Old 08-19-2024, 12:37 PM #1
whibby's Avatar
whibby whibby is offline
whibby is on a distinguished road
whibby's Avatar
3.4 Low Power Until Beating the Hell out of It?
Hey all,
I have a 3.4 swapped 2nd gen. Been chasing this issue for the better part of 5 days now. Lots of variables as everything on my car has been screwed for a long time but not like this.
What's happening is On a cold start, I idle fine, and get to 2k fine. After 2k it begins to groan bad and has absolutely no power. This is until I slam the gas off and on for a few minutes and have it drop gears (auto trans). Though, atleast regarding coolant temp, it is not solved once reaching OT. After about 5 minutes of doing this the car is fine. This stops it from lugging too much after (like 85% better) for the rest of the drive. Previously last week it was not doing that though, just wouldnt move without being at 5k.
I've redone the wiring on the MAF as it was beat, and cleaned it. Numbers appear within spec. 3.5-4.5 g/s at idle, ~40 at 2500rpm.
Fuel trims appear normal too less than +/- 10 on LTFT B1 and STFT B1. Except my B1S2 STFT sensor is permanently stuck at a reading of 99.2. But to my understanding, since its downstream, it does not change fuel trims and the overall bank reads the same as sensor 1. Instead just throws a cat code if it fits parameters.
Been running Technron through it, which honestly might be the reason it's cleared up, but just seems weird that it's mostly fine after a few mins of beating it. Doesnt seem conducive to a fuel pump/filter.
Wondering if its my trans (A340H)
Anyways long post, but desperate
Video is pedal to the metal, and also exhaust leak sounds dramatic but is downstream past sensors.
https://www.youtube.com/watch?v=LA2N7lGxvBs
whibby is offline   Reply With QuoteReply With Quote
Old 08-21-2024, 10:47 PM #2
ARTHUR4STX ARTHUR4STX is offline
ARTHUR4STX is on a distinguished road
Theory 1
Check the valve cover bolts
PCV
throttle body elbow
Coil packs
Spark plugs
Wires
Coil pack boot might have white ash marks
ARTHUR4STX is offline   Reply With QuoteReply With Quote
Old 08-22-2024, 01:43 AM #3
ZSW99 ZSW99 is offline
ZSW99 is on a distinguished road
I have no good explanation of why but the downstream sensor does have an affect on how the engine runs. I had a mystery issue causing lean codes and stalling when hot that I chased for nearly a year. I replaced basically everything ignition and fuel related until finally doing the o2 sensor and it fixed it. Some people speculated than the downstream sensor only affects the tune long term which kinda makes sense to me but idk for sure
98 Base 4x4 3rz 380k
96 Taco rcsb 4x4 3rz 320k
ZSW99 is offline   Reply With QuoteReply With Quote
Old 08-22-2024, 01:34 PM #4
The downstream sensor is probably used to 'tune' the response of the main AF sensor on trucks so-equipped ('99/'00 CA emissions and all '01/'02's). Both work together...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-26-2024, 08:36 PM #5
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
I experienced a lack of power until I got open loop which is pretty much beating on it. Replaced the front o2 sensor and it fixed it. Accelerating in closed loop was a real slob.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
downstream , fine , fuel , idle , sensor
Transmission Pan Beating... Oops... 007Tacoma 5th gen T4Rs 11 06-15-2017 12:49 AM
Am I beating a dead horse? Plumber 4th Gen T4Rs 0 04-10-2014 08:35 PM
Help, my new BF Goodrich KO's are beating me to death. Tbird45 4th Gen T4Rs 17 02-28-2014 02:00 PM
Ever seena 4th Gen take a beating from hell? Video OJwerks 4th Gen T4Rs 7 08-17-2012 08:34 AM
Am I beating a dead horse? socal4rnr 5th gen T4Rs 0 02-27-2011 06:14 PM
