LED size from the regular bulb size.
Mods: Tacoma Whip
03-19-2014, 05:30 PM
Awesome info!!!!
03-19-2014, 05:34 PM
![Brique's Avatar](https://www.toyota-4runner.org/customavatars/avatar100310_1.gif) |
Win.
03-20-2014, 09:49 AM
@ vm_boy
every single one of the bulbs was a tight fit. Try taking some pliers and compressing the contacts a tiny bit. And from what I gathered, most bulbs were the same across different model years for the 3rd gens.
03-20-2014, 01:45 PM
![Jaketino's Avatar](https://www.toyota-4runner.org/customavatars/avatar101823_1.gif) |
Real Name: Brandon Hutchens
Subbed. Thanks!
'98 Limited auto w/ factory locker 217k
ROLA roof rack with custom low profile mounts+LED lightbar, Procomp Lights on bumper, 265/75/16 Goodyear Duratracs, Finally lifted with Fabtech FTS2200 coilovers and LC 8 wraps/Tokico LC shocks
Changing rear coils to OME 861's soon because of my new NWTI rear bumper
