Old 07-01-2024, 02:25 PM #1
wtfdissux2 wtfdissux2 is offline
Real Name: Chuck
wtfdissux2 is on a distinguished road
Real Name: Chuck
projection bulbs
OK I know I am going to get roasted for this but here goes....
I dont have the $$$ or physical ability anymore to mod the lenses or buy ones that are allready modded, but really want to upgrade my lights. Not a fan of HID and really prefer LED but not in a hurry to blind everyone around me. Was looking for replacement bulbs and stumbled across projector LED bulbs. I am wondering if I use them should I remove the reflector/shield dome from in front of the bulb to allow it to go straight forward?
hope this link worked correctly
Amazon.com
wtfdissux2 is offline   Reply With QuoteReply With Quote
Old 07-01-2024, 05:03 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light
jgue467's Avatar
Modern LEDs are designed to use the OEM housings including the reflector and shields there and they use similar shields built into the LED housing to mimick the non-glaring lighting
So use as is - do not alter your housings or the LEDs. Luck and enjoy the Runner.
2001 Limited 4WD - 350+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
Old 07-02-2024, 02:04 AM #3
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
I bought a set of mini projector H4s from AliExpress last year for something like 20$, work great as of July 2024 and don't have any glare either. I did have to remove that middle reflector thing that goes in front of the regular bulbs, but they work great.
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 07-02-2024, 11:26 AM #4
prybar's Avatar
prybar prybar is offline
prybar is on a distinguished road
prybar's Avatar
Forget the projectors, just swap in some higher wattage bulbs. Cheaper and the light quality is really good.
@gamefreakgc shared the solution with us. Check post #3
Drop-in headlight upgrade?
'99 Limited, 260k
prybar is offline   Reply With QuoteReply With Quote
Old 07-02-2024, 11:39 AM #5
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
My 100W/80W bulbs have been great all these years. Highly recommend it as a low-cost solution to improve the lights.
326WHP 347TQ
Old 07-02-2024, 11:41 AM #6
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
the mod mentioned works very well, and am considering doing to my tundra now
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 07-02-2024, 12:34 PM #7
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
You have to remove the glare shield for those to work
Yes they have a sharp cutoff but at the expense of really narrow beam width - original halogens were wider.
Old 07-02-2024, 07:10 PM #8
prybar's Avatar
prybar's Avatar
possibly my favorite easy mod for these vehicles. I've recommended this to all my buddies too, they all run the 80/100W bulbs now. Thanks again for this
'99 Limited, 260k
Old 07-02-2024, 09:06 PM #9
Real Name: Chuck
Real Name: Chuck
If was still running the shop and had full use of my body I could do the upgrade.
Am out on workers comp for shoulders then got rear ended (new liftgate and complete rear bumper but her 2011 pilot was totaled whe trailer hitch hit her engine). So kinda limited funding and ability so might just stick wth "normal" LED and install factory fogs.
Bad enough I had to watch somebody else replace front pads and rack & pinion
Old 07-02-2024, 11:49 PM #10
Real Name: Chuck
Real Name: Chuck
Did little bit of searching and drew a blank. What is the bulb number your talking about or is it just an up powered 9003? Can they be run without harness or am I looking at a meltdown in wires or lens? I can build a harness at my desk and have my son do the actual "work" part of it but just found out the headlight that was failing is now Hi and Low dead.
Old 07-03-2024, 01:50 PM #11
prybar's Avatar
prybar's Avatar
Bulbs:
Amazon.com
Wiring harness;
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
These are the materials I used. The bulb is an H4 bulb, so you will need a wiring harness to power the lights, since the ground spot is switched on these. The harness is plug & play, you just connect the harness to your existing headlight plugs, then plug the bulbs into the new harness. I believe you also have to hook the harness to the battery to draw power if I remember correctly. The headlight stalk still functions as it should. I've been running this setup about a year now, and no issues with the extra heat.
'99 Limited, 260k
Old 07-08-2024, 12:46 PM #12
Real Name: Chuck
Real Name: Chuck
ordered the bulbs and harness
Bought the silverstar top rated and they were crap compared to my LED bulbs. So ordered the set up you mentioned. Got a link to the wire diagram so I can walk my son through the install?
Old 07-08-2024, 02:23 PM #13
prybar's Avatar
prybar's Avatar
The diagram is listed if you go to the link I sent.
I had silverstars too at one point, nothing close to the 80/100W Hella bulbs tho
'99 Limited, 260k
Old 07-15-2024, 05:15 PM #14
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
And don't forget to upgrade the headlight circuit so that you're getting better draw from the bulbs with less danger of burning up the circuit: Daniel Stern Lighting Consultancy and Supply
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
bulbs , led , projection , projector , stumbled
Head light aiming projection nytefog 4th Gen T4Rs 2 09-07-2012 08:29 PM
projection headlamp burn in? kavalis 4th Gen T4Rs 2 09-22-2011 08:30 AM
06 projection Housing VS retrofit??? Alaskan_Runner 4th Gen T4Rs 7 11-04-2010 05:36 PM
Halo Projection Headlights Mitchc4216 3rd gen T4Rs 10 11-01-2009 03:40 PM
projection headlights for 3rd gen skkiii_whhaattt 3rd gen T4Rs 34 09-23-2007 11:06 PM
