Old 07-23-2024, 07:29 PM #1
Forrest931 Forrest931 is offline
Real Name: Forrest
Forrest931 is on a distinguished road
Real Name: Forrest
3rd gen 4runner cooling question.
Hi T4r, I know there's already a bit of a thread about this but I was left a little unclear about what the optimal coolant temp should be for a 3rd gen 4runner.
I have a 96 limited 286k miles and recently on a trip to some dirt roads in the sierras I started getting a little hotter than I have previously I would say coming back I averaged about 200 on the freeway in 102 degree heat with the heater on but as I hit stop and go traffic I got up to 220 so I pulled over and opted to tow home.
A little background I recently did a lift bumper and tires within about a week of each other. one thought I had was that my bumper placement blocks more airflow to the rad.
Driving around town today I was sitting around 197-202 so to circle back to my question is that a normal temp or should I be concerned? I purchased a new OEM thermostat and champion radiator just in case but I want to see what people who are smarter than me have to say
Thanks!
Forrest931 is offline   Reply With QuoteReply With Quote
Old 07-23-2024, 09:42 PM #2
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
It would be my guess the jiggle valve on your thermostat is positioned wrong. It's supposed to be positioned at the 6 o'clock, not 12 o'clock. You'll run 10 degrees hotter at 12 o'clock.
Also, rising temps in stop and go traffic is indicative of a fan clutch problem. When you're driving down the road, wind pushing in through the grill is cooling your radiator. When you're not pushing through the air, you rely solely on the fan clutch to pull air through your radiator cooling fins.
I would investigate the whole system. First check the integrity of your radiator cap. They are known to break apart and not hold proper pressure on your cooling system. If the cap is good, I'd drain the coolant and investigate the positioning of the thermostat jiggle valve. Finally, I'd test the fan clutch, or just replace it.
You can use my videos to get the work done. By the way, I was in Santa Cruz today for a mountain bike ride.
Old 07-23-2024, 11:25 PM #3
Real Name: Forrest
Real Name: Forrest
Thanks, Timmy, I'll get that new rad thermostat and fan clutch installed when I get it and send an update.
You're the man I used your trans video to do mine.
Old 07-24-2024, 09:46 AM #4
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light
jgue467's Avatar
220 - that's right on the edge of cracking a head - hopefully not.
The 5VZ has a very robust cooling system. In central texas heat well over 105 mine idles - goes thru repeated SG - tows - off-roads slowly for miles - all under 194 and all with the AC blasting ice cubes. Yours should do the same.
2001 Limited 4WD - 350+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
Old 07-24-2024, 01:09 PM #5
Agreed - the only time I've seen over 195* or so is when something has been wrong. This includes 105*F+ weather climbing mountains off road with the AC blasting.
Tim hit the top three:
- Radiator cap - get OEM ONLY!!! This is important.
- Thermostat - OEM only, again. Jiggle valve at 6 o'clock, which is upside down to most motors
- Fan clutch - definitely a possibility at this age.
No need to upgrade the radiator or anything else (other than a transmission cooler). The only reason for an aftermarket radiator is go get the increased reliability of an all-aluminum part, not for increased cooling.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-24-2024, 01:50 PM #6
DK327's Avatar
DK327 DK327 is offline
DK327 is on a distinguished road
DK327's Avatar
Thermostat jiggle valve @6pm made the biggest difference for me.
I had purchased my 3rd gen with 232K miles on the clock back in 2016. I then ordered a scan gauge which showed 202-207F as the operating temp for my engine. After draining the radiator, I took a peak at the thermostat and the jiggle valve was oriented at 3pm. Placed the new thermostat in with the jiggle valve @6pm and refilled new coolant. The new temps were 186-191F. Huge difference!
Then in 2021 I took my car in for a timing belt/water pump job and upon completion, on my way home, the scangauge reported 210-215F temps. When I reached home, I drained the radiator again and looked at the thermostat, this time the jiggle valve was at 12pm position. Again, flipped it back to 6pm and refilled old coolant, and bam, back down to 188F.
As for what a "normal" engine temp is, I would think anything from 170F-220F can be considered "safe". I think those that are supercharged run hotter than smallfolk and do require an 170F thermostat.
00 T4R LTD V6 4WD 275K e-locker
11 RAV4 LTD V6 4WD 100K
DK327 is offline   Reply With QuoteReply With Quote
Old 07-24-2024, 05:01 PM #7
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing has a spectacular aura about GhostRing has a spectacular aura about GhostRing has a spectacular aura about
GhostRing's Avatar
I've been running into similar issues with my vehicle, but I attribute it to being gifted an UltraGauge and now I stare at the temp fluctuations constantly!
I do have 285s, plate bumper, trans cooler, min. decade old radiator/cap, and hover between 190-200 most days - short drives, stop & go, offroad often, etc.
Now, I *swear* I put the jiggle valve at 6 o'clock, but maybe it was daylight saving time when I did it, who knows...but the dash needle rarely moves
under all of these circumstances, so I'm tempted to say it's fine. I'd love to see more 180s and I think it's probably time for a fresh radiator anyway.
