Old 11-11-2024, 06:03 PM #16
Kmurt's Avatar
Kmurt Kmurt is offline
Kmurt will become famous soon enough
Kmurt's Avatar
UPDATE #2
Out with the old rack and bushings and in with the new. New OEM steering rack and outer tie rods. Energy Suspension "D" shaped polyurethane bushing on the passenger side of the rack. Energy suspension sway bar bushings and just some Rock Auto sway bar end links installed.
I went ahead and got an alignment done right after and I'm still having the same issue but I think I have narrowed it down to the possible causes. Everything was tightened and torqued to spec as well. I originally applied some silicon grease inside the "D" shaped bushing on the steering rack and now I'm thinking I shouldn't have.
And two, I think I might be missing or just have the wrong hardware to connect the driver side bushing on the rack with the long bolt and washer allowing the rack to also move and not fully tighten the bushing.
Can anyone that has known OEM steering rack hardware confirm if this is the right setup or not? This diagram shows a washer but it looks like it mounts on the other side of the rack? Front steering gear & link for Toyota 4Runner VZN185 - Auto parts - Amayama
I've attached a video and pictures. Let me know what you think. I want to drive my 4runner again!!!
https://youtu.be/d7rNW8YIMVQ?si=7pmuTB7ZWM3_SfLZ
The suspect washer....
IMG_2920
And the other side of it...
IMG_2926
IMG_2922
IMG_2923
After removing the silicon grease from the inside of the bushing...
IMG_2925
IMG_2927
2001 4Runner SR5 4x4
Kmurt is offline   Reply With QuoteReply With Quote
back , steering , straight , turn , wheel
Steering Wheel Issue Hadelson 5th gen T4Rs 2 05-16-2020 03:58 PM
Steering Wheel Control Issue with Lights xnodesirex 5th gen T4Rs 0 06-19-2019 04:56 PM
Steering Wheel shake/ vibration (not a tire issue) Mullett757 4th Gen T4Rs 15 08-09-2018 10:42 AM
Aftermarket head unit, Factory JBL with steering wheel controls issue aceshi21 4th Gen T4Rs 5 02-19-2017 10:32 PM
Steering wheel re-cover and cold tranny issue Axewhlder 3rd gen T4Rs 3 02-06-2012 04:26 PM
