I want to to add the trans temp PID to my Torque Pro app using my S23 Plus.
Is this the process I use for my 3rd gen? I found this equation and process but its for a 4th gen so I'm not sure if its what I use.
Torque App - working formula for tranny temp
Hit the menu button again, and choose "Add custom PID"
Hit "OK"
Under the first item called "OBD2 Mode and PID" enter "21d9"
Under "long name" choose whatever you want. I typed in "Trans Custom"
Under "short name" choose whatever you want. I typed in "Trans"
Under "minimum value" leave it at "0" or type in "0"
Under "maximum value" type in "300"
Under "scale factor" leave it as "x1" or type in "x1"
Under "unit type" type in "F"
Here's the tricky part - under "equation" type this in, EXACTLY, without any spaces:
(((((G*256)+H)*(7/100))-400)/10)
That's *five* parentheses at the beginning! Just be sure that there are six total parentheses facing to the right, and six total to the left.
Leave the rest blank and hit "OK"
Now when you want to add a gauge to the display, you should see "Trans custom" or "Trans" or whatever you named it at the beginning. The darn thing works!!!!!
For reference, I have a 2008 V6, but I will assume the PID's are the same for others in this generation of 4Runners.
