Old 09-13-2024, 05:50 PM #1
Reidabook Reidabook is offline
Reidabook is on a distinguished road
Climate Control Lights dim when braking
I have a weird issue in my 4runner. When I push on the brake pedal the lights in the digital climate control switch from the bright mode to the dim night mode. The actual switch on the stalk is in off position. When it's in the middle or forward position the lights stay in the dim mode like they should. It only seems to happen on the climate control, the clock functions normally. I don't have leds bulbs in the climate control just the regular bulbs or led taillights, I know those sometimes do weird electrical things. Anyone else had this problem or know what might cause this?
Reidabook is offline   Reply With QuoteReply With Quote
Old 09-13-2024, 05:58 PM #2
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
I'd start by checking the battery and alternator. If, for some reason, the battery/alternator are just bbbbarely providing enough power, it might cause one system to draw from the rest.
If you were to say, turn on the headlights, do you get the same results?
1997 4Runner SR5- ~376k Miles and counting
2007 4Runner Limited V6- 175k Miles
2011 VW JSW TDI- 150k Miles
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 09-16-2024, 12:22 PM #3
Step 1, check the grounds in the back and unplug any trailer wiring converters (the OEM one goes bad at this age, so remove it to eliminate the risk during debug). Grounds inside below where the tail light wiring enters the cab.
You will also want to check if the corner lights or cluster lights come on at all. With a helper, check all the other lighting, etc. around the truck at night to make sure it is doing exactly what you expect.
There is also a risk that there could be a broken trace on the flex PCB on the back of the gauge cluster, which can link systems that otherwise seem totally disconnected.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
climate , control , dim , lights , mode
Climate control lights wifestoy 4th Gen T4Rs 15 06-22-2020 06:50 PM
Installed ProComp lights, now the climate control lights don't work 94stick Classic T4Rs 1 04-21-2014 09:53 AM
Climate control lights Grouchy Wings 3rd gen T4Rs 3 11-11-2013 12:48 AM
how to fix climate control lights? ///Mracer 4th Gen T4Rs 3 07-17-2009 03:15 PM
Lights on control climate.... dalmo 3rd gen T4Rs 2 10-05-2008 02:26 PM
