Old 06-02-2024, 10:06 PM #1
SPark SPark is offline
SPark is on a distinguished road
Prinsu rack water tight?
I just installed a Prinsu full length, and after I finished it occurred to me that there wasn’t any step to address water leaking into the holes utilized for the install. Anyone run into any leaking issues after installing the Prinsu? Should I try and add some urethane type sealer or something?
SPark is offline   Reply With QuoteReply With Quote
Old 06-03-2024, 11:57 AM #2
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
I used this when I installed mine 3 years ago and haven’t had any leaks. When pulling the oem bolts out for the first time, you’re usually ruining the sealant that’s used from the factory. I’d address it before finding out the hard way if it’s still water proof.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 06-03-2024, 12:13 PM #3
MBTaco2-4Runner MBTaco2-4Runner is offline
Real Name: Jay
MBTaco2-4Runner is on a distinguished road
Real Name: Jay
They're supposed to be including RTV in the kits now when you buy it vs having to go get your own. Plenty of video's out there showing how to seal the factory holes during installation.
I posted another thread this past week asking for long term reviews as I can see where dirt can really get in under the feet and the front feet require cutting making yet another hole for dirt to get into.
MBTaco2-4Runner is offline   Reply With QuoteReply With Quote
Old 06-03-2024, 04:57 PM #4
I already have the front feet 3M adhesive down, so I’m hesitant to remove the whole rack. But I got some urethane edge sealer, do you think if I just took the bolts out and put some of this in the hole and then replaced the bolts through the goopy urethane there, that would seal it up?
The front feet didn’t require any cutting for me. It’s just attached via 3m adhesive pad. They include thread locker with the install kit, is that RTV? I used that, I just don’t know how waterproof it’s going to make it because it was just on the threads of the bolt, seems like water could still make it through
Old 06-03-2024, 06:19 PM #5
Real Name: Jay
Real Name: Jay
You didn't cut the weatherstrip and have the front feet sitting on the roof vs on the weatherstrip?
https://youtu.be/0yt8-Xz2EHs?si=5KhFHiJJWb1QgmV4&t=450
Old 06-03-2024, 06:38 PM #6
Had me worried for a second that I totally screwed up. That video is for a 4th (5th?) gen; my question and install is for a 3rd. The front foot doesn’t end up on any sort of weather stripping.
Old 06-03-2024, 06:55 PM #7
The water can only leak through the root of the threads... so depending on how much thread locker is on there, it can also act as a sealant. Probably still smart to put a dab silicone sealant or a dedicated thread sealant on the the threads - and make sure the hole for the roof rail front and rear cap clips are sealed while you are at it...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-04-2024, 03:54 PM #8
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing is a jewel in the rough GhostRing is a jewel in the rough GhostRing is a jewel in the rough GhostRing is a jewel in the rough
GhostRing's Avatar
The purple Vibra-Tite 111 is usually for the black bolts going into the crossbars.
I would recommend using a proper RTV-type sealant for the vertical roof bolts.
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 06-04-2024, 06:14 PM #9
Real Name: Jay
Real Name: Jay
Yup sorry 5th Gen install. Didn't note what you had. Still interesting the differences in mounting between all the different racks out there.
add , leaking , prinsu , urethane , water
WTB: Prinsu or Prinsu Style Roof Rack for 2003-2009 4Runner smeister Want to Buy/Trade 6 11-23-2022 03:49 AM
Prinsu Full length rack or The 3/4s rack? BradyHankins General Discussions 1 11-16-2021 01:32 AM
RTT on a Prinsu rack anyone? PhotogEric 5th gen T4Rs 9 07-29-2018 10:11 AM
Needing an air/water tight food storage container momo.75 Off Topic 4 07-01-2013 07:52 PM
"Water Tight Drivetrain" - Does the 4R have? westwind77 5th gen T4Rs 34 10-08-2010 10:47 PM