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 07-24-2024, 09:29 PM #8
Real Name: Forrest
Real Name: Forrest
Update
I installed my champion today temps are down about 10 degrees or so sitting around 194, lower but not quite as low as I'd like. I'll give another update when I install the new thermostat I tested my fan clutch and it seems fine but I'm going through all the trouble so I figure I'll replace it anyway with an OE replacement.
3rd gen 4runner cooling question.-img_0945-jpg
Old 07-25-2024, 04:22 PM #9
194*F is not high. How much lower do you think it should go when your engine has a 180*F/82*C thermostat? The thermostat regulates the INLET temperature of the engine, and the temperature of the OUTLET is where the sensor is for the ECU. That ~10-15*F rise is the heat getting transported out of the engine by the coolant.
There is no reason to run the engine colder... (assuming you aren't supercharged, running on the edge of pinging during regular use...) If the temp is 'rock sold' - running up and down only a few degrees under most usage conditions, your cooling system is working well. When the jiggle valve is in the wrong position, temps go up and down by a much larger amount while driving which tells you something is wrong.
As a secondary note, the factory gauge is basically a 3-position indicator - too cold (<160*F or so), fine (160-215*F) and too hot (>215*F). It doesn't show any minor fluctuations, by design.
All of this is somewhat specific to the 5vz engine - every engine runs a bit different with ideal temps, normal temp fluctuations, etc.
Old 07-25-2024, 08:24 PM #10
TracyNorton's Avatar
TracyNorton TracyNorton is offline
TracyNorton is on a distinguished road
Charlie...you running automatic, right? When you climbing (in HOT weather)...in a situation where you have to use 1st gear (lo range) for a period of time.....do you recall what rpms your engine running in that situation? Just ballpark.
I'm just analyzing some things related to a trip up to top of Silver Cyn Rd out of Bishop a couple weeks ago....and researching these threads for some baseline info.
Thx
Does anyone have a link to supplemental electric radiator fans w/ thermostat control?
Just researching something.
TIA
98 SR5 4x4 5sp w/ fact rear locker
ARB & 6112s business up front
CBI DSG & LC 862s/Tokicos party in the back
Lots of So African electrics strewn thruout
"If you haven't broken anything on your last trip...you ain't tryin' hard enuf"
TracyNorton is offline   Reply With QuoteReply With Quote
Old 07-25-2024, 08:42 PM #11
Real Name: Forrest
Real Name: Forrest
Thanks, Charlie I appreciate it, drove it around some more today and ended up in the 197-201 range. I'm sure it's fine I want to bulletproof my system so that I never have to worry about it again when 4wheeling at altitude with AC on. I also don't want to get close to over 220 again on the freeway for fear of damaging my head gasket that definitely wasn't normal and I don't want to have that happen again. the only reason I worry about it is that before Lift 285 17 tires and a bumper, I used to run a lot colder 185 ish so seeing the increase was worrying. I'll check my thermostat and replace it with an OEM. the person who owned my car before claimed he did a water pump timing belt job but I doubt it was done well if it was done because he was very dishonest.
Old 07-26-2024, 01:35 AM #12
Yeah, auto. 4Lo, locked in first is for slow driving only... if you are going up a 'road' feel free to use more than just 1st. If you are going to be above 25mph or so, you'll want to be back in 4Hi. Based on a quick google view of the trail/road you are talking about, I might even stay in 4Hi and watch trans temps.
Old 07-26-2024, 01:38 AM #13
My post above covers it well - jiggle valve, fan clutch or radiator cap...
I used to have a 'weak' thermostat that opened early and ran in the mid 180's, but now with a new (well, like 5 years old now!) it is right in the 190-193 range most of the time. The only time I've seen my 4Runner get hotter than it should was when I had a bad radiator cap.
Old 07-27-2024, 04:20 PM #14
Real Name: Forrest
Real Name: Forrest
FIXED!
I got my new OEM thermostat in the mail this morning and pulled off the thermostat housing. the jiggle valve was at 12 o'clock and upon closer inspection it looks nothing like the OEM one and has no brand name anywhere. I installed everything and refilled the coolant with OE Toyota red, went for a test drive and the hottest I got was 190, and stayed 188 to 190 the whole time so no more massive 10-degree fluctuations. I am beyond happy with the repair and added reliability of the champion radiator, I also threw on a trans cooler while I was at it.
Thank you to everyone who pointed me in the right direction, as always couldn't have done it without the T4r forum!
Old 07-30-2024, 08:25 PM #15
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I went the Koyo Aluminum radiator route. Like you, my engine temps improved with the aluminum radiator. I'm happy I went with it.
3rd , back , bumper , gen , temp
engine and Auto trans cooling question Dezerts10 3rd gen T4Rs 24 01-03-2018 10:04 AM
1990 4Runner 3.0 Cooling Problems ankara36 Problems & Warranty Issues 1 07-02-2014 07:36 PM
2006 4runner cooling problem bhebert General Discussions 6 07-24-2013 02:03 PM
3.4 V6 cooling question Cliff Engines / Suspension / Wheels / Tires / Audio / Accessories 1 05-29-2013 07:40 PM
cooling system question theizzardking 3rd gen T4Rs 1 12-13-2012 03:32 PM
