Old 07-31-2024, 02:07 PM #1
dustin Keeler's Avatar
dustin Keeler dustin Keeler is offline
dustin Keeler is on a distinguished road
2001 Starting/Charging issue Please help
My sons 2001 4x4 auto is having issues starting. We could always jump it and within the last few days we have replaced the alternator and Battery that both tested defective. We also replaced the battery terminals while it was all apart.
He comes home for lunch today and it is acting like it has a dead battery again.
After swapping everything out it has been running perfect. He checked the Alternator fuse, and it was good. I am at work and can't test to see if the alternator might have failed again but is there anything you guys have encountered as to another item I am not thinking of?
I appreciate you guys.
2000 4Runer SR5 3" Rough Country lift on 265/75/16
dustin Keeler is offline   Reply With QuoteReply With Quote
Old 08-01-2024, 07:45 PM #2
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light
2TH4IST's Avatar
Could be that you have a new bad alternator. Or a massive drain on the battery. Have you checked grounds? Main one on engine block by oil filter (on 5vz). Also the little ground to the body? Is the alt and starter power nuts tight?
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 08-02-2024, 01:43 PM #3
Bad alternator could definitely be it, especially if it isn't a quality Denso (reman BY Denso) alternator. A bad diode might not have been caught by a cheap rebuilder, which could then be causing the drain when off.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-02-2024, 02:26 PM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
If you don't own a multi-meter, get yourself one. With the multi-meter, you can quickly see what the charging volts are at with the engine running and connecting the test leads to the posts on the battery. A healthy alternator should be putting out somewhere around 13.8 to 14.2 volts.
alternator , battery , guys , replaced , swapping
Charging issue Flighht2k Lexus GX470/460 3 05-29-2019 09:20 PM
charging issue gsalazar 3rd gen T4Rs 0 03-11-2013 09:59 PM
charging issue chris001979 Classic T4Rs 5 02-21-2013 01:30 PM
charging issue k_schutte Classic T4Rs 7 12-27-2010 10:42 AM
Charging Issue NEED HELP ASAP!!! RunnerUp Engines / Suspension / Wheels / Tires / Audio / Accessories 4 02-07-2007 08:32 AM
