Old 05-29-2024, 03:30 PM #1
cooker cooker is offline
cooker is on a distinguished road
rear axle housing
My son was hit in my 96 4runner and it appears not only is the left rear axle bent, but the axle housing is also bent. Mechanic says toyota doesn't make them anymore and his parts service says the nearest is 500 miles away. Anyone out there with experience on a rear axle housing?? Thanks!
cooker is offline   Reply With QuoteReply With Quote
Old 05-29-2024, 04:23 PM #2
prybar's Avatar
prybar prybar is offline
prybar is on a distinguished road
prybar's Avatar
Just get one from pick-n-pull that doesn't have rear end damage
'99 Limited, 260k
prybar is offline   Reply With QuoteReply With Quote
Old 05-29-2024, 05:06 PM #3
Make sure it matches your current gear ratio - or you can swap the 3rd member (and wheel cylinders, if needed). There were some minor differences through the years (mostly '01/'02 compared to '96-'00) so pay attention to that too - brake line brackets and wheel bearings are the main differences.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-29-2024, 05:49 PM #4
96RedRunner's Avatar
Real Name: Mark
96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold
Real Name: Mark
@cooker
01-02 backing plates shoes hardware wheel cylinders brake lines are different from previous years.
Ran into these differences when installing locker axle into my 01.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress not stock.
2011 Audi S5 Prestige 4.2 V8 6 spd. MT not stock.
Old 05-29-2024, 07:10 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I think the axle housing are similar from 1996 to 2002. Now there is difference with the e lockers vs non e-locker as the 3 members gasket mating surfacesare different. I am trying to recall if any of the 01 and 02 have different brackets welded on the housing... I am thinking they do not, However, not 100% on that one.
Old 05-31-2024, 10:37 AM #6
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Have you thought about reaching out to local auto restoration or customization shops? Or, sometimes, you can find used parts in good condition at local salvage yards.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 05-31-2024, 12:33 PM #7
gh25_'s Avatar
gh25_ gh25_ is offline
Real Name: Garrett H.
gh25_ will become famous soon enough
gh25_'s Avatar
If your going to go the route of buying a new axle housing check out this seller named "RUST FREE TOYOTA PARTS" on ebay. I guess he is a regular pick n puller in the state of AZ he always has 1st gen tacoma and 4runner axle housings for sale as well as the axles too. Both e-locker and non. The shipping price is actually decent too only 120 bucks ish to ship it
https://www.ebay.com/sch/i.html?_ssn....m3561.l161211
gh25_ is offline   Reply With QuoteReply With Quote
Old 05-31-2024, 03:21 PM #8
I may go that route which brings up the following question: Are all axle housings the same for the 4wd '96? I have ABS as well as the factory rear locker.
Thanks!
Old 05-31-2024, 06:11 PM #9
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
What others have written above answers your question, but to summarize you will need a e-locker axle housing from 96-00 with abs, and axle shaft(s), not knowing the engine we can only guess what 3rd member is in it, likely 4.30ratio if its a v6 with elocker, axle code is on the VIN tag, and it is stamped on the ring gear, but yours should be reusable. You can check axle shafts for runout by rolling the shaft part on a perfectly flat table surface. You will want to replace seals, and maybe bearings if it is high milage at this time, you will want someone with the proper tools, press and specific experience with this specific bearing replacement job or they WILL make a mistake and she'll leak.
Malcolm99 is offline   Reply With QuoteReply With Quote
axle , bent , housing , parts , rear
FS 3rd Gen Rear Axle Housing - NYC - $100 T4R2014 For Sale: T4R Items 6 10-02-2018 09:47 PM
WTB Rear axle housing FlipStyle54 Want to Buy/Trade 5 09-17-2013 09:06 PM
Rear Axle housing (3rd gen) 4-Ripcord For Sale: T4R Items 9 02-05-2013 12:06 AM
WTB: 3rd gen rear axle housing TruckTreeHouse For Sale: T4R Items 0 01-04-2012 04:21 PM
WTB: 3rd Gen Rear Axle Housing 3MPHToy Want to Buy/Trade 0 11-15-2010 12:51 PM
