Old 05-19-2024, 12:35 PM #1
beatnik_glory beatnik_glory is offline
beatnik_glory is on a distinguished road
Rear Seat Permanent Removal for Overlanding
I am thinking of permanently removing the Rear Seats on my Gen 3 to be able to create a flat cargo deck. I would probably cut a piece of 3/4" Plywood for the deck and add some L-channel to be able to secure gear.
My rear seats are in the folded down position 99% of the time. but I would want this modification to be reversible.
Anyone have any advise and pics they could share?
Thanks.
Beatnik
beatnik_glory is offline   Reply With QuoteReply With Quote
Old 05-21-2024, 09:48 AM #2
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
just remove the seat bottoms and head rests, then it folds flat and gives you the head room to sleep, 4 bolts and easy to reinstall, you could even install studs and tap the correct sized SAE wing nut for the metric thread making it a tooless removal, or weld half a washer to the existing bolt.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 05-21-2024, 06:52 PM #3
Thanks.
Beatnik
Use the 'advanced search' in the stickies at the top of the forum subsection (google search with site:https://www.toyota-4runner.org/3rd-gen-t4rs/ as one of the terms) and search for sleeping platform builds. Plenty of options...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-25-2024, 11:53 PM #4
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
I’d suggest using bolts instead of permanent welding or adhesive to make it reversible. This way, you can easily remove the plywood and L-channel when needed.
weberlukas74 is offline   Reply With QuoteReply With Quote
99% , deck , rear , seats , time
Rear seat removal! Help sinks88 5th gen T4Rs 12 10-18-2020 04:22 PM
2012 T4R LTE Rear Seat Removal Michael Siener 5th gen T4Rs 3 09-10-2020 12:37 PM
GX 460 rear seat removal fraggy Lexus GX470/460 7 02-22-2015 07:09 PM
Removal - RSES - Rear Seat Entertainment System sctazmon 4th Gen T4Rs 4 09-17-2012 10:30 AM
Rear upper panel removal to fix seat belt? skategoat 4th Gen T4Rs 2 02-08-2010 10:26 AM
