05-12-2024, 12:27 PM
AC Question
I have an 02 4Runner that has some intermittent ac issues. When it’s working, it cools great. However, sometimes it won’t cool at all. Usually we can get it to work by turning everything off and on a few times. I am assuming the compressor is this issue, but not 100% sure. I wanted to see if I could confirm that’s the issue and if I replaced the compressor, wha else should I replace?
05-12-2024, 02:12 PM
Spin the compressor it should spin freely. Check the resistance at the electrical connector it should be between 2,5 to 5 ohms. You can also energize the connector to see if it clicks.
Low refrigerant could also be an issue. Check ac relay etc.
The sight glass diagnosis fsm
05-12-2024, 07:13 PM
What are your outside temps?
Do you have manual or automatic climate control?
05-12-2024, 08:53 PM
Outside temps are in the 70's. Manual climate control.
05-12-2024, 08:55 PM
Thank you. I will try these things out.
05-13-2024, 04:50 PM
Real Name: Mark
Real Name: Mark
@ jwkiss0
Your symptoms fall into the realm of filter/dryer end of life.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
05-13-2024, 06:36 PM
Originally Posted by 96RedRunner
@ jwkiss0
What does the filter/drier do? Is any way to test it?
05-13-2024, 06:42 PM
@ jwkiss0
05-13-2024, 11:44 PM
Real Name: Lukas Weber
I’d suggest first checking the refrigerant levels and the condition of the AC belts. Also, check the AC clutch relay and the pressure switches.
Look for leaks, especially around the compressor shaft seal and connections.
Besides the compressor replacement, I’d recommend changing the receiver-dryer or accumulator and O-rings to protect the new compressor from moisture and debris. Also, you can replace the orifice tube or expansion valve (depending on your system) and flush the whole system to remove any built-up contaminants.
05-14-2024, 08:15 AM
Real Name: Mark
Real Name: Mark
No easy answer to T/S your problem, best advice download FSM start reading at AC-1.
05-27-2024, 10:52 AM
I used this chart and didn’t come up with anything. I took a few pictures and a video but can’t figure out how to post them. I was low on refrigerant again so I have a leak somewhere. Any suggestions on how to diagnose the leak? I use the AC Pro refrigerant to fill it up. Do they make one with dye to check for leaks? Is there a better solution?
05-27-2024, 11:44 AM
Seems to me that if you can get it to work by cycling through control settings, it kinda means the refrigerant circuit is OK (compressor, drier, evaporator, etc). It points to a problem of activation.
The control unit itself? Switch/solenoid for the compressor clutch? I just fixed issues with the HVAC control valve activation cable where the AC worked, but the heater would still be running.
Replacing cable for heater control valve
Edit: Just saw your post above. I hope you find the leak.
05-27-2024, 12:47 PM
AC Pro does make one with dye.
There's also other R134a with dye available probably cheaper.
If you use the dye you can buy a UV flashlight which might help finding the leak.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
05-28-2024, 09:34 AM
Does turning on the AC engage the compressor clutch, if no you likely have a leak, low refrigerant or bad pressure switch/clutch/wiring, test pressure switch buy jumping terminals, does ac clutch engage now, if yes you have a leak, usually it is the Evaporator under the dash, if so you will also need a proportioning valve and a receiver dryer, some pagg oil and 134a refrigerant after the system has been evacuated and dried under vacuum. could also be the condenser infront of the Rad among many other orings and schrader valves.
05-30-2024, 08:10 AM
If the system is capable of "cools great" then maybe the issue is the dash control unit - they flake out rather often - guy on ebay repairs for 2 bills - you must send yours in (he repairs poor soldering in known places).
2001 Limited 4WD - 349+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
