Old 09-06-2024, 08:20 AM #1
DWilliam DWilliam is offline
DWilliam is on a distinguished road
Almost to 150k miles. What maintenance should I do?
Current Codes: P0301 and P0171. I'm hoping injectors will do the trick.
Already done: timing belt, water pump, belts, plugs, wires, coil (bank 1 misfire, didn't stop the code), fuel pump.
Planning on: injectors, valve cover gasket, lower ball joints, fuel filter, and brakes (tundra 199mm upgrade?)
What else should I have my mechanic take care of while it's in the shop? Are there other gaskets I should replace while the injectors are being replaced? I'd like to set myself up for another 100k miles, despite the two codes listed above.
DWilliam is offline   Reply With QuoteReply With Quote
Old 09-06-2024, 10:52 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light jgue467 is a glorious beacon of light
jgue467's Avatar
So there's a miss in cyl 1 - pull that plug to see whats up.
0171 could be the fat air hose between the maf and intake plenum - the ribs hide tiny cracks that may not really open much at idle yet under throttle will causing a lean condition - I used oem for that part.
Besides manual's list of maint. and what you've already done - I would add a new radiator if over 10yrs old (date stamp on it) or it looks brown vs grey - this is mostly to avoid the pink milkshake potential (add a radiator cap & new thermo -185 - if you can find one + new fluid).
Depending on temps in your area and/or whether towing is expected - an external trans cooler (in-series with existing factory one) can be a real life extender to the trans.
Brake fluid swap + TC and diff fluids. Then there's the pwr steering fluid...I just use a turkey baster on that.
There's a good sticky above on Maintenance with lots of How To info - best of luck and enjoy the Runner
2001 Limited 4WD - 350+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
codes , fuel , injectors , miles , pump
Maintenance - 4Runner Approaches 150K alaskaman 4th Gen T4Rs 7 11-16-2017 07:43 PM
Just hit 150k time for some maintenance foxrider56 3rd gen T4Rs 7 03-16-2014 03:44 PM
150k+ mi 4th Gen 4Runner maintenance JohnnyTron 4th Gen T4Rs 7 03-07-2014 02:53 PM
150K Maintenance? gkinng 3rd gen T4Rs 2 11-15-2013 10:23 PM
Maintenance at 150K miles Roguestatus1688 3rd gen T4Rs 4 11-13-2013 01:28 PM
