Old 09-23-2024, 02:59 PM #16
brokedownwallet brokedownwallet is offline
brokedownwallet is on a distinguished road
When do y'all recommend going through a full bushing replacement? About to hit 200k on my 3rd gen and wondering if it's time
brokedownwallet is offline   Reply With QuoteReply With Quote
Old 09-23-2024, 06:58 PM #17
mendozer mendozer is offline
mendozer is on a distinguished road
Originally Posted by mtbtim View Post
I'd definitely go with Whiteline over Energy Suspension for the Front Lower Control Arms. I'd also use Whiteline for the Rear Upper and Lower Control Arms.
Energy Suspension is good for the Steering Rack and Sway Bar Bushings.
@infamousRNR and I have videos for all these bushing swaps on our Timmy the Toolman YouTube Channel. Just do a search on our channel and you'll find what you're looking for.
Timmy The Toolman - YouTube
Oh I'm VERY familiar with the channel lol I use it all the time. Great job. I ended up finding good ebay deals on OEM. So I got OEM UCA, LCA, front and rear, UBJ, cam bolts/sleeves, then I got the ES sway bar mounts and trailing arm bushings.
It's hard to find the 2nd gen sway bar links too (bc I'm lifting 2"). I went with Moog. hopefully it lasts although I highly doubt it will.
mendozer is offline   Reply With QuoteReply With Quote
Old 09-23-2024, 07:35 PM #18
Zhehan Zhehan is offline
Zhehan has a spectacular aura about Zhehan has a spectacular aura about Zhehan has a spectacular aura about
You're due if you've never replaced anything. Like, way overdue.
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 09-23-2024, 07:39 PM #19
These 2nd Gen T4R rear end links seem to hold up: https://www.oreillyauto.com/detail/c...-4runner?pos=0
Hope this helps
Cheers
Old 09-23-2024, 10:20 PM #20
mine is at 233k and I bought it with 125k. No idea on if these bushings were done before then.
Old 09-24-2024, 09:34 AM #21
How much of a DIY is this/how does the cost compare to a shop?
Old 09-24-2024, 01:18 PM #22
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing is a jewel in the rough GhostRing is a jewel in the rough GhostRing is a jewel in the rough
GhostRing's Avatar
Originally Posted by 96RedRunner View Post
You owe me laptop spit beer on mine laughing, you ain't lying. Is a back story to that.
haha! just ribbing ya'
between all of us, we'll get the answers somehow! ;)
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 09-24-2024, 10:08 PM #23
96RedRunner's Avatar
Real Name: Mark
96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold 96RedRunner is a splendid one to behold
Real Name: Mark
Shops my area done lost their minds $3k+- plus parts easy number to hit for all.
200k+- mi virgin location matters. Cams/bolts Rack pressure line fitting have eaten better
part of day to get to bushings on southern truck sawzal was needed. First time diy schedule
a weekend/looonng day for frontend. PBblaster for days before.
Links and Sways long day doable. Been my experience.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress not stock.
2011 Audi S5 Prestige 4.2 V8 6 spd. MT not stock.
Old 09-24-2024, 11:06 PM #24
Real Name: Mark
Real Name: Mark
Seen some at that milage a visual all it took to Yea those need changing.
Old 09-29-2024, 02:03 AM #25
a shop near me told me 10 hours so about 1400 bucks. I've seen videos on these and if anything the LCA might give me a headache. I'm doing shocks too so maybe all at once
Old 09-29-2024, 12:11 PM #26
I installed Whiteline LCA bushings and used this method: Replace Toyota Lower control arm bushings-SPC Alignment
Mine were seized. Yours may not be, but the bushing removal method still applies. It was fairly painless. I broke 2x 3/16" drill bits, so make sure you have some spares. I used the simple hammer and chisel method to drive out the split bushings. No power tools for that. They came out easily once the core was removed and the sleeve was cut. I think this method is better than the heat method.
You do need a Sawzall, some metal cutting blades and a beefy bench vice for the basic service. You might need the Sawzall to remove the arms/alignment cams if they're seized. I already owned a Sawzall, but I borrowed a ball joint press kit from O'Reilly's to install the bushings.
Hope this is useful information.
Cheers
Old 09-29-2024, 12:42 PM #27
I have a shop press and if that doesn't work the bottle jacks always an option like how mtbtim did in his video. Torch and press so no breaking bits or risk of cutting the inside of the sleeve
Old 10-02-2024, 09:56 PM #28
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
The sawzall, hammer and chisel method works better than the press method recommended in the FSM tbh. I just used the bottle jack to tear out the center sleeve of the bushing.
This is a long job, so I ended up buying used control arms to minimize downtime.
Old 10-04-2024, 01:50 AM #29
really, even with torching/pressing? that seems like it would be fast
Old 10-04-2024, 06:05 PM #30
T4R2014's Avatar
T4R2014's Avatar
Once you cut that inner sleeve it weakens and comes out easy. No heat involved, nor any potential projectiles from pressing. Plus the bearing splitter from the FSM method requires chiseling that lip on the bushing. I flattened the hell out of it for the bearing splitter to have meat to grab onto, and it still slipped off and broke the lip of the splitter. My second time around went way quicker with no press work involved. Maybe you'll have better luck with the press than me though.
arm , bushing , bushings , suspension , swap
How easy is a bushing swap on my UCAs?! LOSTR4 4th Gen T4Rs 9 01-30-2020 06:51 PM
Suspension Bushing Replacement hallcs 3rd gen T4Rs 3 07-13-2017 06:04 AM
Front suspension upgrade - LCA bushing swap, Bilstein 6112 alia176 4th Gen T4Rs 10 06-24-2017 04:39 PM
Have you ran a full taco suspension swap only? Cygan1008 4th Gen T4Rs 77 05-09-2016 10:59 PM
Question About End Link Bushing Swap RPC 4th Gen T4Rs 6 06-03-2014 11:50 PM
