Old 06-11-2024, 07:47 PM #1
prybar's Avatar
prybar prybar is offline
prybar is on a distinguished road
prybar's Avatar
5VZ-FE Replacement Sourcing
Hi all,
I've had my '99 4R for 4 years now, bought it from an old lady who was the only other owner in its life. She took it to the dealer for everything and kept all receipts. Since I bought it, I have taken great care of it mechanically, oil changes at every 3k, using quality oil and good filters.
Yesterday on my way to work, I was sitting at a red light and all of a sudden, got a bad misfire accompanied by clanking coming from the engine. Shit. Pulled over, couldn't figure out the issue right away - it sounded like a broken lifter or something. Took it to the AAA shop (they could get me in the quickest) and they say I spun a rod bearing and there's damage to the lower. They determined this without taking the engine apart, and said they didn't see any metal shavings or chunks in the oil or filter. I trust that their guys are experienced, but I'm not sure how they made this diagnosis and they won't let me talk to the tech (AAA policy, complete BS). For the guys with experience on this motor, how does this diagnosis sound? Would you trust it? They said usually with this sort of issue, it ends up just costing the customer more to tear down the engine and that they'd likely replace it anyway.
So they're telling me my best bet is a motor swap. They want to charge about $5000 for labor. Is this fair?
Where are you guys sourcing your motors from? I'm leaning towards a recycler yard - ToyAuto Mart here in Rancho Cordova, since they're nearby and I can't wait weeks for a new motor - this is my only vehicle. The shop said they've had good luck with Jasper Motors, but those are $4-5k and I don't want to drop $10k on a motor swap. I'm mechanically inclined, but I really don't have the time or interest to do the swap myself. Jeggs sells them for $4-5k as well, but again that's more than I'd like to spend. JDM motor could be an option, but again I can't have the truck down for too long since it's my only vehicle and I'm supposed to move this week. I am aware of all the parts I'd need to swap from my motor and am not worried about that - more concerned with lead time and cost.
Any suggestions or advice would be appreciated. I want to keep my 4R, I couldn't imagine going with a different vehicle at this point and I don't think I'd have luck finding another good one right now, as the prices are pretty high in my area. I'm kinda at a loss for which option to take, so if anyone has experience, I'd love to hear your thoughts.
Thanks in advance to anyone who can give me any info on this.
'99 Limited, 260k
prybar is offline   Reply With QuoteReply With Quote
Old 06-11-2024, 08:00 PM #2
Texmax's Avatar
Texmax Texmax is offline
Texmax will become famous soon enough
Texmax's Avatar
Just a moment...
99 4wd limited w/ E/locker
3" RC lift-loaded struts. Sonoran Drop diff and adjustable rear Panhard.
JBA Offroad UCA's, Pro comp Raven 16x8 wheels wrapped in 265/75/16 Gladiator Mt ,APOC INDUSTRIES Rear Trailing arms.
RETIRED USCG Aviation Mechanic/Hc130h Flight Engineer/HH65-A Flight Mech.
SEMPER PARATUS
Texmax is offline   Reply With QuoteReply With Quote
Old 06-11-2024, 09:59 PM #3
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
I don't think a spun bearing could cause a misfire...
did the engine make a toc toc toc noise continually?
Maybe start by taking out your spark plugs and have a look at them.
A spun bearing would definitely bring shiny particles to the filter I can't see how it couldn't do so.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 06-11-2024, 10:28 PM #4
prybar's Avatar
prybar's Avatar
I did have a valve tick before this happened, which was there for a few months. This made me think that it could have been a lifter or something along those lines, along with the fact I could hear it better on the passenger side.
My truck is at their shop so I can't take a look at it. I don't think it was actually misfiring since I didn't get a code for that, and I have fresh plugs and coils (1 year old, densos). But it felt like a misfire, for lack of better words. It also lurched slightly while in gear when I went to pull over.
