Old 04-22-2024, 10:02 AM #16
Dizzle801 Dizzle801 is offline
Dizzle801 is on a distinguished road
I havent tried a fuel injector cleaner in a bit but ran them about every other tank for a while. I also only use premium in it. Probably a bit overkill but figure shes worth it.
Dizzle801 is offline   Reply With QuoteReply With Quote
Old 07-02-2024, 02:43 AM #17
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
So, after I said my warm misfire was Resolved, it came right back (of course it did!) and I didn't want to post another message until it really was. Yes, it was an injector. I did all 6 so I don't know if it was only the one that most frequently threw a code - others did occasionally, too, and I also got a p0300 Random code from time to time. The path to this resolution was longer and more expensive than it should have been because I tried everything 'easier'. I'm guilty of hoping for a simple solution - human nature. If I was a mechanic I would have used a more logical approach. Maybe being a computer mechanic for a couple decades clouded my mind because hardware and software are controlled by black magic sometimes and you have to try all kinds of approaches and there in no FSM. The thing now runs really really well and feels more responsive and punchy. As a result of meandering to the conclusion, I learned that I have rather good & uniform compression in all cylinders and I own a compression tester now. I ended up with new plugs, wires, coil packs, and a junkyard Igniter. As others here had said, a misfire on warm restart is probably/nearly always injector-related. Live and learn. Thanks to Timmy and Sean's injector video!!
262K - Y2K/E - Clock still works
motorwest , performance , problem , roll , start
I Got a MISFIRE P0301 Garcia9876 3rd gen T4Rs 15 02-01-2020 09:58 PM
P0301 Misfire - Fuel Pump on the Way Out? beefsix 3rd gen T4Rs 33 01-28-2020 03:13 PM
P0301 misfire, replaced "everything", still a misfire, but no CEL...what next? Heyduke 3rd gen T4Rs 7 06-25-2018 10:50 AM
Multi misfire P0300, P0301, P0302, P0303 kakarot 3rd gen T4Rs 3 12-24-2012 11:36 PM
Cylinder one misfire error code without the misfire MJW 3rd gen T4Rs 4 05-03-2012 09:07 AM
