Old 09-18-2024, 09:50 PM #1
beldar beldar is offline
beldar is on a distinguished road
Water outlet leaking
Hey guys.
I recently did my timing belt, water pump, t-stat, and cam seals (thanks Timmy, you talked me into it!) and after putting
everything back together I noticed a coolant leak around the pump. Wow, I thought I did everything right. Went back in and after
removing the #3 timing cover, hooking up the hoses and pressure testing the system, I could clearly see a leak at the water outlet.
I thought it was just the gasket but after removing it I could see a hairline crack on the outlet. Oops! This was all my fault as
I remember accidentally smacking the outlet with a breaker bar early on.
So I thought this would be an easy fix. I bought a metal gasket from the dealer, and then bought a Gates water outlet, which
came with its own paper gasket. I used the metal gasket without sealant and tried torqing it to 14 ft. lbs.
But it just kept tightening and tightening and something didin't seem right. Then I ended up breaking one of the studs.
It never hit 14 ft lbs before the stud broke.
My question is are these Gates water outlets supposed to have a completely flush surface, because this one was pretty rough.
It might be ok with the included paper gasket and sealant, but with the Toyota metal gasket I could not get it to tighten
down.
Does anyone know the part number for those studs with the torx head? Nevertheless, I will hit the local pick-n-pull tomorrow as they have
a couple 4runners and look for the studs and water outlet if I'm lucky. Or should I just spring for the $55 dealer part that should mate
the metal gasket? I'm so close, it's killing me.
Here are some pics.
Water outlet leaking-surface-jpg  Water outlet leaking-crack-jpg  Water outlet leaking-rough-jpg  Water outlet leaking-compare-jpg
beldar is offline   Reply With QuoteReply With Quote
Old 09-18-2024, 11:36 PM #2
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all
2TH4IST's Avatar
Yes, go to the junkyard and grab that outlet and the studs from the donor 4runner, they are a reverse torx, probably a e5 or e6. I did that for my lower water pump outlet as mine was badly corroded from the junkyard.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 09-19-2024, 07:42 PM #3
I stopped by Pick-n-Pull today and picked up 2 water outlets and a handful of those torx studs.
Again, when torqed down to 14 ft lbs, I broke another stud. So 14 is incorrect.
I looked in the FSM and could not find any torqued specs for the water outlet.
Any guesses?
I'll start at 10 and start pressure testing. Then slowly increase torque until it stops leaking under pressure.
Old 09-19-2024, 10:15 PM #4
2TH4IST's Avatar
2TH4IST's Avatar
Fsm says 13 ftlbs. Make sure your torque wrench is accurate. I've done this a few times and I always torque 13 ftlbs without any issue.
Water outlet leaking-20240919_191323_emutvw496k-jpg
Old 09-19-2024, 10:34 PM #5
Thanks!
It sure is a fine line. I'm being verrrrrry careful to not strip the threads.
I started at 10 ft lbs, and it's about 99% drip free. Crossing fingers and will bump it back up to 13 tomorrow.
Do you know if the OEM metal gasket is a once-use gasket like the water pump?
Old 09-20-2024, 10:52 AM #6
2TH4IST's Avatar
2TH4IST's Avatar
In a pinch you can reuse a metal gasket like that outlet, while the wp has a rubber inner ring thing that can not be used.
Old 09-20-2024, 11:55 AM #7
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
if the fsm says 13 pounds and your breaking at 14 you need a new torque wrench
I personally dont like reusing gaskets, while I cant speak for this one, some metal gaskets are made in such a way that they act as "crush seal" and only crush one time
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 09-20-2024, 05:19 PM #8
I ended up removing the junkyard outlet and installing an aftermarket outlet + paper gasket from NAPA that I had shipped to store last week but never picked up.
I wanted to try a new Toyota metal gasket but the local dealers were out of stock. So I went and picked up the water outlet from NAPA.
I was able to get it torqued to 12.75 ft. lbs, and there is no leaking under pressure, hurray! 13ft lbs and it just wanted to keep tightening,
so I backed it down to 12.75 and got it to click. It just makes me nervous torquing to aluminum. The last thing I needed was stripping the lower intake threads.
Here is the torque wrench I used;
Amazon.com
It worked just fine for all the other torque settings for the timing belt job.
Next I'll be be doing the rear hood lift and say goodbye to the prop rod.
Thanks guys!
Old 09-20-2024, 10:49 PM #9
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner has a spectacular aura about Sparky 97Runner has a spectacular aura about
Glad to hear you got it together and working but it sounds like your torque wrench is over torquing. I agree with 3bears you need a new torque wrench.
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 09-21-2024, 09:08 PM #10
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
Get a good name brand professional grade torque wrench (Snap On, Cornwell, Matco, Mac Tools etc.) An 8mm stud should not break at 14 ft lbs.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
gasket , metal , outlet , studs , water
95 3.0 coolant leak from water outlet gasket Bjankins1 Classic T4Rs 0 10-04-2022 02:31 PM
Water Leaking in MarkBlack 3rd gen T4Rs 3 12-27-2019 09:15 PM
easiest way to get to the water by-pass outlet Steven94 Classic T4Rs 12 07-27-2013 01:24 AM
resealing 3vze water outlet hoe_nah Classic T4Rs 8 02-28-2012 05:45 PM
Coolant leak at Head Bolt and Water Outlet? NuckaMan Classic T4Rs 0 10-18-2007 12:12 AM
