Old 07-29-2024, 06:16 PM #1
beldar beldar is offline
beldar is on a distinguished road
OEM Denso Radiator - Not Impressed
I just replaced the original radiator on my 2000 4WD Limited 3.4L with 230K miles. I am the original owner so I know it had never been replaced. Old radiator was working fine so this was just preventative maintenance. I also replaced the thermostat along with the upper/lower hoses, and flushed out the system.
The new radiator is an OEM Denso part# 16410-AZ011, which I picked up from the dealer for $152.
I thought it would be pretty much the same as the original. Not quite.
Before I get to my gripe, one thing I do like on the new Denso are the hooks on the sides that align up the bolt holes. Made the install so much easier.
So here's my complaint. Why is the petcock half the size of the original and of such low quality. When I loosen it, it wobbles almost like the fitting is off. When I hand tighten it down I feel like it's going to break off in my hand. At one point I just stopped tightening and called it good.
The new radiator does not even have the weep hole below the petcock, where you could blast pressurized water straight down like you could with the stock radiator. You have to carefully loosen it so it starts trickling, and don't dare open it up too much or it'll pop off and you will get soaked. Ask me how I know
There's no middle ground. It's either a slow trickle or full blast straight back.
I thought (for a split second) to maybe drill in a little weep hole. But then common sense prevailed, and to leave well enough alone.
edit: I didn't realize until today that there are more than one OEM radiator to choose from....so this is the "economy" line. If I wanted something closer to factory it would cost much more than I paid.
OEM Denso Radiator - Not Impressed-1-petcocks-2-jpg  OEM Denso Radiator - Not Impressed-4-opened-jpg
beldar is offline   Reply With QuoteReply With Quote
Old 07-29-2024, 06:20 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light
jgue467's Avatar
Rascals. Still a pretty good radiator though. Luck and enjoy the Runner.
2001 Limited 4WD - 350+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
Old 07-30-2024, 08:58 AM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
You answered your own question ... you get what you pay for. Although it would be nice if the dealer would let you know there are several options and what differences are, but they probably don't know.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 07-30-2024, 08:14 PM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
This is a better option than OEM.
Old 07-30-2024, 09:41 PM #5
Thanks Tim. BTW, I used your flush video, step by step, for reference and it worked great. Next up is changing the 114k, 13yo timing belt and water pump. By your video it looks pretty involved so I will get a shop to partake.
Old 07-30-2024, 10:46 PM #6
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You could easily do the timing belt with the right tools.
Old 07-30-2024, 10:49 PM #7
You know, I might take you up on that advice. Stay tuned. To note, I rechecked the last CarFax and the dealer notes say the timing belt & water pump were changed at 86K. So not 114K but 144K. So I would say I am a tad overdue!
Old 07-31-2024, 11:06 AM #8
Robb235's Avatar
Robb235 Robb235 is offline
Real Name: Robert
Robb235 will become famous soon enough
Robb235's Avatar
Real Name: Robert
This was my experience as well. When I ordered the 221-0508 Denso unit labeled as OE from RockAuto, I thought I was getting an OEM quality and style radiator. To me, the new Denso radiator just didn't feel as "solid" as my old original one. I was also disappointed with the drain, as when I opened it up all the way it just blasted everything behind it with coolant and got everywhere. Makes me wonder the true quality of this radiator, and if it's any more prone to the pink milkshake. After running for years with my radiator transmission cooler bypassed and just using my B&M external one, I hooked my transmission cooler back inline with the radiator cooler to further cool my transmission temps while towing. Hoping I didn't make a mistake by doing this.
1999 Toyota 4Runner Limited 4x4 - Turbocharged GTX3071 - URD AFR Sensor Calibrator - DW255 fuel pump - 2JZ Supra 315cc “teal top” fuel injectors - Rear Elocker Retrofit w/ 4.30 gears - 2wd Low (2Lo) On Demand - 231mm Tundra Brake Upgrade - Hayden 699 Transmission Cooler - Monitoring ATF Temps w/ My iPhone - DIY Projector Headlight Retrofit - Backup Camera Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear)
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
Robb235 is offline   Reply With QuoteReply With Quote
Old 08-02-2024, 02:58 PM #9
Jose Rizal Jose Rizal is offline
Jose Rizal is on a distinguished road
This is for sure on the list in the future. Thanks, Tim!
Jose Rizal is offline   Reply With QuoteReply With Quote
Old 08-02-2024, 06:15 PM #10
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
I'll agree with Tim, though many years ago (2011?) I had the FSM and not Tim's assistance. A buddy and I followed the take-your-time method with his tools in his garage. Took a while, but we had no problems afterward. Not one. I think we did that at around 125k miles, and I got rid of the truck at 265k.
thennen is offline   Reply With QuoteReply With Quote
Old 08-03-2024, 08:56 AM #11
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all
JoeT4R's Avatar
@ OP, I’ve been running the same radiator (made by Denso, from Toyota) same p/n, with no issues since 2018 (knock on wood). I never even paid attention to the drain valve when swapping units.
I’d be curious to know if you’ve installed an aftermarket trans cooler? That would be a great time to do so when swapping rads.
Old 08-03-2024, 11:54 AM #12
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
been running the denso since 2016. ts been fine, But will prob change it out this coming spring for safety sake as some people say every 10 years, some say when it changes color.....sadly some wait till they have a pink milkshake
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 08-03-2024, 12:20 PM #13
2TH4IST's Avatar
2TH4IST 2TH4IST is online now
2TH4IST is just really nice 2TH4IST is just really nice 2TH4IST is just really nice 2TH4IST is just really nice
2TH4IST's Avatar
I ran the denso from rock auto when I bought the 4runner a while ago with a new oem cap. I noticed that after my drive to work it would never build pressure. Tested system, it held 15psi no problem and no leaks. Tested the new cap, same held pressure.
One thing I noticed, when putting the cap on the radiator it didn't have the resistance when turning it. That's when I noticed, squeezing the hose I saw a bit of movement in the overflow bottle. So I bought a new oem cap. Same issue. Measured out the sealing steps in the cap to the sealing steps in the radiator. The radiator ended up being a few hundredths to long vs the cap! So it would never seal the pressure side of the system.
Long story short, I ended up buying the koyo radiator and cap and never looked back.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is online now   Reply With QuoteReply With Quote
Old 08-06-2024, 11:46 AM #14
Robb235's Avatar
Real Name: Robert
Robb235's Avatar
Real Name: Robert
Confirms in my mind that the Denso "OE" radiator is not nearly the quality of the radiator from the factory.
denso , oem , original , radiator , replaced
Radiator Replacement OEM vs Denso (or are they the same? 5horizonsrr 3rd gen T4Rs 18 11-16-2023 11:48 AM
3rd gen Denso Radiator (new in box) $80 kquon For Sale: T4R Items 2 05-17-2018 10:57 AM
Radiator DENSO nissanh 3rd gen T4Rs 15 04-12-2016 01:47 PM
FS: 3rd Gen Denso Radiator. Denver CO CoPhil For Sale: T4R Items 5 03-12-2016 11:05 PM
Denso: Anyone know anything about their radiator? 1985taylor1925 3rd gen T4Rs 5 01-04-2012 01:14 AM
