Old 06-20-2024, 04:23 PM #1
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Constantly losing power to gauge cluster
Hey all
What started out as a once in a blue moon occurrence has now rapidly become a reliable and very annoying problem, arguably at the worst time it could have. Seemingly whenever it's warm outside - about 80 degrees and above - I randomly lose power to my gauge cluster in the middle of driving. Sometimes it's within 5 minutes, sometimes it's after half an hour, but either way there's no rhyme or reason for it. This means I not only lose my tach and speedo, but all window and HVAC functions as well while driving around in the sun
I've noticed sometimes shutting down and letting the car sit for a minute or two will restore it, but if that doesn't work I have to unplug/replug the dash to get power again. That seemingly works out every single time
I've checked every wire I can for splits or cracks and have tried double-checking any ground I come across but everything seems totally fine. All fuses are good too - some of which I even replaced just for the giggles to see if it would stop it from happening again but to no avail
Anybody have any ideas what could be causing it? Is my dash dying or something? I'm worried that if I replace it altogether then my odometer will change
Old 06-20-2024, 05:36 PM #2
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a jewel in the rough 2TH4IST is a jewel in the rough 2TH4IST is a jewel in the rough 2TH4IST is a jewel in the rough
2TH4IST's Avatar
Hmm that is odd, that it only happens above 80 degrees. That might lead me to a possible relay. Ambient when cooler then 80 might just be enough to keep the relay cool. Any hotter and the relay shuts off. But I could be wrong too. Have you checked the circuit opening relay? I believe it's the blue one in the fuse box under the hood.
I don't have a wiring diagram in front of me now, so I can't check common grounds and powers.
Any recent electrical work on that system on your rig?
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 06-20-2024, 07:06 PM #3
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Nothing recent, no; the most recent was trying to tap in my diff locker switch to the dash light, but it didn't work so I removed it, and that was back in the winter as well The relay makes a bit of sense, I believe you're right that it's in the engine bay so it could be getting pretty toasty. I might look into replacing it just to be safe and see any changes
Update: reconnected the dash before I went into work and it did the trick. Went out to my truck again on lunch and it's dead again Very strange, hasn't done that before. Usually once it's "fixed" it stays on for a week or so
Anybody know what relay these functions run through? I found it in a thread a few months ago but can't find that particular post anymore
Old 06-28-2024, 04:37 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I have included the overall wiring diagram for the 2000 3rd gen. Hopefully it will help you find your gremlins. :-) I am chasing a tail circuit gremlin myself but I need to get a Honda civic done and off my lift to get the 4 runner in the shop.. :-)
Old 07-09-2024, 09:14 PM #5
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Damn thought I was in the clear.... I swapped my tail relay and put a fresh 10 amp fuse in the gauge cluster spot and didn't have the problem for quite some time, only to try and start up my car after sitting in 100 degree sun all day and it all went blank again :/
Old 07-09-2024, 11:40 PM #6
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
You wouldn't happen to have a wiring diagram for the interior fuse box would you? If not it's no big deal
Old 07-10-2024, 09:24 AM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Besides the Overall EWD Everything else is individual circuits. I unfortunately, do not have a gauge diagram. :{
Old 07-16-2024, 04:12 AM #8
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Anyone know where I can find the integration relay on a 2000? When I try and look it up I just find people saying it's under/hugging the interior fuse box, but all I see is one solid unit. Is it perhaps integrated to the fuse box instead of a separate part?
Old 07-16-2024, 09:53 AM #9
Texmax's Avatar
Texmax Texmax is offline
Texmax is on a distinguished road
Texmax's Avatar
This is my experience with wiring on my 4runner.
I was having issues in the cluster with the Gear indicator being intermittent, the cruise stopped working and the reverse lights stopped working. We traced the bad wiring to the harness from the neutral safety switch wire loom running from the trans through the engine bay to the fuse box. We unwrapped all the tape around the harness and found a crap load of exposed wires from corrosion or heat exposure, we ended up replacing almost every wire in that loom by hand. So I'd started by unwrapping and seeing if you've got the same issue. Good luck.
99 4wd limited w/ E/locker
3" RC lift-loaded struts. Sonoran Drop diff and adjustable rear Panhard.
JBA Offroad UCA's, Pro comp Raven 16x8 wheels wrapped in 265/75/16 Gladiator Mt ,APOC INDUSTRIES Rear Trailing arms.
RETIRED USCG Aviation Mechanic/Hc130h Flight Engineer/HH65-A Flight Mech.
SEMPER PARATUS
Texmax is offline   Reply With QuoteReply With Quote
Old 07-16-2024, 10:26 PM #10
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
The body ECU is the "integration relay" from what I can find (or has it built in to it...). U can remove and replace the Board but there are many different part numbers even between the same yrs from what I've found (I save the broads from the fuse blocks I save from wrecked 4runner's/Tacoma's. U have to remove the cover on the fuse Box/panel to get access it the unit.
clearock is offline   Reply With QuoteReply With Quote
Old 07-17-2024, 01:26 AM #11
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Well that blows
dash , lose , power , seemingly , time
2nd gen losing all power. HELP! danhtx92 Classic T4Rs 15 08-18-2015 05:52 PM
Gauge Cluster Help! bigjebus 4th Gen T4Rs 4 08-11-2015 11:48 PM
97 sr5 losing power/please help! mercuryrising17 3rd gen T4Rs 8 04-20-2015 12:31 PM
losing power? TxRoadHawg 4th Gen T4Rs 2 10-01-2013 01:01 PM
Power steering fluid constantly leaking. AZ2AK Classic T4Rs 4 04-09-2011 10:45 PM
