Old 06-09-2024, 01:14 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Adjusting the speedometer to work with 265/75R16 tires
Im considering upgrading to 265/75R16 tires from 265/70R16. I know the diameter difference will affect the odometer and speedometer accuracy.
I know most people just live with it, but I like to log my fuel economy and having the odometer be off will mess with that. I could make a conversion equation but that’s a hassle. I don’t want to use my phone for this.
How would you adjust the speedometer so that it is accurate to a new tire size?
Im pretty sure 1998 don’t use a cable anymore. Mine has no ABS and it uses an analog counter, but I didn’t see a cable when I removed my cluster to replace bulbs.
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 06-09-2024, 01:57 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Not sure but here's a search results that may or maynot help, if you figure it out be sure to report back to possibly help others in the future.
https://www.google.com/search?q=Adju...hrome&ie=UTF-8
2004 Limited V8
Old 06-09-2024, 06:23 PM #3
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
If you don’t have ABS you can swap in a different speedo gear. Do a little searching on that topic to find out what you need. I think I changed mine from 31 to 33 teeth or something… it was a while ago
JZiggy is offline   Reply With QuoteReply With Quote
Old 06-09-2024, 06:51 PM #4
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Isn’t yours a 99? I thought the digital ones didn’t use gears. Was the gear inside the gauge cluster or the transmission on yours.
And where did you get this gear from
Old 06-09-2024, 10:15 PM #5
SpiderT4R SpiderT4R is offline
SpiderT4R is on a distinguished road
I went from 265/70/16 to 265/70/17, so it's a similar diameter difference. For whatever reason, my speedometer doesn't seem to be affected at all. I've been through multiple different speed radar signs since getting the new wheels and tires, and every time the speed matches exactly what is being shown on my speedometer. It doesn't make much sense, maybe my speedometer was off before
SpiderT4R is offline   Reply With QuoteReply With Quote
Old 06-10-2024, 02:42 PM #6
Non-ABS 3rd gens use a speed sensor at the rear of the transfer case. ABS-equipped 3rd gens use a signal from the ABS computer. For you, gearing changes AND tire changes will affect your speedo. ABS-equipped trucks will only be affected by tire size changes. Not cable in either case.
You can change the gear on the speedo sender in the transfer case OR use any of a number of digital speedo healer type products that will adjust the digital signal before it gets to the cluster.
Likely it was off (reading too high) before you changed the tires. That is a 3.3% increase in tire size, which is right around 2mph difference in indicated speed on the highway - which is coincidentally about what they read high with factory tires...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-10-2024, 04:38 PM #7
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
I have an UltraGauge that I thought I recalibrated when I went to 265/75/16, but a free MPH app on my phone thinks the cluster needle is more accurate than the UG. I drive by feel these days with a glance at a variety of data sources.
Y2K LTD/E 262K
Old 06-15-2024, 12:05 PM #8
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
How would I determine the new gear size I need for the tires?
Old 06-15-2024, 12:14 PM #9
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
Im running 265/75/16 and as stated above , I pass a radar and all agree.
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 06-19-2024, 10:56 AM #10
Texmax's Avatar
Texmax Texmax is offline
Texmax will become famous soon enough
Texmax's Avatar
Load a speedo app on your phone then you'll know the difference. It's a waste of money to modify stuff like that.
99 4wd limited w/ E/locker
3" RC lift-loaded struts. Sonoran Drop diff and adjustable rear Panhard.
JBA Offroad UCA's, Pro comp Raven 16x8 wheels wrapped in 265/75/16 Gladiator Mt APOC INDUSTRIES Rear Trailing arms.
RETIRED USCG Aviation Mechanic/Hc130h Flight Engineer/HH65-A Flight Mech.
SEMPER PARATUS CENSORSHIP IS REAL ON 4RUNNER.ORG
Texmax is offline   Reply With QuoteReply With Quote
Old 06-19-2024, 11:32 AM #11
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
I did the same tire size upgrade years ago and there is such a small difference that the amount of work, time, money into correcting it doesn't make sense. IE you'll spend more money on "correcting" than you will on gas over the life of the vehicle. Plug the tire sizes into Tire Size Comparison to see what I mean.
Other things to keep in mind too is that with a larger diameter tire you could potentially get better MPG if you're driving on flat roads (less revs/mile). On the flipside you'll lose MPGs on hillier terrain since lower revs is less torque meaning your engine has to work harder.
1997 4Runner SR5- ~376k Miles and counting
2007 4Runner Limited V6- 175k Miles
2011 VW JSW TDI- 150k Miles
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 06-19-2024, 11:44 AM #12
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
I would be sure to check your speedo needle vs gps speed on your phone. With 265/75/16's my speedo is perfect. There is a slight possibility that someone changed it before I bought it 12 years ago, but I doubt it.
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Old 06-19-2024, 12:53 PM #13
They all read slightly high from the factory. A small bump in tire size corrects it...
I went from the small 15" wheel tires (225/75-15, 28.3" diameter) to 265/70-17's (31.6" diameter), which is nearly a 12% difference in size - about the same as going from 265/70-16 to 35's - so I really needed to adjust the speedo.
Old 06-19-2024, 06:26 PM #14
JZiggy's Avatar
JZiggy's Avatar
I dug around and found that I used part number 33403-39415. If memory serves, this is a 33 tooth gear, which is the highest # of teeth available. More teeth = slower rotation on the encoder that feeds to signal to the speedometer in non-ABS rigs, so it would reduce the displayed speed and made the odometer click up more slowly. (If someone reads this carefully and I have it all backward -- sorry!)
Had trouble finding the part page with the details but this might help: Speedometer Gear- Toyota 4Runner, Pickup, T100 & Tacoma w/MT OEM Speedometer Driven Gear 33 Tooth (1991-2004) 33403-39415
Also Speedometer correction by T-case gear change | IH8MUD Forum
265/75r16 , don’t , odometer , speedometer , tires
Rear axle swap. Need help getting speedometer to work Deangraen 4th Gen T4Rs 7 08-28-2019 11:17 AM
Fitting 285 Tires with LR UCAs (Adjusting Caster) Bicepus Maximus 5th gen T4Rs 16 09-16-2015 08:01 AM
AC Fan/Radio/Auto Windows/Speedometer won't work, help please... Ralph III Problems & Warranty Issues 3 05-15-2013 04:08 PM
Adjusting the Speedometer tla11384 3rd gen T4Rs 1 09-24-2008 10:05 PM
2004 4Runner Speedometer doesn't work wieyu 4th Gen T4Rs 3 12-05-2007 03:29 PM
