Old 05-26-2024, 12:02 AM #16
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a jewel in the rough 2TH4IST is a jewel in the rough 2TH4IST is a jewel in the rough
2TH4IST's Avatar
Originally Posted by Nathan97Limmited View Post
But I thought the bearing does not sit in there? Like it just sits in the housing and and on the axle and the ABS ring just spins in that space?
Holy smokes, I need to be more careful posting stuff when I'm beat tired. Sorry you are correct, the abs tone ring resides in the void. I'll go back and correct my post so if anyone comes across it they won't be confused.
The bearing sits only in the cup. So either the cup is the issue, or there is an issue with the retainers and abs tone ring or the c clip isn't seated or an out of spec bearing.
On the axle housing side of things, do the bolt holes or alignment flange show any signs of damage?
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 05-26-2024, 12:04 AM #17
2TH4IST's Avatar
2TH4IST's Avatar
https://www.toyota-4runner.org/attac...ay-housing-jpg
Is this the piece to measure? its the the one I ordered.
Yes measure that.
Old 06-04-2024, 03:40 PM #18
Nathan97Limmited Nathan97Limmited is offline
Nathan97Limmited is on a distinguished road
Alright so I may have been lazy and just replaced the bearing housing with a new one. NO LUCK, still have the exact same play. At this point I've gone through 2 axles 3 or 4 bearings and 2 housings. I am stumped. Thoughts Anyone? Could the only thing that it could be is the 3rd member / Rear Diff? I'll Add a video of the play when I get a chance.
Nathan97Limmited is offline   Reply With QuoteReply With Quote
Old 06-05-2024, 09:48 PM #19
2TH4IST's Avatar
2TH4IST's Avatar
Holy smokes. I was hoping for a good result from your replacement parts. I checked both of mine yesterday as I'm doing a rear disc brake swap. Zero play.
I'm stumped as well. Maybe could be a bal lot/batch of wheel bearings? Did you get the bearings from Toyota or ebay/amazon? If it's the later could be low quality out of spec bearings.
Was there any damage on the axle when you pressed off the original bearing? Did you cut or press off the retaining ring/abs tone ring?
Did you torque the 4 bolts to 48 ftlbs?
Old 06-06-2024, 09:30 AM #20
Hello! Two bearings from NAPA one Bearing from Toyota one bearing from Rock Auto but its the same one as the Toyota. Pressed off the bearing and the axles seems fine to me. It seems this stuff always happens to me!
Old 06-07-2024, 12:05 PM #21
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
idk like timmy said they have some play even new. When I removed my axles to replace my bearing and seals i saw a little rock in the old bearing so thought it was bad but after getting the new one in it had the same movement. Not a ton but it will move if you grab the axle and hold end rocking back and forth
Sounds like your over thinking it. Your not getting bad bearings cause you tried mulitiples. Either its fine and your over thinking or something else was missed and your over looking it.
The bearing isnt really pressed im like you saw in timmy video, it can just kinda fall out if turned upside down.
You need to post a video so we can actully see what your talking about.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 06-10-2024, 04:56 PM #22
You cant really see it but you can defiantly hear it and the other side does not do it. I'll try to take another video at a better angle when i get a chance. feeling defeated on this one. I just been driving it around as its my daily driver. Thanks for all the reply's!
3gen 4runner wheel play - YouTube
Old 07-14-2024, 12:46 PM #23
mark3406e mark3406e is offline
mark3406e is on a distinguished road
Have you got this figured out yet? Iím having the exact same issue!
mark3406e is offline   Reply With QuoteReply With Quote
bearing , bunch , play , side , wheel
Wheel bearing replaced still play? jman11788 3rd gen T4Rs 31 04-27-2023 08:14 PM
Rear wheel bearing play rcrick 3rd gen T4Rs 11 11-21-2014 12:29 AM
Does my wheel bearing need to be replaced? (video) uncleslam23 3rd gen T4Rs 16 08-01-2014 04:50 PM
Wheel bearing replaced 3 times in less than a year??? fuel-n-fire 4th Gen T4Rs 11 04-22-2014 11:03 PM
excessive wheel play.. already replaced everything Jc12 3rd gen T4Rs 2 09-07-2013 03:56 PM
