Old 05-07-2024, 05:43 PM #1
trashboy trashboy is offline
trashboy is on a distinguished road
vibration/pulling to left side when braking
hey guys, i've been trying to track down this issue and get it resolved for the better part of 2 months now. when braking, there is a noticeable vibration in the pedal/body (not in the steering wheel), and the car pulls to the left. it is more pronounced at higher speeds. i have also noticed that when i'm crawling to a stop (10 mph and lower), the truck is almost pulsating forward, as if someone was releasing brake pressure and re-engaging ever so slightly.
things i have performed trying to track down this issue and other related vibrations.
- greasing ujoints
- lower control arm bushings (poly, sonoran steel)
- upper control arm (jba)
- upper ball joints (toyota)
- lower ball joints (toyota)
- outer tie rod (napa)
- inner tie rod (toyota)
- rack and pinion (new toyota, not remanned/junkyard)
- new tires (at4)
- balancing
- alignment (3 times)
- pads and rotors (2 times, napa premium)
- retorquing all suspension components (discovered LCA bolts were very loose after an alignment, which greatly improved vibration upon braking)
- wheel bearings (both sides)
- brake flush
i'm at a loss for what could be causing this now. am i chasing something thats considered normal on these trucks? i definitely wouldn't consider this normal behavior, but i also have never driven a 20+ year old vehicle.
trashboy is offline   Reply With QuoteReply With Quote
Old 05-07-2024, 06:53 PM #2
You spent a lot of time on the front... what about the rear - brakes in particular. I would guess you have a leaking rear axle seal and one side has contaminated brakes in the back.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-07-2024, 09:34 PM #3
Yep, people always throw rocks at the pads/rotors and totally forget about their 250,000 brake drums.
But, with regards to the pads and rotors….did you do the pad bedding in procedure?
I drive city to work and it’s 25 miles. Every once in a while my pedal will pulse doing those slower stops and I will go out and do some aggressive braking and the pulse goes away.
I’ve only used Napa premium coated rotors and their ceramic pads for a long, long time…..
Old 05-07-2024, 09:42 PM #4
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Have you checked the brake calipers? Problems with caliper pistons or slide pins can make your brakes work unevenly, causing these issues.
Also, I’d check the brake lines for wear or kinks that could affect fluid flow. Since you've already flushed the brakes, make sure all the hydraulic parts are working correctly.
Plus, inspect the suspension bushings, especially the ones in the control arms and sway bars.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 05-07-2024, 09:59 PM #5
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I'm guessing you have one or more sticking/seizing caliper more likely on the left side.
Get or borrow one of those infrared thermometer, drive it around for a while, then check the temperature of each rotor and caliper, if one is much hotter than the others that caliper is sticking.
2004 Limited V8
Old 05-07-2024, 11:34 PM #6
thanks for the ideas guys. i did consider a stuck brake caliper or the drums but didn't feel any sort of stiffness when pushing the pistons back when doing the brake job, and have heard the drums can last a very long time.
i have 320k miles on the truck, so its definitely possible that it might be the drums, but i talked to a shop who said it was most likely other things, so i didn't pay it any attention.
Old 05-07-2024, 11:37 PM #7
i did do the bedding procedure but wasnt able to get as aggressive stops as i would have liked. ill go out on an empty street and give her a couple strong stops and see if that helps.
Old 05-08-2024, 07:54 AM #8
Hard 60 to 5mph then drive somemore don’t come to a complete stop….
Old 05-08-2024, 09:21 AM #9
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
I would check the temperature of each wheel as AuSeeker said. Drive it around for a good bit and then place your hand on each wheel. The front two should be the same temp and the back two should be the same. If one is hotter than the rest then that is your problem wheel. I suspect either front caliper seizing or rear axle leak
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 05-08-2024, 02:12 PM #10
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy has a spectacular aura about Wedgy has a spectacular aura about
Wedgy's Avatar
I had a similar issue, replaced the front pads and calipers, bleed the brakes, etc. and still had the pull. Took the front shocks off and could see movement in one of the control arm bushings I had recently replaced. Got a bad one I guess.
Wedgy is offline   Reply With QuoteReply With Quote
Old 05-08-2024, 02:52 PM #11
can you share if yours was the lower control arm or upper?
Old 05-08-2024, 03:10 PM #12
Wedgy's Avatar
Wedgy's Avatar
Mine was a lower. I had tried prying on it with a pry bar and got no movement but in the air with the shock off it was easy to see the movement.
It was frustrating because I had done everything as you including rear axle seals and new drums, brake cylinders, etc. complete front end and also a new steering rack(old one leaked like crazy) and still had the issue. Two shops found no issue either.
Old 05-08-2024, 03:21 PM #13
you say you had a pull to one side.. weas the bad bushing on the side that was pulling, or opposite? i would assume the same side as the pull
Old 05-08-2024, 03:42 PM #14
Wedgy's Avatar
Wedgy's Avatar
Lower right rear bushing and it pulled to the right, scary if you hit the brakes hard so I quit driving it except to test it.
Old 05-08-2024, 03:57 PM #15
When my lower control arm bushing on the drivers side failed I’d be driving down the road and the rig would veer left or right with the steering wheel strait.
Talk about a butt pucker feeling…..
braking , lower , normal , toyota , vibration
Pulling to the drivers side when braking thewetdog 4th Gen T4Rs 3 02-27-2018 08:50 PM
pulling while braking 03V84R 4th Gen T4Rs 4 10-10-2017 08:06 PM
She pulls to the left when braking harder, but not when normal braking... Goyo 3rd gen T4Rs 6 11-30-2012 08:21 PM
engine pulling/braking HossBoss 4th Gen T4Rs 3 06-02-2011 05:02 PM
Pulling to left and shimmy while braking? dat5574 Problems & Warranty Issues 6 05-17-2011 10:40 PM
