Old 04-11-2024, 11:27 PM #1
Deej101 Deej101 is offline
Deej101 is on a distinguished road
'97 vs '01 rear hatch struts/supports
Took the hatch struts from a 97 to replace my failing 01s.
Since the 97s are from a junkyard, no way to know if they are original. But they are *much* better than my 01s. They look almost identical except instead of a single ring there are two (see pic).
The part numbers are:
3JA28-WH86 ('97 RH)
3JA29-WH86 ('97 LH)
3FC26-WH86 ('01 RH)
3FC27-WH86 ('01 LH)
Anyway, just wondering if it's a thing or just random.
'97 vs '01 rear hatch struts/supports-pxl_20240412_032954101~2-jpg
Deej101 is offline   Reply With QuoteReply With Quote
Old 04-12-2024, 11:22 AM #2
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
None of the part numbers you listed are Toyota part numbers, maybe they are KYB numbers?
From what I can decipher, the part numbers are identical for all 3rd Gens, although Toyota did make the higher force cold climate struts (that's what I have now).
I'm guessing that at 23-27 years of age, none of these are going to be original if they are holding up the tailgate at all. So you probably found a replacement set in the '97.
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 04-12-2024, 12:47 PM #3
Right, those are the numbers stamped into the metal, likely KYB# (but are they Toyota parts? Or is KYB an aftermarket brand?)
Heh, maybe so, good. Although the bushings were brittle in all of them, need to get some nylon parts to compensate.
OT: I got your hood strut kit a few years back and now that I'm finally ready to install, can't find it, lol. Must search harder.
Old 04-12-2024, 06:36 PM #4
official vendor
official vendor
Originally Posted by Deej101 View Post
Right, those are the numbers stamped into the metal, likely KYB# (but are they Toyota parts? Or is KYB an aftermarket brand?)Heh, maybe so, good. Although the bushings were brittle in all of them, need to get some nylon parts to compensate.
I believe KYB is aftermarket, at least my Toyota struts do not say KYB on them..
I hate when that happens! They're probably hiding in the same place as all the missing socks.
01s , hatch , numbers , part , pic
Sagging 3rd-gen Toyota 4-Runner rear door hatch struts lift supports enginelover 3rd gen T4Rs 20 12-17-2021 07:23 PM
Rear Hatch lift supports, which one? Hailmagnet 4th Gen T4Rs 8 10-13-2018 08:50 PM
Rear hatch supports mavrick1903 4th Gen T4Rs 1 11-02-2017 04:24 PM
4th Gen StrongArm 6107 Hatch Tailgate Lift Supports Struts bobbys For Sale: T4R Items 1 08-11-2015 06:42 PM
FS: NEW! 2 Rear Hatch Supports (shocks) BradB For Sale: T4R Items 5 08-02-2012 09:03 PM
