Old 05-06-2024, 01:10 PM #1
mendozer mendozer is offline
mendozer is on a distinguished road
Roof leak?
I just noticed the roof liner above the driver side wet and extending toward the back seat but no obvious leak. I tried uploading photos but it wouldn't work. Nothing looks weird at the roof rack or the sunroof
mendozer is offline   Reply With QuoteReply With Quote
Old 05-06-2024, 01:43 PM #2
Offroad Alliance Offroad Alliance is offline
official vendor
Offroad Alliance is on a distinguished road
official vendor
check the drain for the sunroof. get a cup of water and open the sunroof, pour a little down the sides where the drains are and see if it backs up or causes the inside to drip/leak. Those commonly get clogged with debris and will cause leaks (although usually down in the floors not the headliner). If its not that, you could back the roof rack bolts out and put some sealant on those bolts and retorque them down.
Offroad Alliance is offline   Reply With QuoteReply With Quote
Old 05-06-2024, 03:54 PM #3
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
I had a small leak in my sunroof and it ended up being the black plastic surround/gasket had cracked right in the front above the controls.
I "temporarily" foil taped it and flex sealed over that because of days of rain still to come and it hasn't leaked since so it's now a permanent fix
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 05-06-2024, 04:23 PM #4
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
Lift the floor mat on the driver's side. The carpet beneath may well be wet, also. Mine is. I just cleaned my drains last week. I'm waiting for a dry spell to pull the seats and center console and remove the carpeting for pressure washing on the driveway. I'll probably have some rust to address when I'm under there, as well.
While you're at it, clean up the rubber sealing surface on the perimeter of the sunroof along with the painted surface of the roof where the seal mates. Mine took some scrubbing with a microfiber cloth and window cleaner spray. It was quite grungy.
mtbtim has a great video showing how to check and clear the drains.
https://www.youtube.com/watch?v=qalXo4etX3Q&t=6s
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 05-07-2024, 08:05 AM #5
Brutus H Brutus H is offline
Brutus H is on a distinguished road
This is where my problem is and I just wasn't able to fix it correctly, so I sealed it with some caulk. Hate that I can't use my sunroof currently.
Brutus H is offline   Reply With QuoteReply With Quote
Old 05-07-2024, 09:59 PM #6
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Leaks can sometimes come from other spots like door seals or the windshield. Maybe, check those areas. Also, if the sunroof drainage channels are blocked, water can find its way into unexpected places. Have you cleared them out lately?
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 05-09-2024, 01:41 AM #7
I didn't know checking these drains was even a thing. I've owned it since 2015 and never done that. i'll check when i get a chance. No floor mat water, only roof liner.
and i don't have factory roof racks, i riveted my own rails for rhino rack
Old 05-09-2024, 01:04 PM #8
Making sure the drains are clear is a thing with EVERY sunroof vehicle. ALL sunroofs leak, at least a bit - the drains are required to be clear or you will have problems.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-09-2024, 04:02 PM #9
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
I had the same problem as OP and the solution was to remove the roof rails or rack, and apply silicone to every screw and into the hole threads before putting it back. It was leaking from the roof screws and it was leaking a lot during heavy rain.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 05-11-2024, 05:44 PM #10
i riveted the rails down to the roof and siliconed it when i put it on 7 yrs ago. I don't think those rivets are coming out.
leak , noticed , rack , roof , weird
Roof Leak cpayne5 4th Gen T4Rs 18 12-17-2023 10:53 PM
Roof Leak Lexington 5th gen T4Rs 13 03-16-2023 10:46 AM
Roof leak. Need help! 4Hammer 5th gen T4Rs 15 12-14-2018 12:45 PM
Sun roof leak Dezerts10 3rd gen T4Rs 0 08-14-2017 10:13 AM
Roof leak? Dirtbikekid12 4th Gen T4Rs 0 02-07-2014 01:37 AM
