Old 09-07-2014, 09:46 PM #1
tstoneman78 tstoneman78 is offline
tstoneman78 is on a distinguished road
Exclamation OBD II won't connect to reader
I have a 1997 Toyota 4runner. I wrecked it a couple of years ago. Since I have wrecked it, the OBD II will not connect to any readers. I have been trying to get it inspected so that I can renew the tags on it. I live in NC so they will not renew my tags without an inspection. I have replaced the OBD II on it with a brand new one and it will not connect to the reader either. Does anyone have any idea what could be causing it? The truck runs great, I just can't get it to connect to the NC inspection computers or any readers.
tstoneman78 is offline   Reply With QuoteReply With Quote
Old 09-07-2014, 09:58 PM #2
sterbenlicht's Avatar
sterbenlicht sterbenlicht is offline
sterbenlicht is on a distinguished road
Did you check the OBD fuse under the hood? 7.5A I believe.
2001 SR5 Sport 4WD
sterbenlicht is offline   Reply With QuoteReply With Quote
Old 09-08-2014, 07:31 AM #3
habanero's Avatar
habanero habanero is offline
Real Name: Throws like a girl
habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light
habanero's Avatar
And if that's not it try
OBD II not talking to state's computer... - YotaTech Forums
Some wiring info to help test the connector. In my case a jumper wire from pin 5 did the trick.
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R View Post
I know this is a weird ass question but do you shave your legs or something?
habanero is offline   Reply With QuoteReply With Quote
Old 10-05-2014, 12:23 PM #4
Smile Thanks.
I have checked the fuses. Everything is good. I checked out the forum and I think I will try a couple of the ideas that were posted there. Thank you for your help.
Old 04-21-2024, 02:53 PM #5
HOGCAT HOGCAT is offline
HOGCAT is on a distinguished road
my code reader will not work either. Neighbor has one alsp, but will not work on my vehicle. Plus will not idle or run below 2000 rpm. Plus the IAC vibrates about 50 times a second. I am sure it's not the Crank and cam sensor as the have been changed. Plus unplugging the IAC it makes no difference at all.
HOGCAT is offline   Reply With QuoteReply With Quote
Old 04-21-2024, 07:14 PM #6
If you have a volt meter research the pin on the OBD2 connector and ensure you have battery voltage on it.
What OBD2 tester are you using?
If you have more than one vehicle does it talk to your other vehicle?
obd ii
Best Code reader for 3rd gens Duhockey 3rd gen T4Rs 75 06-08-2018 03:21 PM
OBD II reader (pics) toy4rner 4th Gen T4Rs 0 02-21-2010 07:54 PM
Code Reader Input on '05 thefatcat 4th Gen T4Rs 3 02-23-2009 07:37 PM
ODB II reader inetquestion 4th Gen T4Rs 2 07-17-2008 08:55 AM
