Old 05-29-2024, 01:20 PM #1
WOLVERINE's Avatar
WOLVERINE WOLVERINE is offline
WOLVERINE is on a distinguished road
WOLVERINE's Avatar
2001 Toyota 4runner 4x4 Flashing Lights - Front Driveshaft Always Engaged Normal?
Question - on the 2001 - 2002 4x4 4runners, with electronic actuators and push button 4x4 on the fly - is the front driveshaft always locked and spinning even when in 2wd? I have verified front wheels are not spinning - so front differential is not engaged - nor does it engage with push button either.
I am having the flashing 4x4 lights and no engagement in 4x4 Hi or Low - without manually jumping, with a "U" shaped wire, the forward most transfer case actuator ball-sensor harness - by doing this, I can get 4x4 engaged, with lights flashing - and I can switch to 4x4 Low with differential locked, and all lights will go solid. Once going back to 2wd - the lights remain flashing.
I already removed and cleaned the cover contacts for the center differential actuator, ordered and installed a refurbished $350 4x4 computer module, installed new AISIN front differential actuator, changed both differential and transfer case fluids, and both transfer case actuator sensors are new OEM Toyota.
I believe I have narrowed it down to a wiring issue OR a mechanical differential actuator rod/fork issue I believe - to further diagnose wiring, I need to rule out mechanical - I do know also, that when I remove the harness pigtail for the rear transfer case actuator sensor, the flashing lights stop - so maybe even adding a washer to that sensor will fix it, as someone else did on Yotatech.
Question is - on the 2001 - 2002 4x4 4runners with electronic actuators and push button 4x4 on the fly :
IS the front driveshaft always locked and spinning even when in 2wd?
New Daily Driver - 2006 4runner Limited Galactic Grey V8 4x4 -291K miles and counting - STOCK Driveline - New Audio Setup.
2007 Lexus GX470 - Stock, 56K miles - Sold
2004 Black Sport V8 4x4 - Made Limited- 141k miles Sold
2003 Grey Sport V8 4x4 - Sold - 1st 2UZ owned
WOLVERINE is offline   Reply With QuoteReply With Quote
Old 05-29-2024, 01:41 PM #2
No, in 2WD, the front driveshaft should spin freely by hand (disconnected at the diff end and the transfer case end). It might spin slowly when driving at speed due to viscous drag in the front diff, but it is not directly linked to road or driveline speed otherwise.
It sounds like your transfer case actuator is not making it all the way to 2WD and that's why the 4WD ECU keeps the lights blinking.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-29-2024, 01:45 PM #3
WOLVERINE's Avatar
WOLVERINE's Avatar
Ok, that is what I thought - heard a few people say it was normal for 2001-2002 shift on the fly 4runner 4x4's - but made no sense to me as the Tacoma's front that year spin freely. I manually activated the transfer case actuator both ways and can never get it to unlock that front driveshaft.
Anyone have a good shop that rebuilds transfer cases???
Old 05-29-2024, 02:26 PM #4
Those people may be confusing the multi-mode transfer case for a full-time transfer case (like you have in the GX, or V8 4th gen 4runner, Land Cruiser, etc.).
Old 05-29-2024, 02:31 PM #5
WOLVERINE's Avatar
WOLVERINE's Avatar
That's exactly what I thought - thank you for helping me confirm!
Old 06-01-2024, 07:34 AM #6
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all
JoeT4R's Avatar
Can confirm what Charlie said. When I greased my joint fittings on the front shaft last year I remember turning it by hand. So nice & easy.
Old 06-07-2024, 08:19 PM #7
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
I drove through water once and it rusted the lines on the transfer case for the acuator. I ended up just getting a used transfercase from a junk yard for like $300 cause that was the easiest. both front acuator and transfer case acuator should move when shifting to awd/4wd
have a friend under the car near the transfer case acuator and see if thats at least moving. if not then its not getting the command or its not being sent.
Mine would move but since it was rusted it didnt know when to stop and got all confused.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 06-18-2024, 06:23 PM #8
WOLVERINE's Avatar
WOLVERINE's Avatar
Fixed
So, that gear does come out, rather easy - the housing can then be removed, and the rod can be pulled in and out.
I have fixed her, this posting explained what I found to be essentially true :
4wd not engaging in my 2001 4runner
There are some differences in what I did, but she is now fixed - I do still have to turn the wheel and move in D or R to get from 4wd to 2wd, but it's fixed.
DO NOT BE AFRAID to take the gear out of the housing, it is a serviceable actuator, like the 2000 and older models, just has the rod metal gear attached to the plastic actuator gear wheel via a metal tab and spring roll - it does com apart and is fairly easy to put back together - pull it all out, re-clock, move rod in/out where neeeded, and bam.
Old 06-19-2024, 12:25 PM #9
Even on a j-shift you often have to be moving or change the loading on the drivetrain to go in/out of 4WD. It could just be the front diff actuator being loaded a bit to keep it from sliding.
Use it more and it will get better - Just go in and out of 4WD every time you drive it on a straight section of road until its working quickly and reliably. After that, use it at least monthly (owners manual requirement).
Old 09-17-2024, 10:27 AM #10
Kd4R1 Kd4R1 is offline
Kd4R1 is on a distinguished road
I try and go in and out of 4x4 at least a few times a month. This seems to keep the sensors free and working properly. I’ve noticed if I don’t, it will take a few tries to get it in 4wd. I replaced a few of the pressure sensors on top of the transfer case and this helped a lot.
Kd4R1 is offline   Reply With QuoteReply With Quote
Old 09-17-2024, 05:16 PM #11
3ToyGuy 3ToyGuy is offline
Real Name: Patrick
3ToyGuy is on a distinguished road
Real Name: Patrick
Living in a subdivision that has all dirt/gravel roads is really handy for that. I drive a few miles in 4WD once a month like clockwork. A little 4LO, a little 4HI, shifting through the gears in both, keeps the truck happy.
Come winter, if I encounter snow/ice the truck shifts happily in/out of 4WD as needed. It's like, when I shift it into 4WD, I am going into "double gravity" mode. It just grabs the ground, and away I go!
The Toyo AT3 tires seem to help a lot, too. I ran into a rainstorm the other day on the way home from a Dr. appointment. I mean a RAIN storm. It was pouring down like mad. I slowed down to about 45, and had no trouble staying in what little bit of road I could see. Come time to slow down for a 90* turn, and the truck had no problems at at all. I think the ABS system was working at it's peak
Have a great day, gang!
Pat☺
3ToyGuy is offline   Reply With QuoteReply With Quote
4x4 , actuator , differential , front , lights
Locker light flashing but engaged Anthrax 3rd gen T4Rs 6 01-22-2023 09:21 PM
Replacing the Driveshaft – 2001 4runner 2wd w/ Pics Beach4RunnerNC 3rd gen T4Rs 27 04-17-2021 02:07 PM
2001 4Runner SR5 center rear driveshaft U joint pink_sleeve 3rd gen T4Rs 1 03-10-2019 12:34 AM
40-50mph front end humming when 4wd engaged. Is this normal for a new car? alext72888 5th gen T4Rs 2 02-16-2016 01:21 PM
Normal for knock when 4wd engaged? SR5_Limited 5th gen T4Rs 12 12-26-2014 01:04 AM
