Originally Posted by D'arce
Well yes you can feel the groove ever so slightly...I was thinking that maybe the new seal is in a slightly different spot and would have a different landing on that surface...
Very good thought....:-) I would definitely try it.
If it won't seal, I try to have that surface smoothed out with a lathe. It would not take much as the new seal will seal if the surface is smooth if not very little material removed. If its a deep groove that might take too much material and not seal.
Mostly if its just slight, a new seal will seal on the shaft without an issue. :-)
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
