Old 05-09-2024, 05:04 PM #16
trashboy trashboy is offline
trashboy is on a distinguished road
as an update, i took the truck for a drive and didnt feel any difference in heat between the two front wheels and two rear wheels, so figured it was drums.
found a thread that said a good check is to pull the ebrake while driving so all the braking is done by the rear, and see if theres a vibration/pull. doing so resulted in a pretty noticeable vibration, so i ended up getting the drums replaced. from my initial short drive, it seems like the problem is fixed, along with much better brake feel.
i think the rears needed adjusted and probably just needed to be replaced anyways. truck has 320k miles on it, don't know if theyre original drums but the tech noted that the drum seemed "a little too big" (not sure what that even means) but im happy for now
trashboy is offline   Reply With QuoteReply With Quote
Old 05-09-2024, 06:39 PM #17
Most Drums have a ID range stamped on the drum somewhere.
If the ID exceeds the number you’re suppose to replace it
That may be what he was referring to
braking , lower , normal , toyota , vibration
Pulling to the drivers side when braking thewetdog 4th Gen T4Rs 3 02-27-2018 08:50 PM
pulling while braking 03V84R 4th Gen T4Rs 4 10-10-2017 08:06 PM
She pulls to the left when braking harder, but not when normal braking... Goyo 3rd gen T4Rs 6 11-30-2012 08:21 PM
engine pulling/braking HossBoss 4th Gen T4Rs 3 06-02-2011 05:02 PM
Pulling to left and shimmy while braking? dat5574 Problems & Warranty Issues 6 05-17-2011 10:40 PM
