Old 07-31-2024, 02:06 PM #1
SgtAbn's Avatar
SgtAbn SgtAbn is offline
Real Name: Jerry Kraus
SgtAbn is on a distinguished road
SgtAbn's Avatar
Help Please! 3rd Gen Ignition / Fuel Problem
Hi Guys! This is literally my fourth 3rd Gen T4R - I'm a very big fan of the 3rd Gen T4R's! The short version of the story is this one I now have around 300K miles on it & it floods and stalls instantly for some reason. I took it to my mechanic and he says that fuel is being sent to the cylinders too fast and its causing it to flood. He replaced the Fuel Injectors + Crank Shaft Position Sensor + the Throttle Position Sensor + the ECM and it is still happening. The Mechanic literally gave up on trying to solve it and said he would give me my money back. Now it is at mechanic #2 and he has the same diagnosis, but hasn't given up yet. Any Ideas would be greatly appreciated please?
*There is a longer more detailed story but I'm afraid that will just confuse everyone..
2002 T4R Limited 4x4 w/factory locker, factory supercharger, sunroof, deck plate mod, Tundra brake upgrade, BFG TA/KOs on 17" TRD rims, automatic transmission, 3" lift from Toytec with "Old Man Emu" heavy duty shocks & springs, 288,000 miles on it, I live outside Steamboat Springs, Colorado.
SgtAbn is offline   Reply With QuoteReply With Quote
Old 07-31-2024, 05:19 PM #2
If the ECM was replaced, how was it programmed for the immobilizer (Limited should have it...)? If it 'stalls' at the same time, every time (about 1 second), it is the immobilizer shutting the engine off.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-31-2024, 06:12 PM #3
SgtAbn's Avatar
SgtAbn's Avatar
Charlie, thank you very much for that input, I did not know the T4Rs even had an in-mobilizer. Would the Factory Service Manual have instructions on how to reprogram it?
Old 08-01-2024, 03:19 PM #4
'00-'02 Limiteds had an immobilizer (which is separate from the alarm system...). If you have the 'fat' keys, you have the immobilizer - not just the plastic body key, but the 'fat' plastic body keys.
I haven't looked through the FSM for any programming procedures (not needed for my SR5).
Old 08-02-2024, 01:14 PM #5
SgtAbn's Avatar
SgtAbn's Avatar
Thank you Charlie, you've been a big help Sir :-)
3rd , fuel , gen , mechanic , story
Ignition Problem 906-Runner 3rd gen T4Rs 8 05-04-2020 06:29 PM
Ignition/key problem wslytoy 3rd gen T4Rs 6 05-04-2018 12:55 PM
Fuel / Ignition Gremlins (3RZ-FE) selfish 3rd gen T4Rs 24 02-16-2015 09:57 AM
Disabling ignition and fuel pump POPSRNR Maintenance/Detailing 2 06-07-2008 11:25 AM
Ignition Problem crdean1 3rd gen T4Rs 0 02-28-2008 04:40 PM
