Old 08-08-2024, 12:07 PM #1
stevew092984 stevew092984 is offline
stevew092984 is on a distinguished road
Still having acceleration issues
I thought I had fixed this issues with tightening the slack on throttle cable, but it still seems to lack torque on inclines. On the freeway if there’s any sort of incline, I can’t get the truck past 65 mph. I have a 98 limited 3.4l. 6 and just did a 30k miles service. Any ideas why I’m experiencing this lack of what I feel is torque power? Feels like I’m driving a fully loaded box truck up a mountain highway.
stevew092984 is offline   Reply With QuoteReply With Quote
Old 08-08-2024, 03:25 PM #2
spartacus's Avatar
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
spartacus's Avatar
Could be a TPS issue. Test the tps
Opinion on TPS Sensor/Engine Code
Old 08-08-2024, 04:29 PM #3
Wouldn’t that throw the check engine light?
Old 08-09-2024, 02:30 PM #4
prybar's Avatar
prybar prybar is offline
prybar is on a distinguished road
prybar's Avatar
is the lack of power new? You kinda have to build up speed before hitting hills on the freeway. I get passed by semis all the time. It's just a toyota thing lol
'99 Limited, 260k
prybar is offline   Reply With QuoteReply With Quote
Old 08-09-2024, 02:57 PM #5
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Nope...
If thats true, that's not normal. My 4runner with 400k+ has no issue passing or climbing hills and gaining speed in the process and will pull rpm pretty much to redline.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 08-09-2024, 04:45 PM #6
Had to take it in to a mechanic and he told me that my cat and O2 sensor (the one before the cat) were bad. That’s something I didn’t want to hear because I had just bought that cat in November because I couldn’t pass smog with one that was on the vehicle when I purchased it. No serial number anywhere.
Old 08-09-2024, 05:37 PM #7
prybar's Avatar
prybar's Avatar
Originally Posted by Twisted Sid View Post
Nope...
lol i don't redline mine. I was kinda exaggerating. It's one of the most common toyota jokes. They're not underpowered, but definitely not overpowered either. They're not that fast but that's why we love them.
'99 Limited, 260k
Old 08-09-2024, 05:38 PM #8
prybar's Avatar
prybar's Avatar
dang, a new cat clogged in under a year? You might want to check if you're burning oil or have coolant getting into your combustion system, cause that shouldn't happen that quickly
'99 Limited, 260k
Old 08-09-2024, 11:54 PM #9
Sorry if I sound uneducated when it comes to mechanics, but how would I check if there’s burning oil or coolant in the combustion chamber?
Got the truck back from the mechanic and I asked him how I can avoid this happening again and he told me it could be a number of things. He then asked what gasoline I used and I said I use Costco exclusively to fill up. He then told me that’s my problem right there. Said 8 out 10 people who go to his shop for emission problems are using Costco’s gasoline. I’m not too sure how I feel about that. Any thoughts?
Old 08-12-2024, 11:55 AM #10
prybar's Avatar
prybar's Avatar
An easy way is to monitor your oil and coolant levels to see if/how quickly they're dropping. Smoke coming out the exhaust is another tell tale sign, but not always present. You can check your spark plugs to see if they have any buildup or anything, or even look at your cylinders with a boroscope to check for excessive buildup. Compression test/leakdown test might be the only surefire way to check, there are writeups on how to do that on the forum. There are probably other ways that other forum members might be able to chime in about.
I can't speak to costco gas, I haven't heard of any problems with it but I suppose it could be an option. As far as gas, I think any modern gas from a reputable company (chevron, 76, arco, sinclair) should be fine, as gas these days is so much better than it was 20 years ago. I've always used arco gas and haven't had any issues, though I have had the P0420 code for my entire ownership of the car.
'99 Limited, 260k
Old 08-15-2024, 10:51 PM #11
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
Just did a 30k mile service? How many miles on the truck?
Did this start after the service?
Anything special in the work order from your service that might hint towards what the mechanics did?
1997 4Runner SR5- ~376k Miles and counting
2007 4Runner Limited V6- 175k Miles
2011 VW JSW TDI- 150k Miles
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 08-16-2024, 11:39 PM #12
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I know you tightened your throttle body cable but to fix the gas pedal slack for good, replace the deteriorated bushing on the gas pedal. This will firm up your slack 100%. Creds to sleepydad!
https://www.toyota-4runner.org/2936430-post153.html
2000 4Runner Limited 4x4 V6
issues , i’m , lack , torque , truck
Acceleration issues stevew092984 3rd gen T4Rs 1 08-02-2024 10:28 PM
2000 4WD Acceleration Issues... AutomatiX 3rd gen T4Rs 8 08-23-2019 11:35 AM
Acceleration/hesitation issues Jdhulse74 3rd gen T4Rs 5 01-15-2015 01:25 AM
Acceleration issues GoneMudding Classic T4Rs 2 04-25-2011 02:25 PM
95 4R acceleration issues coachie Problems & Warranty Issues 0 03-24-2008 05:49 PM