I'm in the same boat about the bearings. Seems a little shady, maybe the desk guy misunderstood the techs diagnosis.
'99 Limited, 260k
Old 06-11-2024, 11:07 PM #5
diverscale's Avatar
diverscale's Avatar
there are no lifters so no lifter tick possible. What you heard for months might have been a rod knock, manifold leak, a purge valve or something else.
If it was rod knock, a spun bearing is possible but IMO would show in the oil filter. Have they done a compression test?
1998 4runner SR5
Old 06-11-2024, 11:58 PM #6
prybar's Avatar
prybar's Avatar
Well, I thought it was a valve tick, sorry I misspoke. You're right about the lifters. It definitely was not rod knock, it was more of a light tick with no weight to it. The guy who I spoke to at the front desk wasn't very helpful and couldn't really tell me what tests they had done, so I'm not sure about compression. I'll ask the manager tomorrow. I wouldn't be surprised if they didn't even check it. Hopefully I can get some better info from the manager since I can't talk to the actual techs for some stupid policy reason.
'99 Limited, 260k
Old 06-12-2024, 04:21 AM #7
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Not being able to talk to the techs is common, but it's still BS. Have it towed to a better shop?
pluton is offline   Reply With QuoteReply With Quote
Old 06-12-2024, 10:00 AM #8
prybar's Avatar
prybar's Avatar
I'm considering options. I'm going to call around today to other shops and see what they say, if they agree with the diagnosis, how much they would charge for the same work, etc.
The motor definitely sounds really bad. It seems that there's not many shops in my area that are actually willing to tear into the motor and work on internals, so at this point I may be forced to go the swap route..
'99 Limited, 260k
Old 06-12-2024, 01:47 PM #9
Ibrad Ibrad is offline
Ibrad is on a distinguished road
I would not go with the first shop that told me something. I fix everything myself as I don't trust any shop for anything. They're in business to make money and if they aren't letting you talk to a tech then I see that as the classic pressure tactic. I'd sit outside at closing time then talk to the dirtiest guy as he walks out of the shop. Chances are he's a young guy that knows nothing much about diagnosing much of anything. If internal damage has happened there will be signs of metal in the oil and filter. If oil is clean please look elsewhere and start with the simple stuff first. New coils do go bad. A couple of bad coils will cause the motor to clank as you said and will make it seem as though something bad has happened. If this is your spare vehicle take it home and diagnose yourself. A spun bearing will not cause a code to throw. Do not let them just swap your motor without a complete tear down and showing you the bad parts to prove their diagnosis. This forum will guide you in the right direction if you just listen to what others are saying. You are free to do what you want but I suggest working on the rig yourself. You can only gain knowledge and understanding of how everything works and provide insight to others that may encounter things such as this.
Ibrad is offline   Reply With QuoteReply With Quote
Old 06-12-2024, 04:14 PM #10
prybar's Avatar
prybar's Avatar
Thanks for your insight. I was able to talk to the shop manager today, and he basically said they diagnosed it based off other 3rd gens that have come in with the same sound/symptoms. They said they'd be happy to pull the motor apart and only fix what's wrong, but he said a lot of times there's more wrong than is worth it to fix, and they'll end up swapping the motor.
I spoke to a different shop today (Made in Japan) about a second opinion. They said they'd tear the motor apart to diagnose and that if it were the bearings then it would obviously be a relatively cheap fix compared to a swap.
Unfortunately, this is my only vehicle. I just signed a new apartment lease and I need to start moving my stuff, and it sucks to do without a car. So I really need to get it back on the road ASAP.
I definitely didn't get any pressure from the shop to start work on anything, they've been super nice and answered all my questions.
Taking the vehicle home to drop the pan and look at the lowers will take more time than I have right now, due to having to move. The timing is really poor.
But I agree with everything you're saying about verifying the problem before dropping a huge chunk of money on a new motor. However, it would be nice to start with a fresh motor - I'm burning oil pretty bad.
