Old 08-15-2024, 02:03 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Heater Valve Leaking
I got back home and found dried coolant (I told my parents to drive it) on what I believe is the heater valve?
I don't know if it's the valve or the hose clamp, but I'm going to replace the old valve before it gets worse. Should I go OEM for this part? To change it will I have to partially drain the coolant?
Heater Valve Leaking-img_5498-jpg
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 08-15-2024, 02:41 PM #2
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light 2TH4IST is a glorious beacon of light
2TH4IST's Avatar
I'd go oem, as it has lasted that long already. It could also be the connecting hoses weaping. You can use hose clamps to clamp the hoses so coolant won't leak out, swap out the valve, when done take off the clamps and your in business. Burping the system is recommend after that though.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 08-15-2024, 03:01 PM #3
96RedRunner's Avatar
Real Name: Mark
96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold
Real Name: Mark
I'd go OEM get the hoses and clamps while at it. Search by your VIN for correct part #
TOYOTA 4RUNNERVZN185L-GKPZKA - ELECTRICAL - HEATING AIR CONDITIONING WATER PIPING | Japan Parts EU
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress not stock.
2011 Audi S5 Prestige 4.2 V8 6 spd. MT not stock.
Old 08-16-2024, 07:17 AM #4
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light
jgue467's Avatar
I've gone thru 4 OEM heater valves in 200k of owning my '01.
Its got an original (never opened) AC - original rear brake seals - original alot of things yet that part fails and fails - weird.
Its the highest point on the cooling system - just remove it and replace - no draining needed.
2001 Limited 4WD - 350+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
Old 08-16-2024, 09:21 AM #5
Real Name: Mark
Real Name: Mark
Its got an original (never opened) AC.
Fails maybe use related maybe, we live same climate 374k 18 yrs 96Red, 01 231k 7 yrs.
both original I function heat weekly old habit like E-brake.
Original AC be knocking on wood, Filter/dryer in the fubar stage of service life.
Desiccant cartridge breaks up complete system is toast, $25 part vs $1600 in 2012 dollars.
You're at the milage I'd change it.
Old 08-16-2024, 10:57 AM #6
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
I have not changed one, but have an oem on shelf and plan to do as preventative soon. I think I have read in other threads that there is another small plastic pipe near the valve that can be brittle and break as well when your doing the swap out of the valve
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 08-16-2024, 01:53 PM #7
GhostRing's Avatar
GhostRing GhostRing is online now
GhostRing is a jewel in the rough GhostRing is a jewel in the rough GhostRing is a jewel in the rough
GhostRing's Avatar
Yes, be very careful pulling hoses off - even with the correct tool.
My hoses survived, but a chunk off the valve stayed in the firewall hose.
Glad I caught it before reassembly!
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is online now   Reply With QuoteReply With Quote
Old 08-16-2024, 06:00 PM #8
jgue467's Avatar
jgue467's Avatar
Very interesting. Of course in central texas I Need heat maybe once or twice in Nov-Dec and then some in Jan-feb and then all AC. So that may explain that.
So to replace dryer system has to be evacuated and recharged - correct?
It has always blown snowballs - best AC of any vehicle I've ever owned so I'd like to keep it that way - thanks for passing that info along!
Old 08-17-2024, 08:44 AM #9
Real Name: Mark
Real Name: Mark
Correct. Easy DIY job using equipment rented at parts store, time of year shop repair comes with guaranty.
Hi-jacking thread DM me for some finer diy details you want em.
Old 08-17-2024, 10:10 AM #10
Real Name: 3 Bears
Real Name: 3 Bears
funny im just the opposite. I maybe needed ac once or twice a year....maybe a hot year for a week. Used so little that I disconnected the belt. its such a dry cold here that dont need the ac part to defrost windows.
1969 kharmann ghia
Old 08-17-2024, 11:14 AM #11
DJRodriguez88 DJRodriguez88 is offline
DJRodriguez88 is on a distinguished road
happened to me >_<. the nipple on my valve broke off while driving and dumped my coolant.
Just unbolt the old one and pop in the new one then replace any coolant that may have dropped before or during the install, burp/bleed, and done.
DJRodriguez88 is offline   Reply With QuoteReply With Quote
Old 08-18-2024, 11:27 AM #12
Real Name: Mark
Real Name: Mark
Thread hijack talking AC filter/drier Coolant in AC system not good idea.
coolant , heater , replace , valve , worse
Heater core leaking crimedog 4th Gen T4Rs 14 11-15-2024 12:31 PM
Heater Valve Novashards 3rd gen T4Rs 16 02-22-2022 12:53 AM
leaking heater core? infinitysa 3rd gen T4Rs 1 06-16-2014 10:35 PM
Heater Control Valve Leaking...Rebuild? UTEP 3rd gen T4Rs 1 10-15-2013 03:16 PM
leaking heater control valve... jamess 3rd gen T4Rs 0 11-08-2009 10:02 AM
