Old 05-27-2024, 04:03 PM #1
KarlitosWay KarlitosWay is offline
KarlitosWay is on a distinguished road
Tapping or clicking sound upon startup, then idle stabilizes
1999 SR5, has a rough idle at startup, does this sound like rod-knock or something mechanical that is going to fail?
https://youtu.be/qynpUXGQ0fI
KarlitosWay is offline   Reply With QuoteReply With Quote
Old 05-27-2024, 04:07 PM #2
Previologist Previologist is offline
Previologist will become famous soon enough
Video unavailable
This video is private
97 4runner 5-speed 3.4
Previologist is offline   Reply With QuoteReply With Quote
Old 05-27-2024, 05:07 PM #3
Just changed the settings
Old 05-27-2024, 05:47 PM #4
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Still saying unavailable, you need to update the link I think.
2004 Limited V8
Old 05-28-2024, 03:10 AM #5
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton is a jewel in the rough pluton is a jewel in the rough pluton is a jewel in the rough
pluton's Avatar
Real Name: Keith
28MAY24 00:09 PDT video still unavailable.
pluton is offline   Reply With QuoteReply With Quote
Old 05-28-2024, 01:10 PM #6
Apologies, try this maybe:
Old 05-28-2024, 03:24 PM #7
subzjc subzjc is offline
subzjc is on a distinguished road
Maybe try removing belts one at a time and then listening.
subzjc is offline   Reply With QuoteReply With Quote
Old 05-28-2024, 04:42 PM #8
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all
JoeT4R's Avatar
Can't be a bad bearing somewhere, could it? I might be totally off but wanted to at least throw it out there for a conversation starter.
Old 05-28-2024, 05:13 PM #9
Real Name: Skip
Real Name: Skip
This is just an observation but to me it looked like the cooling fan slowed down at the same time as the noise subsided, if you can verify that as a fact in person it could very well be the fan clutch making the noise.
Other than that before you got the video link to work and without hearing the noise yet I was thinking it maybe "piston slap", so it could be that.
2004 Limited V8
Old 05-31-2024, 03:42 PM #10
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Also, maybe check the timing belt or chain. It could also be the lifters, which make noise until oil pressure builds up.
Sometimes, a worn or misaligned serpentine belt or its pulleys can cause noise at startup. Plus, check your oil level and condition.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 05-31-2024, 04:51 PM #11
5vz is timing belt. No hydraulic lifters.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-01-2024, 07:32 AM #12
JoeT4R's Avatar
JoeT4R's Avatar
@ OP if it's your fan clutch that is a quick and easy fix! Aisin fan clutch from RockAuto, 4 nuts, remove clutch, install new one, 4 nuts, boom, done.
Is your engine roaring/noticeably louder than normal?
Old 06-01-2024, 12:10 PM #13
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
you can try the steps as listed above, remove a belt at a time, I agree it could be a fan clutch
get youself a piece of hose and hold it on various parts of your engine to listen to...or go to harbor freight or an auto parts store and get a stethoscope
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 06-03-2024, 04:59 PM #14
Gizmo McGee Gizmo McGee is offline
Gizmo McGee is on a distinguished road
Unless the computer speakers are fooling me... bad bearings "thunk" more than they "tap" or "click," I'm not hearing any of that
Gizmo McGee is offline   Reply With QuoteReply With Quote
fail , idle , sound , startup , tapping
Clicking/tapping noise when engine is idle drag0dan 5th gen T4Rs 2 10-26-2019 06:56 PM
Grinding Sound on Startup/Idle? EveningCommuter 3rd gen T4Rs 9 07-02-2019 01:14 AM
Weird metal tapping/clicking noise from engine zzzzzzz7zzzzzzz 3rd gen T4Rs 3 01-20-2019 03:52 PM
Clicking/tapping/rattle sound in passenger floorboard area. brian0128 5th gen T4Rs 12 08-10-2017 07:21 PM
Does anyone recognize this sound?? Mouse/tapping sound from inside? theoutbackdream 4th Gen T4Rs 5 04-22-2017 12:26 AM
