Old 05-22-2024, 03:39 PM #1
5horizonsrr 5horizonsrr is offline
5horizonsrr is on a distinguished road
Rear Suspension on 2WD Daily - Anything Smart Beyond Shocks/Springs While I'm at it?
Hi all,
My wife's daily is a 2001 2WD, stock suspension since she is quite short and it is 2WD anyways. We are starting to see a little rear sag, and the shocks are prehistoric anyhow, so its time to replace the lot.
I'm planning on using OEM springs (no good/quality aftermarket at stock height?) and probably KYBs for shocks
After a little searching I thought I'd ask since I didn't see much in the way of pro tips for a stock-replacement job like this: Are there any small/rubber/related components I should swap in the process, or general "while you are in there" jobs I should be doing while I'm at it for efficiency- rear suspension or in that geographical area of the car?
Thank in advance for any insights!
2001 RWD SE
5horizonsrr is offline   Reply With QuoteReply With Quote
Old 05-22-2024, 06:37 PM #2
New OEM '99 talls in the rear (that can then sag up to 1" and still look good) will be fine, as would correct/matching year rear springs (that would last another 20+ years, just like the current set).
New front top-hats and stem bushings will be a good idea.
New front (OEM only!) lower ball joints are highly recommended - that is the only catastrophic failure point in the gen3 4Runner, pretty much.
All the bushings, front and rear will be old/shot - which causes uncomfortable but not dangerous suspension harshness. Whether you want to change them is up to you.
New shocks+rear springs+front lower ball joints will get you 85% of the way there - whether you want to do the last 15% is up to you...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-01-2024, 03:25 PM #3
Thanks @phattyduck ! Apologies for the delay but work inhaled me the last few weeks and I haven't had a chance to get this moving.
Doing rear only for now, then will move to front the next free weekend.
I'm going to order KYBs, is it worth the $20 for an energy suspension (or similar) poly bushing kit?
2001 RWD SE
Old 06-01-2024, 04:21 PM #4
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Rubber bushings are noticeably smoother and have a better ride than poly bushings. I had poly in the rear link bars for a few years and went back to rubber and am glad I did. I still have poly in the panhard bar but that doesn't really effect the ride and front lower control arms that I still want to change back to rubber.
Also look at the sway bar bushings and endings while you are in that area
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old Yesterday, 12:45 PM #5
Just a note to say thanks everyone! Between your tips, the FSM, and the Timmy video this was far easier than I was expecting. Total time for the rear including lots of fidgeting and cleanup was 3 hours. Those top nuts were a good 45 minutes of that
I went KYB and OEM springs, its my wifes daily and Im trying so hard not to open pandoras box with mods that will turn it into a project truck for me
I did notice my stabilizer bar bushings (the ones connecting the vertical to the horizontal bars) are totally destroyed. Will need to order those, the rest looked surprisingly good down there for 185K miles!
Thanks again guys- you are always a huge help!
2001 RWD SE
2wd , daily , rear , shocks , suspension
Rear suspension bushings-Daily Driver Sarki 3rd gen T4Rs 42 01-14-2022 11:01 PM
WTS: 4th Gen OEM Suspension (Shocks and Springs) Bumbo For Sale: Suspension/Wheels/Tires 0 07-04-2020 10:08 PM
4th Gen Suspension - OEM Springs & Shocks Bumbo For Sale: Suspension/Wheels/Tires 1 01-15-2020 11:05 AM
02 SR5 Sport - Best springs/shocks for Daily Driver Sarki 3rd gen T4Rs 13 06-20-2019 11:22 PM
FS: 5th Gen (2016 Trail) Front Coilover Shocks & Rear Shocks/Springs $175, West LA rgoodman00 For Sale: Suspension/Wheels/Tires 3 01-28-2016 03:22 PM
