Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 04-12-2024, 08:53 PM #1
kong kong is offline
Member
kong is on a distinguished road
Member
Lost Compression on Cylinder 3 and 4 - repair or move on?
Car:
1998 175K miles, 2.7L Manual
Backstory:
-Check Engine light went on a year ago. P0303. Had Fuel Injectors cleaned at shop. New spark plugs.
-Check Engine light went on 6 months ago. P0303. Had Fuel Injectors cleaned again at shop.
-Check Engine light went on last week. P0303 and P0300. Lost Compression on Cylinder 3 and 4.
Questions
1. Shop claims that the cylinders were totally fine previously when I took it in. Does that check out with you all? I just want to make sure I'm not being taken advantage of here.
2. I can either drop $3K to do a "cylinder head gasket, cylinder head bolt set" repair, or I can just call it quits with the vehicle and move on. My concern is that I drop $3K now, and then next year, I drop another $3K. Should I look at getting a used motor put in? I'm open to all options and suggestions here.
FWIW, I do have sentimental value attached to this car (I've had it for 15+ years)...but I just want to know what the experts on this forum would do. I am in California in case that detail is relevant in any way.
kong is offline   Reply With QuoteReply With Quote
Old 04-12-2024, 09:17 PM #2
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Member
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
Member
To answer the question "repair or move on". I'd say definitely repair. That's assuming it's not a total rust bucket. Is this a reputable shop? I find it a little odd that the shop cleaned your injectors twice in 6 months trying to fix the same problem.
__________________
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 04-12-2024, 10:13 PM #3
gamefreakgc's Avatar
gamefreakgc gamefreakgc is offline
Elite Member
Real Name: Jerod
gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future gamefreakgc has a brilliant future
Elite Member
Real Name: Jerod
Get a print out of the compression in each cylinder. The shop just saying "compression loss" isn't helpful or sounding very honest. They are just charging $3,000 for a head gasket job which is not worth it, even for CA standards. If they won't give you more information take it to another shop for a second opinion.
Not saying this is what's wrong but I bought a 4Runner years back for $1700 that had a quote from the shop saying "needs engine replacement" and had multiple CEL codes and was leaking coolant. After changing the spark plugs, replacing the leaking water pump and a good cleaning and wax, I sold it a few months later for $4200. No codes, perfect compression. I would get a second opinion before paying $3000.
__________________
'98 4Runner SR5 - 4x4 JDM 5VZ-FE Supercharged - 249K miles.
326WHP 347TQ
AEM F/IC 6, 11 PSI, 3" Intake and 3" Exhaust
Jerod's Supercharged T[u]RD Build
gamefreakgc is offline   Reply With QuoteReply With Quote
Old 04-13-2024, 10:14 AM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Elite Member
Real Name: Tim
mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute mtbtim has a reputation beyond repute
Elite Member
mtbtim's Avatar
Real Name: Tim
Here's my take if your compression truly is bad in both those cylinders. The shop doing the job didn't properly diagnose the cause of the misfire in the first place. They GUESSED it was a fuel injector issue, when all along it was a compression issue. You don't just all of a sudden lose compression on two cylinders.
But, I agree with @gamefreakgc . Get the compression numbers from the original shop and maybe even bring it to another shop for a compression test to confirm the findings. At this point, I'd have very little trust in that original shop. The 3RZ engine is known to burn up valves because the valve lash gets too tight.
__________________
"My old man is a television repairman, he's got this ultimate set of tools. I can fix it!"
mtbtim is offline   Reply With QuoteReply With Quote
Old 04-13-2024, 11:25 AM #5
3bears 3bears is offline
Senior Member
Location: north east of Fairbank out there in the frontiers Alaska
Real Name: 3 Bears
3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold 3bears is a splendid one to behold
Senior Member
Real Name: 3 Bears
I agree with above. SO I assume you dont turn any wrenches yourself, otherwise I would do a compression and leak down test, if it is truly 2 dead holes, I would do the head gaskets etc myself
that 4 banger is a pretty easy engine to work on.
__________________
2000 SR-5 Highlander version 4:30's, factory locker , green, bought 6/21
2001 SR-5... bought 11/20..sold 6/21....
2000 SR-5 moded, lifted, e locker, other cool stuff, totaled 10/20
3bears is offline   Reply With QuoteReply With Quote
Old 04-17-2024, 07:00 AM #6
BuffaloBass BuffaloBass is offline
Member
BuffaloBass is on a distinguished road
Member
Kong, I dont know if this helps, but i had "lean cylinders" which ended up being a head gasket leak. THis is a 5VZ. My issue was that the engine had 275K on it and was running dirty ( fresh oil got black real quick) from poor cylinder seal as well.
I elected to replace the engine with a reman from gearhead ( LKQ). The cost was $3600 but i havent yet fired it up! Its is NOT an easy job to swap engine given that wiring harness, but they maybe would charge 2K for a engine R&R.
3K for cylinder head rebuild and new gasket seems reasonable actually. However, my point is that if the bottom end ( ring) sealing is poor, then you will find the next weakest link in the chain with a fresh head. BTDT.
175K is light. My 5VZ was pushing on 280k. I cant imagine your bottom end is toast yet. I may spend the 3K for a fresh head if I were you. Not unusual to have to clean up aluminum heads at 200k.
I would DO IT if the vehicle is good to go otherwise. 175K is nothing.
BuffaloBass is offline   Reply With QuoteReply With Quote
Reply
Tags
check , cylinder , engine , light , p0303
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Low Compression in one cylinder YFZsandrider 3rd gen T4Rs 22 10-11-2017 12:39 AM
1995 3.0 V6 low compression on 5th cylinder szfarc Classic T4Rs 7 01-27-2015 08:24 AM
HELP!! no compression in cylinder 2 Redt4r 3rd gen T4Rs 22 01-15-2015 02:34 PM
Best option for replacing block on 96 V6? Lost compression on one of the cylinders bigwebb83 3rd gen T4Rs 7 01-30-2011 05:49 PM
Lost Compression in Cylinder #6 fishincurt Classic T4Rs 8 07-12-2006 08:51 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
