Old 07-05-2024, 01:51 AM #1
Brian1973 Brian1973 is offline
Brian1973 is on a distinguished road
Brake Controller
Anyone use a brake controller with their 4Runner? I have two trailers with surge brakes but now have access to use a trailer that has electric brakes. From what I find on Amazon, control units are designed for 2003+ and I have a 2000 4R... Seems I will need the control unit, a pigtail to tie into wires under dash and then I suppose I will need a 7pin trailer connector at the rear... Ideas?
2000 SR5 3.4L 4WD
Aux-12v "always on" mod, DRL mod, 2 Tranny coolers
Rear Differential "extended" Breather mod,
ScanGuage II, 231mm Tundra Brake upgrade,
ABS mod
Brian1973 is offline   Reply With QuoteReply With Quote
Old 07-05-2024, 05:25 AM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
No, I have thought about it. You would have to run wires for Brake controller to work and goto a 7 pin trailer connector.. :-)
Old 07-05-2024, 01:05 PM #3
Yes, you will need to get a 'universal' kit for the brake controller - there is no plug under the dash or any other pre-wiring for it. eTrailer has a bunch of options. You'll also want to be smart about how you mount the 7-pin connector.
You need to run beefy (10-gauge) wire from the battery to the controller and back to the 7-pin connector. Also consider if you want to run a charge wire too.
Up under the dash:
Remote control:
Pollack 4+7-pin (modern style):
Wiring off the battery (winch+ combined charge+brake wire to trailer):
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-06-2024, 01:41 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Glad to see a setup on a 3rd Gen. My 09 Tacoma had towing package built in. I just had to buy the brake controller for it completely plug and pray
Old 07-07-2024, 12:16 PM #5
Phattyduck, what would you guess was your total cost in $$ and time (if you installed yourself)... familiar with Redarc, they build solid stuff....
2000 SR5 3.4L 4WD
ABS mod
Old 07-08-2024, 02:31 PM #6
Looks like my eTrailer order was a bit over $300. There's plenty of 'extra' cost in the nice jacketed wire and higher-end connectors in the rear, too. And don't forget the install time to make it all clean and safe...
brake , brakes , control , controller , trailer
Brake controller gmillerok1 5th gen T4Rs 30 06-09-2016 11:00 PM
need help with brake controller drnick 5th gen T4Rs 5 12-09-2011 10:51 AM
Brake Controller Help stiner0931 4th Gen T4Rs 1 05-08-2011 10:55 PM
Brake Controller salrosa 3rd gen T4Rs 6 10-25-2007 08:06 PM
Brake Controller jclark 4th Gen T4Rs 13 05-13-2004 12:32 PM
