Old 09-15-2024, 07:17 PM #1
Zhehan Zhehan is offline
Zhehan has a spectacular aura about Zhehan has a spectacular aura about Zhehan has a spectacular aura about
DIY Alignment Tools
I needed a front end wheel alignment for a couple of reasons:
1. The outer edge of the right front tire was showing some wear and feathering. Looking at that wheel/tire from the front of the truck showed it was tilting outward at the top a little bit, so Positive Camber was a problem.
2. The steering wheel wasn't centered.
Any shop willing to touch my truck with all the aftermarket parts on it wanted $130-$170 to do the alignment. Luckily, our front suspension is pretty simple and the rear isn't adjustable without aftermarket adjustable arms. I had done alignments professionally decades ago, so I had that experience to rely on as well. I planned to rotate the tires while I was at it since it was time.
I bought a set of Wheel Toe Alignment plates, a Camber/Caster measuring tool and a Steering Wheel Holder.
Here's what I got:
Amazon.com - Toe Plates
Amazon.com - Camber/Caster tool
Amazon.com - Steering Wheel Holder
They all worked as advertised and made the job pretty simple. My steering wheel is now straight, the Camber and Toe are correct, the truck drives straight and the steering feels great. All told, I paid $85.59 for the tools and I can use them on more than just the 4Runner.
There a plenty of videos out there on how to use these tools. The instructions that come with the Toe Plates aren't that great. The only real downside to the Toe adjustment job is that you have to remove the front wheels to use the Toe Plates.
My wheels are kind of deep, making it a bit difficult to read the Camber gauge, but I still got the job done. I was right and there was at least 1* of positive Caster which was causing the outer edge of the tire to wear. I
It was worth it to me to save money and do the job myself.
That is all. Carry on.
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 09-15-2024, 10:01 PM #2
2TH4IST's Avatar
2TH4IST 2TH4IST is online now
2TH4IST is just really nice 2TH4IST is just really nice 2TH4IST is just really nice 2TH4IST is just really nice 2TH4IST is just really nice
2TH4IST's Avatar
Sounds good. I too will probably have to do this as I can't find a competent shop that can work with the spc upper front control arms. I have cam eliminators on the lower arms.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is online now   Reply With QuoteReply With Quote
Old 09-16-2024, 12:22 AM #3
A LOT of shops are just "Toe n Go" when it comes to alignments. Additionally, shops nowadays don't want to work your vehicle if you worked on it yourself or have custom parts. Liability, I suppose? It's really f*cked. Pay a lot of money for a crappy job, or get outright refusal to do the work. There are shops here who work on modified vehicles, but you have to pay for that privilege.
Good luck with your alignment if you decide to go the DIY route.
Old 09-16-2024, 12:57 AM #4
KD5NRH KD5NRH is offline
KD5NRH is on a distinguished road
You fancy lads never cease to post stuff that threatens my budget. What ever happened to a couple of strings and a machinist rule?
Are you able to Photoshop it on like they do in the Amazon listing, or do you actually have to get stuff out of the way first?
KD5NRH is offline   Reply With QuoteReply With Quote
Old 09-16-2024, 10:22 AM #5
As I mentioned in my original post, you have to remove the wheels in order to install the Toe plates. That's the downside. The upside is that they seem to be well made and include 2x tape measures. Metric tape measures, but that's not a big deal to me. The Camber/Caster tool does not require you to remove the wheels and it's probably better if you don't.
Here's a video on using Toe plates that are similar to mine: https://youtu.be/BkYpgKhfMV8?si=AyGr_jbx6N3oVqXK
Here's an entertaining video of how to use the Camber/Caster tool: https://www.youtube.com/watch?v=DQy_OwtrRsk
Old 09-16-2024, 11:09 AM #6
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
thanks for sharing this, I will be doing mine soon
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 09-18-2024, 09:23 AM #7
YW. Hope it goes well!
Old 09-19-2024, 12:38 AM #8
Where exactly are you putting the jack stands for this? I'm assuming you're keeping the suspension loaded, but where's the most stable spot for that on the RWD 3rd gens?
Old 09-19-2024, 11:18 AM #9
For the Toe alignment, you don't need the suspension loaded, so I'm just supporting the truck on the frame rails. I made the Camber adjustment with the wheels on the ground. The alignment cams are easy to move if they aren't rusted in place, even with the weight of the truck on the wheels. That's how it's done in the shop, but they have the advantage of movable wheel pads. You can also buy those if you want to get real fancy. Without those the only thing you need to do is cycle the suspension to check your adjustments. So, either jack it up to lift the wheels off the ground, and then drop it back down, or move the steering wheel back and forth whilst also moving the truck.
Hope this helps.
Cheers
Old 10-14-2024, 11:52 AM #10
Real Name: 3 Bears
Real Name: 3 Bears
so looking at my calipers the other day while switching to winter wheells/tires and thinking of doing a self alignment in a month or so...and looking at the tools listed,,,does the toe plates clear the calipers ? running tbu if that makes a difference.
also a lot of specs list degrees, how do I change that using tape measure to inches...or do you just go with getting both tapes to read the same ?
next time you do it take pictures.
1969 kharmann ghia
Old 10-14-2024, 04:52 PM #11
The Toe Plates will probably not clear your Tundra calipers.
0.1* = 1/16"
1/16" = 1.58mm
It's not very much toe-in, but you want the front measurement to be the smaller of the 2. It's easy to read the markings on the tape measures this system comes with. They are metric. So, a little less than 2mm's toe-in is what you're shooting for.
This isn't the only way to do this at home. There are ton of tutorials on other methods. The Camber/Caster tool is pretty handy though.
Old 10-14-2024, 06:49 PM #12
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
0.1* = 1/16"
1/16" = 1.58mm
Just to be clear, is that 1/10th of a degree or 1 degree = 1/16"??
2004 Limited V8
Old 10-14-2024, 09:18 PM #13
Atimm693 Atimm693 is offline
Atimm693 is on a distinguished road
I have a similar set and have used it with success. It's a pain to schedule an alignment and wait around for hours.
I have used it both with the wheels on the ground, indexing the toe plates off of the lip of the wheel, or with the wheels off indexing on the rotors. The former is more difficult to adjust, but I believe it's always best to do the toe adjustment at ride height. No matter how you place your jack stands, I've found it pretty much impossible to get the suspension at the same height on them versus with the wheels on.
Atimm693 is offline   Reply With QuoteReply With Quote
Old 10-15-2024, 12:29 AM #14
Real Name: 3 Bears
Real Name: 3 Bears
The Toe Plates will probably not clear your Tundra calipers. .
crap
1969 kharmann ghia
Old 10-15-2024, 12:06 PM #15
1/10 of a degree = 1/16" concerning the Toe adjustment
front , job , steering , toe , wheel
Alignment tools for the 3rd generation Toyota 4Runner enginelover 3rd gen T4Rs 11 12-26-2021 02:08 PM
Your favorite tools for wrenching / tech tools for special applications Jhelms 3rd gen T4Rs 340 09-19-2021 10:20 PM
Kobalt tools seem to be getting phased out. What mid-level tools do you guys prefer? repo Off Topic 12 04-20-2019 11:24 AM
MOVING SALE IN NH: Tools, drill press, yard tools, etc clemson4r For Sale: Non-T4R Items 0 06-16-2016 08:49 PM
FS: Mac tool box, tools, cart, diag tools lot. IL Nikkshepherd For Sale: Non-T4R Items 16 04-20-2016 05:34 PM
