Old 05-08-2024, 08:51 AM #1
Mr. Goodkat's Avatar
Mr. Goodkat Mr. Goodkat is offline
Mr. Goodkat is on a distinguished road
Is this the PID is use for my 2000 trans temp?
I want to to add the trans temp PID to my Torque Pro app using my S23 Plus.
Is this the process I use for my 3rd gen? I found this equation and process but its for a 4th gen so I'm not sure if its what I use.
Torque App - working formula for tranny temp
Hit the menu button again, and choose "Add custom PID"
Hit "OK"
Under the first item called "OBD2 Mode and PID" enter "21d9"
Under "long name" choose whatever you want. I typed in "Trans Custom"
Under "short name" choose whatever you want. I typed in "Trans"
Under "minimum value" leave it at "0" or type in "0"
Under "maximum value" type in "300"
Under "scale factor" leave it as "x1" or type in "x1"
Under "unit type" type in "F"
Here's the tricky part - under "equation" type this in, EXACTLY, without any spaces:
(((((G*256)+H)*(7/100))-400)/10)
That's *five* parentheses at the beginning! Just be sure that there are six total parentheses facing to the right, and six total to the left.
Leave the rest blank and hit "OK"
Now when you want to add a gauge to the display, you should see "Trans custom" or "Trans" or whatever you named it at the beginning. The darn thing works!!!!!
For reference, I have a 2008 V6, but I will assume the PID's are the same for others in this generation of 4Runners.
2000 Limited natural white w/rear locker 204,xxx
Eibach Pro-Truck lift kit, Geolandar AT 275/70R16, debadged
2001 Camry LE V6 113,000 antique sage metallic, runs like new
Mr. Goodkat is offline   Reply With QuoteReply With Quote
Old 05-08-2024, 01:15 PM #2
The 3rd gen and 4th gen PIDs are different, I believe. I only have the information for a Scangauge, which uses a different format for the PIDs and math.
Here's the info, if you have a way to translate that into what Torque needs, use this:
TXD: 686AF101B4
RXF: 044105B40000
RXD: 2808
MTH: 00090005FFD8
The math line (last one) is multiply by 9, divide by 5 and subtract 40. Subtracting 40 is needed since the "0" point of the reported data is is actually -40* F/C (the same temp). 9/5 is the ratio between *F and *C.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-12-2024, 10:55 PM #3
Robb235's Avatar
Robb235 Robb235 is offline
Real Name: Robert
Robb235 is on a distinguished road
Robb235's Avatar
Real Name: Robert
This is the PID information you’re looking for:
ModeandPID: 01B4
Formula: A*(9/5)-40
Min Value: 0
Max Value: 300 (or whatever you want)
Unit: °F
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
Robb235 is offline   Reply With QuoteReply With Quote
Old 05-14-2024, 12:02 PM #4
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
so are you all saying the stock torque pro is not accurate....that I have to type in some kind of formula.
I just picked the trans temp from a list and having been using that for years.
Old 05-14-2024, 01:32 PM #5
The coolant temp, air intake temp and trans temp should all match closely on a COLD start (within a few *F). If not, then something is wrong. Modern ECUs actually do this check internally and report errors if they don't match...
Old 05-14-2024, 02:32 PM #6
Robb235's Avatar
Real Name: Robert
Robb235's Avatar
Real Name: Robert
I have no idea if you're Torque Pro app is correct or not. If it's returning a value that makes sense, then it's probably correct. Easiest way to find out would be to find out what PID it's querying, and what formula it is applying, and see if it matches up to what I posted.
custom , leave , pid , trans , type
Scangauge for trans temp on sealed trans flush conclusion? 99Runnr 4th Gen T4Rs 7 01-06-2018 07:07 PM
2000 4Runner Limited 2WD -trans leak near rear of trans rzgkane 3rd gen T4Rs 1 01-05-2018 06:23 PM
Scangauge II for trans temp? Tdaz250 3rd gen T4Rs 12 10-03-2016 09:26 PM
trans temp gauge the great him 3rd gen T4Rs 55 08-05-2016 06:22 PM
Trans temp slides 3rd gen T4Rs 26 10-14-2014 12:12 AM
