Old 04-02-2024, 08:58 PM #1
roscoe67 roscoe67 is offline
roscoe67 is on a distinguished road
Weathertechs with a clutch pedal - experiences?
I have a 1997 with a manual shift. Sometimes the floor mat slides under the clutch pedal and it is hard to start (the clutch start button is not sufficiently depressed). So I yank it back up and away we go. But I have worn a hole in the driver's mat and was thinking about Weathertechs. However, they look bulky and I don't want them to be in the way under the clutch pedal.
Any experiences here? Or thoughts on favorite alternatives?
Thanks!
roscoe67 is offline   Reply With QuoteReply With Quote
Old 04-02-2024, 09:21 PM #2
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
When I first got my weathertechs the pedal would catch on the edge of the mat but only when pushed in 100%. And it never stopped the pedal from returning.
I fixed the issue with a pocket knife, didn't even remove that much material. I wouldn't let such an easily fixable problem dissuade you. Even with the small amount removed they still have better coverage than anything I've seen.
I need a mat that goes up a bit since I often have snowy boots on. If you don't need that and don't want that, Husky makes one's that are cheaper
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 04-02-2024, 09:28 PM #3
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
I’ve had Weathertechs in my manual 2000 since I got it in 2015. I have over 100k miles driven with them and no issues. In fact, they were swapped from my 1996 (automatic) into the 2000 so they have a couple years in that vehicle too. They’re super durable. The hook on the factory carpet holds the driver’s mat in place so I’ve never had it catch on the clutch pedal. No experience with any other model specific floor mat brands in this platform, but I’ve always wondered how the Husky Liners compare.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 04-03-2024, 01:57 AM #4
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
I have the Weathertech generic trim-to-fit mat on my drivers side. It is anchored to the existing hook and has never moved.
pluton is offline   Reply With QuoteReply With Quote
Old 04-03-2024, 02:21 PM #5
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
I don't know about the Weathertech mats and pedal interference, but I installed a short piece of wire connecting the two poles of the clutch pedal switch years ago. I park it in neutral and use the hand brake. I never depress the clutch pedal when I start.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 04-03-2024, 02:37 PM #6
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing has a spectacular aura about GhostRing has a spectacular aura about
GhostRing's Avatar
While I would never recommend relying on only the parking brake, I absolutely think the WeatherTechs are worth it.
Make 'em fit. Fill 'em up! Best interior addition since '99 cupholders.
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 04-03-2024, 03:23 PM #7
Could be worse - the FACTORY floor mats on my '89 Camry (got a couple of NOS sets ~10 years back) interfere with the clutch pedal in that, and there is no clip on the floor either to make sure it is perfectly in place.
I trimmed a bit on the rear Weathertechs to allow better rear heater airflow even though I never use the rear heater... The fronts are great and fit perfect, though I have an auto so I can't comment on the question for the OP.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-03-2024, 04:02 PM #8
TracyNorton's Avatar
TracyNorton TracyNorton is offline
TracyNorton is on a distinguished road
I trimmed it down to clear the clutch pedal....but then it was hooking onto my boot....I almost got into accidents having my boot caught! (very tready boots)
I trimmed it way down, so they great now. I'm using a bungie cord looped around seat legs to keep it from wallering up under the pedals.
98 SR5 4x4 5sp w/ fact rear locker
ARB & 6112s business up front
CBI DSG & LC 862s/Tokicos party in the back
Lots of So African electrics strewn thruout
"If you haven't broken anything on your last trip...you ain't tryin' hard enuf"
TracyNorton is offline   Reply With QuoteReply With Quote
Old 04-04-2024, 07:44 AM #9
texadelphia texadelphia is offline
texadelphia will become famous soon enough
I haven't had any issues with the clutch pedal catching on the edge of my Weathertechs or not being able to depress the clutch fully.
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 04-05-2024, 06:52 PM #10
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
There is a way to raise the cut-in for the clutch switch. I had to do it a few years ago when I replaced the entire carpet set with the optional extra backing. I forgot exactly how I did it but I think it involved putting a furniture bumper with adhesive in exactly the right place. I can say it cured the problem totally for what is now at least five years.
Some diligent searching will lead you to the answer.
My Backyard Frame Swap
clutch , mat , pedal , start , weathertechs
Manual Swap Clutch Pedal and Clutch Master Cylinder VernySanders 3rd gen T4Rs 5 06-27-2020 11:21 PM
Help with clutch and clutch pedal ryandc 3rd gen T4Rs 13 12-30-2019 10:04 AM
Clutch engagement point on pedal after new clutch and flywheel installed 89FourRunner Classic T4Rs 8 11-18-2016 04:03 PM
Clutch Pedal and Clutch Master Cyl sggaz 3rd gen T4Rs 5 10-29-2016 02:14 PM
Clutch pedal goes to far down? ontherunner Problems & Warranty Issues 2 09-25-2010 11:18 AM