Still undecided on what route to take. I wish I had the time and space to just look at everything myself, but unfortunately, I just don't at the moment.
'99 Limited, 260k
Old 06-13-2024, 07:14 AM #11
A shop can't diagnose one car by what other cars they've seen come in. Every car doesn't have the same problem although the same problem does happen in the same cars for sure. Although a new motor seems logical the rest of your rig will still be the same. Older bushings and bearings and everything else that may need attention will still be waiting for your wallet to open just the same. Think this way. If you have enough cash reserves to sink into a 4-5 thousand dollar motor why not find a cheaper car to drive now and slowly bring the 4Runner back to life on your own. That's my suggestion. You have to drive something if you let the shop fix your rig anyway. Find a good deal on a used car that will get you by for a year or so and work on the rig yourself. I'd suggest also looking for a wrecked 4Runner and see if you can pick one up for cheap and swap in that motor.
Old 06-13-2024, 04:26 PM #12
yuckscott yuckscott is offline
yuckscott is on a distinguished road
well if it makes you feel any better, I can commiserate. Last summer was visiting family across the country and got a bad misfire and white smoke out the tailpipe. had to get back out west to return to work so I didn't have much of a choice but to bring it to the only shop I could find locally who would tear it down. got the engine more or less rebuilt with all new gaskets and seals, replaned the heads, new fuel injectors and more. hurt the wallet and lost me a couple weeks of sleep but in the long run, im glad with the outcome. best of luck.
99 Limited - E locker, Wildpeaks, Millennium Silver.
yuckscott is offline   Reply With QuoteReply With Quote
Old 06-13-2024, 05:50 PM #13
diverscale's Avatar
diverscale's Avatar
If there really is internal damage and the shop can do it, and it is your only vehicle, I'd go for it. Might even be faster than finding another car these days. Then once you get it back in order, rust proof the shit out of it every year and replace every fluid per specs (diffs, xfer case, pan drop on transmission once in a while) and you'll still have a great vehicle for a while to come.
I just hope for you that the diagnostic was fair with the lack of information that you can provide.
1998 4runner SR5
Old 06-14-2024, 01:21 AM #14
pluton's Avatar
Real Name: Keith
pluton's Avatar
Real Name: Keith
Rebuilding/partial rebuilding/swapping the motor isn't going to be a "drop it off Tuesday, pick it up Thursday" type of thing. It could be in for a week or longer.
The idea of buying a cheap car is worth considering IMO. Also, you could rent a U-Haul pickup truck (or equivalent) which would be very helpful for moving.
Old 06-14-2024, 03:03 PM #15
TracyNorton's Avatar
TracyNorton TracyNorton is offline
TracyNorton is on a distinguished road
PLEASE do not take it back to that shop.
If what you say they were telling you....something is jank there.
Try another MORE REPUTABLE shop for a diagnosis...
Drive 100mi if you have to....
98 SR5 4x4 5sp w/ fact rear locker
ARB & 6112s business up front
CBI DSG & LC 862s/Tokicos party in the back
Lots of So African electrics strewn thruout
"If you haven't broken anything on your last trip...you ain't tryin' hard enuf"
TracyNorton is offline   Reply With QuoteReply With Quote
engine , guys , motor , swap , vehicle
Sourcing ARB Bumper eleven14 4th Gen T4Rs 2 01-22-2019 02:08 PM
Help sourcing part #s doctorres112 5th gen T4Rs 2 04-22-2018 08:09 PM
Need help sourcing parts! zoombyu86 3rd gen T4Rs 0 02-03-2018 12:17 PM
Sourcing 4.56 OEM V6 3rd member geohil 3rd gen T4Rs 9 10-20-2016 09:16 PM
Sourcing a non-KDSS 4runner NAKaveli71 5th gen T4Rs 49 10-05-2016 01:52 PM
